查看: 26189|回复: 3
Arduino 1602液晶屏显示验证成功
发表于 2016-5-8 00:06:57 | 显示全部楼层 |阅读模式
1602的液晶屏用arduino板子,学习搭建,验证终于成功了。
学习帖子
https://www.arduino.cc/en/Tutorial/HelloWorld
验证体会
1. 可调电阻挺重要的,只有在阻值合适的时候,字体才会清晰地显现出来
2. 这个接线图没有问题,我验证过了。若小伙伴验证时不成功,不要气馁,反复检查pin脚接线有无错误。
代码
  LiquidCrystal Library - Hello World
Demonstrates the use a 16x2 LCD display.  The LiquidCrystal
library works with all LCD displays that are compatible with the
Hitachi HD44780 driver. There are many of them out there, and you
can usually tell them by the 16-pin interface.
This sketch prints "Hello World!" to the LCD
and shows the time.
  The circuit:
* LCD RS pin to digital pin 12
* LCD Enable pin to digital pin 11
* LCD D4 pin to digital pin 5
* LCD D5 pin to digital pin 4
* LCD D6 pin to digital pin 3
* LCD D7 pin to digital pin 2
* LCD R/W pin to ground
* LCD VSS pin to ground
* LCD VCC pin to 5V
* 10K resistor:
* ends to +5V and ground
* wiper to LCD VO pin (pin 3)
Library originally added 18 Apr 2008
by David A. Mellis
library modified 5 Jul 2009
by Limor Fried (http://www.ladyada.net)
example added 9 Jul 2009
by Tom Igoe
modified 22 Nov 2010
by Tom Igoe
This example code is in the public domain.
http://www.arduino.cc/en/Tutorial/LiquidCrystal
// include the library code:
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
  // set up the LCD's number of columns and rows:
  lcd.begin(16, 2);
  // Print a message to the LCD.
  lcd.print("Lv Weiling Happy");
  // set the cursor to column 0, line 1
  // (note: line 1 is the second row, since counting begins with 0):
  lcd.setCursor(0, 1);
  // print the number of seconds since reset:
  lcd.print(millis() / 1000);
 楼主| 发表于 2016-5-8 00:41:07 | 显示全部楼层
将串口输入显示到显示屏上,感觉不错
上一例接线不变,程序更新如下
  LiquidCrystal Library - Serial Input
This sketch displays text sent over the serial port
(e.g. from the Serial Monitor) on an attached LCD.
The circuit:
* 10K resistor:
by David A. Mellis
by Tom Igoe
by Tom Igoe
http://www.arduino.cc/en/Tutorial/LiquidCrystalSerial
  lcd.begin(16, 2);
  // initialize the serial communications:
  // when characters arrive over the serial port...
  if (Serial.available()) {
    // wait a bit for the entire message to arrive
    delay(100);
    // clear the screen
    lcd.clear();
    // read all the available characters
    while (Serial.available() > 0) {
      // display each character to the LCD
      lcd.write(Serial.read());
发表于 2016-5-8 13:34:03 | 显示全部楼层
不错,果断收藏了!
发表于 2016-5-9 11:15:16 | 显示全部楼层
图片用什么软件画的啊
GMT+8, 2026-7-28 23:12 , Processed in 0.034808 second(s), 20 queries .
