查看: 13094|回复: 0
【Ameba Arduino】实战:用Ameba打造Wi-Fi控制的MP3播放器
发表于 2016-6-3 11:33:46 | 显示全部楼层 |阅读模式
转载申明:原文连接http://makerpro.cc/2016/04/building-wifi-control-mp3player-by-ameba/
为了让Ameba能够广泛运用,本文作者(赖桑)hack了十几年前市面上常见的MP3播放器,进一步将MP3改装成可以通过WiFi点歌的设备,这样的系统出了运用在娱乐上,也能用子啊家庭安防上,而且价格只需要几百台币(5台币等于1元RMB)就可以获取这样的模组,既简单又方便。
视频连接:
材料准备
§  Ameba x1
§  Grove-Serial MP3 Player
§  Grove-LCD RGB Backlight
§  MicroSD卡
§  杜邦线若干
范例说明
所有模组都用Ameba的5v供电,建议在5V和GND之间,接一个电解质电容,以免有USB供电不稳,发送掉电的情况。
代码清单
[pre lang="arduino" line="1" file="Ameba_mp3"]#include "rgb_lcd.h"
#include "WiFiServer1.h"
#define mp3  Serial1
#define PORT 5000
char ssid[] = "AndroidAP1B3F";     // the name of your network
char pwd[] = "t101419008";        //The password of your AP
int status = WL_IDLE_STATUS;     // the Wifi radio's status
WiFiServer1 server(PORT);
WiFiClient1 client;
int playIndex = 1;
int volumn = 0x0E;
int playMode = 1;
rgb_lcd lcd;
const int colorR = 0;
const int colorG = 0;
const int colorB = 128;
  mp3.begin(9600);
  mp3.setTimeout(500);
  delay(100);
  if (true ==SetPlayMode(0x01))
    Serial.println("Set The Play Mode to 0x01, Single Loop Mode.");
    Serial.println("Playmode Set Error");
  PauseOnOffCurrentMusic();
  // set up the LCD's number of columns and rows:
  lcd.begin(16, 2);
  lcd.setRGB(colorR, colorG, colorB);
  lcd.print("Ameba MP3 player");
  status = WiFi1.begin(ssid, pwd);
  if ( status != WL_CONNECTED) {
    lcd.print("    No WiFi     ");
    // don't do anything else:
    while(true);
  else {
    delay(3000);
    IPAddress ip = WiFi1.localIP();
    lcd.setCursor(0, 1);
    lcd.print("S");      //Show server IP
    lcd.print(ip);
    server.begin();
  delay(1000);
char buffer[3];
  // check the network connection once every 10 seconds:
  // listen for incoming clients
  int n;
  client = server.available();
  if(client)
    lcd.setCursor(0, 0);
    lcd.print("C               ");
    lcd.setCursor(1, 0);
    lcd.print(client.get_address());
    lcd.setRGB(128, 128, 0);
    if(client.available())
      n = client.read((uint8_t*)(&buffer[0]), sizeof(buffer));
      n = server.write(buffer, n);
      Serial.println(buffer);
      switch(buffer[0])
        case 'P':
        case 'p':
          playIndex = buffer[1] - 0x30;
          SetMusicPlay(highByte(playIndex), lowByte(playIndex));
          delay(1000);
        case 'M':
        case 'm':
          playMode = buffer[1] - 0x30;
          SetPlayMode(playMode);
          delay(1000);
        case '+':
          volumn++;
          SetVolume(volumn);
        case '-':
          volumn--;
          SetVolume(volumn);
      buffer[0] = buffer[1] = buffer[2] = 0;
      client.stop();
//Set the music index to play, the index is decided by the input sequence
//of the music;
//hbyte: the high byte of the index;
//lbyte: the low byte of the index;
boolean SetMusicPlay(uint8_t hbyte,uint8_t lbyte)
    mp3.write(0x7E);
    mp3.write(0x04);
    mp3.write(0xA0);
    mp3.write(hbyte);
    mp3.write(lbyte);
    mp3.write(0x7E);
    delay(10);
    while(mp3.available())
        if (0xA0==mp3.read())
        return true;
        return false;
// Pause on/off  the current music
boolean PauseOnOffCurrentMusic(void)
    mp3.write(0x7E);
    mp3.write(0x02);
    mp3.write(0xA3);
    mp3.write(0x7E);
    delay(10);
        if (0xA3==mp3.read())
        return true;
        return false;
//Set the volume, the range is 0x00 to 0x1F
boolean SetVolume(uint8_t volume)
    mp3.write(0x7E);
    Mp3.write(0x03);
    mp3.write(0xa7);
    mp3.write(volume);
    mp3.write(0x7e);
    delay(10);
        if (0xa7==mp3.read())
        return true;
        return false;
Boolean setplaymode(uint8_t playmode)
    if (((playmode==0x00)|(playmode==0x01)|(playmode==0x02)|(playmode==0x03))==false)
        serial.println("playmode parameter error! ");
        return false;
    mp3.write(0x7e);
    mp3.write(0x03);
    mp3.write(0xa9);
    mp3.write(playmode);
    mp3.write(0x7e);
    delay(10);
    while(mp3.available())    {
        if (0xa9==mp3.read())
        return true;
        return false;
[/code]
需要用到的Grove LCD RGB backlight库文件:
基本解说:
Grove LCD RGB Backlight与Ameba间,透过I2C通讯,而GroveSerial MP3 player与Ameba以serial通讯。另外,Serial MP3 player上面主要是一个WT5001的芯片,这颗芯片就是当年MP3风行一时的主流,常被用于MP3的主芯片,同时也具有SPI及SD卡存取功能。
程序一开以serial1来跟MP3 player建立通讯,并且以protocol跟WT5001通讯。系统会先以single mode的方式发出SD卡上的一首歌曲。当系统登入WiFi后,会在LCD上显示当前取得的IP,目前程序固定port为5000.当使用者通过像是Telnet等终端登录Ameba之后,就可以舒服对应的资源,字串,控制MP3的歌曲播出效果。
结语
透过无线通讯控制音效发出,这样的功能本身就常见于目前日常生活的娱乐设备上,这次运用Ameba打造的WiFi控制MP3,只要所录制的MP3档案具有警示音效,就能再出门的时候当做警报器,甚至用于电话上的语音留言的发出。
而Amabe的下一代版本,将会特别强调影音串流管理效果,事实上,由于Ameba是以ARM Cortex系列为基础进行开发的,这样的效果是可以办到的。我个人非常期待新一代具有影音串流管理的Ameba,到时候再写文档与大家分享。
关于更多介绍请访问官方主页:http://ameba.realsil.com.cn/
QQ交流群:Ameba Arduino 技术交流群(184666894
论坛技术贴:
【新品推荐】Ameba Arduino全功能IoT解决方案
【Ameba Arduino】入手教程之一:开发环境搭建
【Ameba Arduino】入门教程之二:5分钟玩转小车无线控制
【Ameba Arduino】入门教程之三: Wi-Fi之初体验
【Ameba Arduino】入门教程之四:Ameba WebServer LED 控制
【Ameba Arduino】入门教程之五:给无线小车添加“眼睛”
【Ameba Arduino】入门教程之六:无线小车进阶控制---六轴姿态控制
GMT+8, 2026-7-28 12:34 , Processed in 0.074268 second(s), 18 queries .
