查看: 11994|回复: 2
编译导航程序出错(关于TinyGPS.h),求大神指
发表于 2016-5-29 13:34:37 | 显示全部楼层 |阅读模式
程序在编译的时候出现错误,错误信息如下
Arduino:1.6.8 (Windows 10), 开发板:"Microduino/mCookie-Core+ (1284pa), Atmega1284pa@16M,5V"
C:\Program Files (x86)\Arduino For Microduino\arduino-builder -dump-prefs -logger=machine -hardware "C:\Program Files (x86)\Arduino For Microduino\hardware" -hardware "C:\Users\Administrator\AppData\Local\Arduino15\packages" -tools "C:\Program Files (x86)\Arduino For Microduino\tools-builder" -tools "C:\Program Files (x86)\Arduino For Microduino\hardware\tools\avr" -tools "C:\Users\Administrator\AppData\Local\Arduino15\packages" -built-in-libraries "C:\Program Files (x86)\Arduino For Microduino\libraries" -libraries "d:\Documents\Arduino\libraries" -fqbn=Microduino:avr:1284p:cpu=16MHzatmega1284 -ide-version=10608 -build-path "C:\Users\ADMINI~1\AppData\Local\Temp\build751bbe6aa14cf6d2f01190ada61d53a3.tmp" -warnings=default -prefs=build.warn_data_percentage=75 -verbose "C:\Users\Administrator\Desktop\401gpscoper\03\appMaster\appMaster\appMaster.ino"
C:\Program Files (x86)\Arduino For Microduino\arduino-builder -compile -logger=machine -hardware "C:\Program Files (x86)\Arduino For Microduino\hardware" -hardware "C:\Users\Administrator\AppData\Local\Arduino15\packages" -tools "C:\Program Files (x86)\Arduino For Microduino\tools-builder" -tools "C:\Program Files (x86)\Arduino For Microduino\hardware\tools\avr" -tools "C:\Users\Administrator\AppData\Local\Arduino15\packages" -built-in-libraries "C:\Program Files (x86)\Arduino For Microduino\libraries" -libraries "d:\Documents\Arduino\libraries" -fqbn=Microduino:avr:1284p:cpu=16MHzatmega1284 -ide-version=10608 -build-path "C:\Users\ADMINI~1\AppData\Local\Temp\build751bbe6aa14cf6d2f01190ada61d53a3.tmp" -warnings=default -prefs=build.warn_data_percentage=75 -verbose "C:\Users\Administrator\Desktop\401gpscoper\03\appMaster\appMaster\appMaster.ino"
"C:\Program Files (x86)\Arduino For Microduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -w -x c++ -E -CC -mmcu=atmega1284p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_PLUS -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino For Microduino\hardware\Microduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino For Microduino\hardware\Microduino\avr\variants\plus" "C:\Users\ADMINI~1\AppData\Local\Temp\build751bbe6aa14cf6d2f01190ada61d53a3.tmp\sketch\appMaster.ino.cpp" -o "nul"
"C:\Program Files (x86)\Arduino For Microduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -w -x c++ -E -CC -mmcu=atmega1284p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_PLUS -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino For Microduino\hardware\Microduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino For Microduino\hardware\Microduino\avr\variants\plus" "-IC:\Program Files (x86)\Arduino For Microduino\hardware\Microduino\avr\libraries\_10_System_SPI" "C:\Users\ADMINI~1\AppData\Local\Temp\build751bbe6aa14cf6d2f01190ada61d53a3.tmp\sketch\appMaster.ino.cpp" -o "nul"
"C:\Program Files (x86)\Arduino For Microduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -w -x c++ -E -CC -mmcu=atmega1284p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_PLUS -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino For Microduino\hardware\Microduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino For Microduino\hardware\Microduino\avr\variants\plus" "-IC:\Program Files (x86)\Arduino For Microduino\hardware\Microduino\avr\libraries\_01_Microduino_TFT" "-IC:\Program Files (x86)\Arduino For Microduino\hardware\Microduino\avr\libraries\_10_System_SPI" "C:\Users\ADMINI~1\AppData\Local\Temp\build751bbe6aa14cf6d2f01190ada61d53a3.tmp\sketch\appMaster.ino.cpp" -o "nul"
"C:\Program Files (x86)\Arduino For Microduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -w -x c++ -E -CC -mmcu=atmega1284p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_PLUS -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino For Microduino\hardware\Microduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino For Microduino\hardware\Microduino\avr\variants\plus" "-IC:\Program Files (x86)\Arduino For Microduino\hardware\Microduino\avr\libraries\_10_System_SPI" "-IC:\Program Files (x86)\Arduino For Microduino\hardware\Microduino\avr\libraries\_01_Microduino_TFT" "C:\Users\ADMINI~1\AppData\Local\Temp\build751bbe6aa14cf6d2f01190ada61d53a3.tmp\sketch\appMaster.ino.cpp" -o "C:\Users\ADMINI~1\AppData\Local\Temp\build751bbe6aa14cf6d2f01190ada61d53a3.tmp\preproc\ctags_target_for_gcc_minus_e.cpp"
C:\Users\Administrator\Desktop\401gpscoper\03\appMaster\appMaster\appMaster.ino:23:21: fatal error: TinyGPS.h: No such file or directory
#include <TinyGPS.h>
compilation terminated.
使用库 _10_System_SPI 在文件夹: C:\Program Files (x86)\Arduino For Microduino\hardware\Microduino\avr\libraries\_10_System_SPI (legacy)
使用库 _01_Microduino_TFT 在文件夹: C:\Program Files (x86)\Arduino For Microduino\hardware\Microduino\avr\libraries\_01_Microduino_TFT (legacy)
exit status 1
Error compiling for board Microduino/mCookie-Core+ (1284pa).
锻体期弟子,求大神指点
 楼主| 发表于 2016-5-29 13:35:23 | 显示全部楼层
菜鸟想复制大师作品,遇到问题了
发表于 2016-5-29 19:55:11 | 显示全部楼层
TinyGPS:在指定位置没有找到文件
你是不是没有下载库文件啊
GMT+8, 2026-7-28 16:17 , Processed in 0.039162 second(s), 18 queries .
