查看: 12707|回复: 0
Arduino编写库函数Library出错,求解?
发表于 2016-4-29 14:09:43 | 显示全部楼层 |阅读模式
ino文件编译没问题,下载到板子上也是正常的,本想建立一个库函数,方便以后调用,分成.cpp和.h编译出错,检查了很多遍,网上和自建库函数有关的帖子也都看过,Arduino.cc的教程也反复看了几遍,有关书籍也看了,还是不能解决。
下面是IDE 1.6.8 报错的信息:
Arduino:1.6.8 (Windows 7), 开发板:"Arduino Nano, ATmega328"
In file included from D:\arduino-1.6.8-windows\arduino-1.6.8\hardware\arduino\avr\cores\arduino/Print.h:27:0,
                 from D:\arduino-1.6.8-windows\arduino-1.6.8\hardware\arduino\avr\cores\arduino/Stream.h:26,
                 from D:\arduino-1.6.8-windows\arduino-1.6.8\hardware\arduino\avr\libraries\Wire\src/Wire.h:26,
                 from D:\arduino-1.6.8-windows\arduino-1.6.8\libraries\CCS811\CCS811.c:3:
D:\arduino-1.6.8-windows\arduino-1.6.8\hardware\arduino\avr\cores\arduino/Printable.h:25:1: error: unknown type name 'class'
class Print;
D:\arduino-1.6.8-windows\arduino-1.6.8\hardware\arduino\avr\cores\arduino/Printable.h:33:1: error: unknown type name 'class'
class Printable
D:\arduino-1.6.8-windows\arduino-1.6.8\hardware\arduino\avr\cores\arduino/Printable.h:34:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
In file included from D:\arduino-1.6.8-windows\arduino-1.6.8\hardware\arduino\avr\cores\arduino/Stream.h:26:0,
D:\arduino-1.6.8-windows\arduino-1.6.8\hardware\arduino\avr\cores\arduino/Print.h:34:1: error: unknown type name 'class'
class Print
D:\arduino-1.6.8-windows\arduino-1.6.8\hardware\arduino\avr\cores\arduino/Print.h:35:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
In file included from D:\arduino-1.6.8-windows\arduino-1.6.8\hardware\arduino\avr\libraries\Wire\src/Wire.h:26:0,
D:\arduino-1.6.8-windows\arduino-1.6.8\hardware\arduino\avr\cores\arduino/Stream.h:49:1: error: unknown type name 'class'
class Stream : public Print
D:\arduino-1.6.8-windows\arduino-1.6.8\hardware\arduino\avr\cores\arduino/Stream.h:49:14: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
In file included from D:\arduino-1.6.8-windows\arduino-1.6.8\libraries\CCS811\CCS811.c:3:0:
D:\arduino-1.6.8-windows\arduino-1.6.8\hardware\arduino\avr\libraries\Wire\src/Wire.h:33:1: error: unknown type name 'class'
class TwoWire : public Stream
D:\arduino-1.6.8-windows\arduino-1.6.8\hardware\arduino\avr\libraries\Wire\src/Wire.h:33:15: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
D:\arduino-1.6.8-windows\arduino-1.6.8\hardware\arduino\avr\libraries\Wire\src/Wire.h:82:1: error: unknown type name 'TwoWire'
extern TwoWire Wire;
In file included from D:\arduino-1.6.8-windows\arduino-1.6.8\libraries\CCS811\CCS811.c:4:0:
D:\arduino-1.6.8-windows\arduino-1.6.8\libraries\CCS811/CCS811.h:41:1: error: unknown type name 'class'
class CCS811
D:\arduino-1.6.8-windows\arduino-1.6.8\libraries\CCS811/CCS811.h:42:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
D:\arduino-1.6.8-windows\arduino-1.6.8\libraries\CCS811\CCS811.c:7:7: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
CCS811::CCS811()
D:\arduino-1.6.8-windows\arduino-1.6.8\libraries\CCS811\CCS811.c:14:13: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
void  CCS811::begin() {
D:\arduino-1.6.8-windows\arduino-1.6.8\libraries\CCS811\CCS811.c:19:13: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
bool  CCS811::_HardWare_ID(){
D:\arduino-1.6.8-windows\arduino-1.6.8\libraries\CCS811\CCS811.c:39:13: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
bool  CCS811::_Valid_Firmware(){
D:\arduino-1.6.8-windows\arduino-1.6.8\libraries\CCS811\CCS811.c:62:14: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
void   CCS811::_Boot_to_Firmware_Mode(){
D:\arduino-1.6.8-windows\arduino-1.6.8\libraries\CCS811\CCS811.c:70:13: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
void  CCS811::_Measure_Mode(){
D:\arduino-1.6.8-windows\arduino-1.6.8\libraries\CCS811\CCS811.c:83:21: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
unsigned int  CCS811::Read_Value(CCS811MeasureType type){
D:\arduino-1.6.8-windows\arduino-1.6.8\libraries\CCS811\CCS811.c:137:13: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
void  CCS811::init_CCS811(){
exit status 1
Error compiling for board Arduino Nano.
在文件 -> 首选项开启
“编译过程中显示详细输出”选项
这份报告会包含更多信息。
GMT+8, 2026-7-29 00:56 , Processed in 0.052862 second(s), 17 queries .
