查看: 17364|回复: 3
关于Arduino与信捷PLC的modbus问题
发表于 2016-5-16 09:08:47 | 显示全部楼层 |阅读模式
我现在正在做ARDUINO与国产的信捷PLC的modbus协议通讯。
                     用的是ttl232转RS232的模块,然后将TX RX,等线连接好后。
       在PLC处进行了编辑,写了一个读程序和一个写程序,然后用格西烽火软件通过USB串口线看到确实有数据出来
       然后我用了下面的这一个程序。
#include <ModbusRtu.h>
uint16_t au16data[16]; //!< data array for modbus network sharing
uint8_t u8state; //!< machine state
uint8_t u8query; //!< pointer to message query
*  Modbus object declaration
*  u8id : node id = 0 for master, = 1..247 for slave
*  u8serno : serial port (use 0 for Serial)
*  u8txenpin : 0 for RS-232 and USB-FTDI
*               or any pin number > 1 for RS-485
Modbus master(0,0,0); // this is master and RS-232 or USB-FTDI
* This is an structe which contains a query to an slave device
modbus_t telegram[2];
unsigned long u32wait;
  // telegram 0: read registers--------du han shu
  telegram[0].u8id = 4; // slave address
  telegram[0].u8fct = 3; // function code (this one is registers read)
  telegram[0].u16RegAdd = 5; // start address in slave
  telegram[0].u16CoilsNo = 2; // number of elements (coils or registers) to read
  telegram[0].au16reg = au16data; // pointer to a memory array in the Arduino
  // telegram 1: write a single register----xie han shu
  telegram[1].u8id = 3; // slave address
  telegram[1].u8fct = 6; // function code (this one is write a single register)
  telegram[1].u16RegAdd = 2; // start address in slave
  telegram[1].u16CoilsNo = 10; // number of elements (coils or registers) to read
  telegram[1].au16reg = au16data; // pointer to a memory array in the Arduino
  master.begin( 19200 ); // baud-rate at 19200
  master.setTimeOut( 5000 ); // if there is no answer in 5000 ms, roll over
  u32wait = millis() + 100;
  u8state = u8query = 1;
  switch( u8state ) {
  case 0:
    if (millis() > u32wait) u8state++; // wait state
  case 1:
    master.query( telegram[u8query] ); // send query (only once)
    u8state++;
        u8query++;
        if (u8query > 2) u8query = 0;
  case 2:
    master.poll(); // check incoming messages
    if (master.getState() == COM_IDLE) {
      u8state = 0;
      u32wait = millis() + 1000;
  au16data[4] = analogRead(1);
结果我无论如何也无法进行通讯,希望有大神帮忙看看
发表于 2016-5-18 08:18:51 | 显示全部楼层
直接用格西对plc调试啊~不要自己写程序先
 楼主| 发表于 2016-5-18 08:30:33 | 显示全部楼层
我也是按照格式来的,可是怎么调试也是对不上通讯
发表于 2016-5-19 16:27:48 | 显示全部楼层
学习学习学习学习
GMT+8, 2026-7-28 18:05 , Processed in 0.050114 second(s), 20 queries .
