查看: 16903|回复: 3
arduino小游戏
发表于 2016-5-30 22:02:10 | 显示全部楼层 |阅读模式
闲来无事,用arduino写了个小游戏。如图,游戏很简单,简单的计数,按钮每按一次,计数一次,在小液晶上显示,计时十秒,时间一到,把最后的结果显示在小液晶上。因为程序粘贴在这文本中比较乱,所以最后附上程序源码压缩文件。
[pre lang="arduino" line="1" file="count"]#include <UTFT.h>
extern uint8_t SmallFont[];
extern uint8_t BigFont[];
extern uint8_t SevenSegNumFont[];
const int buttonPin = 53;
const int ledPin =  13;
int count=0;
int buttonState = 0;
int t=0;
UTFT myGLCD(ST7735,A2,A1,A5,A4,A3);
void Button();
void Winer();
  myGLCD.InitLCD();
  myGLCD.clrScr();
  pinMode(ledPin, OUTPUT);
  pinMode(buttonPin, INPUT_PULLUP);
  myGLCD.setColor(0, 255, 0);
  myGLCD.setBackColor(0, 0, 0);
  myGLCD.setFont(BigFont);
  myGLCD.print(" num is:", CENTER, 10);
  while(1) {
    Button();
    myGLCD.printNumI(count, CENTER, 42);
    t = millis()/1000;
    if(t==10)
      Winer();
      myGLCD.print(" time: ", CENTER, 68);
      myGLCD.printNumI(t, CENTER, 98);
void Button()
  buttonState = digitalRead(buttonPin);
  if (buttonState == HIGH)
    digitalWrite(ledPin, HIGH);
    digitalWrite(ledPin, LOW);
    delay(10);
    if (buttonState == LOW){
      count++;
    while(digitalRead(buttonPin)==LOW)
       delay(1);
void Winer()
  while(1)
     myGLCD.clrScr();
     myGLCD.print(" winer! ", CENTER, 10);
     myGLCD.print(" your ", CENTER, 26);
     myGLCD.print(" score:", CENTER, 42);
     while(1)
        myGLCD.setColor(255, 0, 0);
        myGLCD.printNumI(count, CENTER, 70);
        delay(200);
        delay(200);
[/code]
发表于 2016-5-31 00:02:26 | 显示全部楼层
这啥主板啊
 楼主| 发表于 2016-5-31 14:10:23 | 显示全部楼层
原野动力 发表于 2016-5-31 00:02
这啥主板啊
arduino due
发表于 2016-5-31 17:05:13 | 显示全部楼层
来个视频
GMT+8, 2026-7-28 17:09 , Processed in 0.037575 second(s), 20 queries .
