查看: 13718|回复: 3
8575移位检测问题
发表于 2016-5-7 10:41:43 | 显示全部楼层 |阅读模式
我用两块8575 I0扩展板得到一组10进制的数据,然后转换为2进制后正好是32个0,对应上两块扩展板的32个口,高电平为1,低电平为0,我现在要完成一个项目,就是当外部有连续的4个IO的输入,就点亮一个LED。
我本来是打算用一个for循环,从0到32进行数据循环,然后读取每一位的二进制数据,当读到1的时候累计一次,当读到0则进行清空,然后进行判断,当连续4个数据为1的时候进行输出,但不知为什么一直实现不了,求大师帮助
#include <Wire.h>
int address = 0x20; //0100000 (7bit)
int address1 = 0x21;
uint16_t dataReceive; //16bit data received
uint16_t dataSend;  //16bit data sent
uint16_t dataReceive1; //16bit data received
uint16_t dataSend1;  //16bit data sent
int LED8=10;
int a;//
int b;
int i;
int c;
uint16_t z;
  Wire.begin();
  Serial.begin(19200);
  pcf8575_write(dataSend); //turn the pcf8575 pins to input
  pcf8575_write(dataSend1);
  pinMode(LED8,OUTPUT);
  pcf8575_write(0xFF);
  dataReceive = pcf8575_read(); //read the pcf8575 pins
  dataReceive1 = pcf8575_read1();
  z=dataReceive1;
   c=(dataReceive,HEX);
   b=0;
   for (i=1;i<16;i++)
      a = bitRead(c,i);
      delay(5);
      if(a==1)
        b=b+1;
      if(a==0)
        b=0;
      if(b==4)
      digitalWrite(LED8,HIGH);
      digitalWrite(LED8,LOW);
     // delay(50);
  Serial.print(dataReceive,BIN); //~ inverses the results, this removes the ambiguity of leading zero
  Serial.print("  ");
  Serial.print(dataReceive1,BIN);
  Serial.print("   z= ");
  Serial.print(z);
  Serial.print("   c= "); //~ inverses the results, this removes the ambiguity of leading zero
  Serial.print(c);
  Serial.print("   a= "); //~ inverses the results, this removes the ambiguity of leading zero
  Serial.print(a);
   Serial.print("   i= "); //~ inverses the results, this removes the ambiguity of leading zero
  Serial.println(i);
  delay(50);
void pcf8575_write(uint16_t dt)
  Wire.beginTransmission(address);
  Wire.write(0xFF);
  Wire.write(0xFF);
  Wire.endTransmission();
  delayMicroseconds(16);
uint16_t pcf8575_read()
  uint8_t a,b;
  Wire.requestFrom(address,5);
  if(Wire.available())
    a = Wire.read();
    b = Wire.read();
    return(word(a,b));
void pcf8575_write1(uint16_t dt)
  Wire.beginTransmission(address1);
  Wire.write(0xFF);
  Wire.write(0xFF);
uint16_t pcf8575_read1()
  uint8_t c,d;
  Wire.requestFrom(address1,5);
    c = Wire.read();
    d = Wire.read();
    return(word(c,d));
 楼主| 发表于 2016-5-7 10:48:32 | 显示全部楼层
关键是c的值无法得到2进制,上面的是换16进制,结果通过串口看到他的值就是16,而不是16进制的值,改成BIN,返回数值就是2
 楼主| 发表于 2016-5-7 11:27:43 | 显示全部楼层
我用移位完成了上面的设计,但是现在新的问题来了,我无法确定到底是那几个IO的输入
我需要判断
发表于 2016-5-7 15:20:40 | 显示全部楼层
为啥验证码这么难输对
GMT+8, 2026-7-29 01:00 , Processed in 0.057493 second(s), 19 queries .
