查看: 15963|回复: 5
arduino怎么控制电调来驱动电机 急急急 求大神帮帮忙
发表于 2016-5-28 17:28:45 | 显示全部楼层 |阅读模式
发表于 2016-5-29 13:55:13 | 显示全部楼层
输出PWM控制
发表于 2016-5-30 07:44:47 | 显示全部楼层
有专门的驱动电机的模块 或者用2003自己做
 楼主| 发表于 2016-5-30 14:04:54 | 显示全部楼层
电机大了L298驱动不了   要用电调来
 楼主| 发表于 2016-5-30 17:30:18 | 显示全部楼层
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
// twelve servo objects can be created on most boards
int pos = 0;    // variable to store the servo position
  myservo.attach(9);  // attaches the servo on pin 9 to the servo object
  for (pos = 0; pos <= 180; pos += 1) { // goes from 0 degrees to 180 degrees
    // in steps of 1 degree
    myservo.write(pos);              // tell servo to go to position in variable 'pos'
    delay(15);                       // waits 15ms for the servo to reach the position
  for (pos = 180; pos >= 0; pos -= 1) { // goes from 180 degrees to 0 degrees
 楼主| 发表于 2016-5-30 17:30:52 | 显示全部楼层
这个程序怎么用蓝牙模块控制啊
GMT+8, 2026-7-22 01:31 , Processed in 0.033615 second(s), 19 queries .
