查看: 5877|回复: 1
enc28j60有访问局域网IP的办法吗
发表于 2016-5-5 20:46:18 | 显示全部楼层 |阅读模式
enc28j60我现代码访问域名外网是正常,但改为局域网IP,就不行,有解决办法吗
 楼主| 发表于 2016-5-5 20:47:28 | 显示全部楼层
  1. #include <EtherCard.h>
  2. #include <OneWire.h>
  3. #include <DallasTemperature.h>
  4. #define SEND_INTERVAL  30000
  5. #define TIMEOUT        5000
  6. #define ONE_WIRE_BUS   2
  7. #define STATUS_IDLE    0
  8. #define STATUS_SENT    1
  9. static byte mymac[] = {0xDD,0xDD,0xDD,0x00,0x00,0x01};
  10. byte Ethernet::buffer[700];
  11. char website[] PROGMEM = "192.168.1.18";
  12. char password[] PROGMEM = "password";
  13. OneWire oneWire(ONE_WIRE_BUS);
  14. DallasTemperature sensors(&oneWire);
  15. unsigned long previousMillis = 0;
  16. static byte session_id;
  17. byte actual_status;
  18. void setup () {
  19.   Serial.begin(57600);
  20.   Serial.println("WebTemperature demo");
  21.   Serial.println();
  22.   if (!ether.begin(sizeof Ethernet::buffer, mymac, 10)) {
  23.     Serial.println( "Failed to access Ethernet controller");
  24.     while(1);
  25.   } else Serial.println("Ethernet controller initialized");
  26.   if (!ether.dhcpSetup()) {
  27.     Serial.println("Failed to get configuration from DHCP");
  28.     while(1);
  29.   } else Serial.println("DHCP configuration done");
  30.   if (!ether.dnsLookup(website)) {
  31.     Serial.print("Unable to resolve Website IP");
  32.     while(1);
  33.   } else Serial.println("Website IP resolved");
  34.
  35.   Serial.println();
  36.   ether.printIp("IP Address:\t", ether.myip);
  37.   ether.printIp("Netmask:\t", ether.netmask);
  38.   ether.printIp("Gateway:\t", ether.gwip);
  39.   ether.printIp("Website IP:\t", ether.hisip);
  40.   Serial.println();
  41. }
  42.
  43. void loop() {
  44.   ether.packetLoop(ether.packetReceive());
  45.   unsigned long currentMillis = millis();
  46.
  47.   switch(actual_status) {
  48.     case STATUS_IDLE:
  49.       if(currentMillis - previousMillis > SEND_INTERVAL) {
  50.         previousMillis = currentMillis;
  51.         sendTemperature();
  52.       }
  53.       break;
  54.     case STATUS_SENT:
  55.       if(currentMillis - previousMillis > TIMEOUT) {
  56.         Serial.println("No response");
  57.         previousMillis = currentMillis;
  58.         actual_status = STATUS_IDLE;
  59.       }
  60.       checkResponse();
  61.   }
  62. }
  63.
  64. void sendTemperature() {
  65.
  66.   sensors.requestTemperatures();
  67.   float float_temp = sensors.getTempCByIndex(0);
  68.
  69.   char string_temp[7];
  70.   dtostrf(float_temp, 4, 2, string_temp);
  71.
  72.   Stash stash;
  73.   byte sd = stash.create();
  74.   stash.print(string_temp);
  75.   stash.save();
  76.   Stash::prepare(PSTR("GET /demo/saveTemp.php?temp=$H&pwd=$F HTTP/1.0" "\r\n"
  77.     "Host: $F" "\r\n" "\r\n"),
  78.     sd, password, website);
  79.   session_id = ether.tcpSend();
  80.   Serial.print("Temperature ");
  81.   Serial.print(string_temp);
  82.   Serial.print(" sent to website... ");
  83.   actual_status = STATUS_SENT;
  84. }
  85. void checkResponse() {
  86.
  87.   const char* reply = ether.tcpReply(session_id);
  88.   if(reply > 0) {
  89.     if(strstr(reply, "KO - ") != 0) Serial.println(strstr(reply, "KO - "));
  90.     else Serial.println("OK");
  91.     actual_status = STATUS_IDLE;
  92.   }
  93. }
GMT+8, 2026-7-29 00:06 , Processed in 0.034139 second(s), 17 queries .
