查看: 13598|回复: 2
这个程序怎么用才能用蓝牙来控制
发表于 2016-5-30 17:33:07 | 显示全部楼层 |阅读模式
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
// twelve servo objects can be created on most boards
int pos = 0;    // variable to store the servo position
  myservo.attach(9);  // attaches the servo on pin 9 to the servo object
  for (pos = 0; pos <= 180; pos += 1) { // goes from 0 degrees to 180 degrees
    // in steps of 1 degree
    myservo.write(pos);              // tell servo to go to position in variable 'pos'
    delay(15);                       // waits 15ms for the servo to reach the position
  for (pos = 180; pos >= 0; pos -= 1) { // goes from 180 degrees to 0 degrees
发表于 2016-5-30 19:55:32 | 显示全部楼层
藍牙控制只係一個無線既 serial input device.
你既程序根本不需要 input, 你想個藍牙可以做到什麼?
 楼主| 发表于 2016-5-31 13:08:49 | 显示全部楼层
可以用蓝牙模块发送指令达到想要的角度
GMT+8, 2026-7-25 05:16 , Processed in 0.047174 second(s), 18 queries .
