查看: 6291|回复: 6
网上买的shieldbot小车,做的循迹小车为什么往后跑。。。
发表于 2016-6-11 11:28:35 | 显示全部楼层 |阅读模式
求大神分析一下原因,本来想用这个来做毕业设计的,急死了
网上买的shieldbot小车,做的循迹小车为什么往后跑。。。用的Arduino Uno控制器,5路灰度传感器,L298P驱动芯片。本来用的ARDUINO里面的循迹程序,小车往后跑,后来自己也改了一下,程序都弄好之后,循迹的时候小车还是往后跑,直接跑偏轨道啊。。。新手实在没办法,
程序如下;
Arduino IDE界面中的程序:
#include <ShieldbotV1_0.h>
Shieldbot shieldbot = Shieldbot();        //decares a Shieldbot object
int S1,S2,S3,S4,S5;        //values to store state of sensors
  Serial.begin(9600);//Begin serial comm for debugging
  shieldbot.setMaxSpeed(200,200);//255 is max, if one motor is faster than another, adjust values
  //Read all the sensors
  S1 = shieldbot.readS1();//Read the first infrared sensor value,and assigned the value to S1
  S2 = shieldbot.readS2();//Read the second infrared sensor value,and assigned the value to S2
  S3 = shieldbot.readS3();//Read the third infrared sensor value,and assigned the value to S3
  S4 = shieldbot.readS4();//Read the fourth infrared sensor value,and assigned the value to S4
  S5 = shieldbot.readS5();//Read the fifth infrared sensor value,and assigned the value to S5
  //Note about IR sensors
  //if a sensor sees HIGH, it means that it just sees a reflective surface background(ex. whie)
  //if a sensor sees LOW, it means that it sees a non-reflective surface or empty space (ex. black tape line, or empty space off ledge)
  if(S1 == LOW && S5 == LOW)
  {        //if both the two outer IR line sensors see empty space (like edge of a table) stop moving
      shieldbot.stop();
      delay(100);
  else if(S1 == HIGH && S2 == HIGH &&S3 == HIGH &&S4 == HIGH &&S5 == HIGH)
  {    //if all the IR line sensors see white paper,just to stop it
     shieldbot.stop();
      delay(100);
  else if(S1 == LOW)
  {        //if the most right IR line sensors see black tape, turn right
    shieldbot.drive(80,0);// to turn right, left motor goes forward and right stop
    delay(50);
  else if(S2== LOW)
  {    //if the second IR line sensors see black tape, turn right
    shieldbot.drive(80,40);// to turn right a little, left motor goes forward fast than right a little
    delay(50);
  else if(S5 == LOW)
  {        //if  the  most left IR line sensors see black , turn left
    shieldbot.drive(0,80);// to turn left, right motor goes forward and left motor stop
    delay(50);
  else if(S4==LOW)
  {     //if  the fourth IR line sensors see black , turn left
    shieldbot.drive(40,80);// to turn left, right motor goes forward fast than left motor a little
    delay(50);
  else        //otherwise just go forward
    shieldbot.drive(80,80);
下面是ShieldbotV1_0.h库中的程序
// Only modify this file to include
// - function definitions (prototypes)
// - include files
// - extern variable definitions
// In the appropriate section
#ifndef _ShieldbotV1_0_H_
#define _ShieldbotV1_0_H_
#include "Arduino.h"
//add your includes for the project ShiledbotV1_0 here
//#define SHIELDBOTDEBUG 0
// for shieldbot Version 0.9 and 1.0
#define right1 5                        //define I1 interface
#define speedPinRight 6          //enable right motor (bridge A)
#define right2 7                      //define I2 interface
#define left1 8                      //define I3 interface
#define speedPinLeft 9          //enable motor B
#define left2 10                     //define I4 interface
// for shieldbot Version 1.1, we changed to the driver pins ,
//if you shieldbot is ver1.0 or 0.9, please using the above pin mapping;
/*#define right1 8                        //define I1 interface
#define speedPinRight 9         //enable right motor (bridge A)
#define right2 11                      //define I2 interface
#define left1 12                      //define I3 interface
#define speedPinLeft 10          //enable motor B
#define left2 13                    //define I4 interface */
#define finder1 A0                   //define line finder S1
#define finder2 A1                   //define line finder S2
#define finder3 A2                   //define line finder S3
#define finder4 A3                   //define line finder S4
#define finder5 4                    //define line finder S5
extern int speedmotorA; //define the speed of motorA
extern int speedmotorB; //define the speed of motorB
extern  int k,n;
extern  uint8_t flag;
//end of add your includes here
#ifdef __cplusplus
extern "C" {
#endif
void loop();
void setup();
#ifdef __cplusplus
} // extern "C"
#endif
//add your function definitions for the project Shiledbot here
// library interface description
class Shieldbot
  // user-accessible "public" interface
  public:
        Shieldbot();
        int readS1();
        int readS2();
        int readS3();
        int readS4();
        int readS5();
        void setMaxSpeed(int);
        void setMaxSpeed(int, int);
        void setMaxLeftSpeed(int);
        void setMaxRightSpeed(int);
        void rightMotor(char);
        void leftMotor(char);
        void drive(char, char);
        void forward();
        void backward();
        void stop();
        void stopRight();
        void stopLeft();
        void fastStopLeft();
        void fastStopRight();
        void fastStop();
下面是ShieldbotV1_0.cpp库中的程序:
// Do not remove the include below
#include "ShieldbotV1_0.h"
int speedmotorA = 255; //define the speed of motorA
int speedmotorB = 255; //define the speed of motorB
Shieldbot::Shieldbot()
  pinMode(right1,OUTPUT);
  pinMode(right2,OUTPUT);
  pinMode(speedPinRight,OUTPUT);
  pinMode(left1,OUTPUT);
  pinMode(left2,OUTPUT);
  pinMode(speedPinLeft,OUTPUT);
  pinMode(finder1,INPUT);
  pinMode(finder2,INPUT);
  pinMode(finder3,INPUT);
  pinMode(finder4,INPUT);
  pinMode(finder5,INPUT);
//sets same max speed to both motors
void Shieldbot::setMaxSpeed(int both){
  setMaxLeftSpeed(both);
  setMaxRightSpeed(both);
void Shieldbot::setMaxSpeed(int left, int right){
  setMaxLeftSpeed(left);
  setMaxRightSpeed(right);
void Shieldbot::setMaxLeftSpeed(int left){
  speedmotorB=left;
void Shieldbot::setMaxRightSpeed(int right){
  speedmotorA=right;
int Shieldbot::readS1(){
  return digitalReadA(finder1);
int Shieldbot::readS2(){
  return digitalRead(finder2);
int Shieldbot::readS3(){
  return digitalRead(finder3);
int Shieldbot::readS4(){
  return digitalRead(finder4);
int Shieldbot::readS5(){
  return digitalRead(finder5);
void Shieldbot::drive(char left, char right){
  rightMotor(right);
  leftMotor(left);
//char is 128 to 127
//mag is the direction to spin the right motor
//-128 backwards all the way
//0 dont move
//127 forwards all the way
void Shieldbot::rightMotor(char mag){
  int actualSpeed = 0;
  if(mag >0){ //forward
    float ratio = (float)mag/128;
    actualSpeed = (int)(ratio*speedmotorA); //define your speed based on global speed
        #if SHIELDBOTDEBUG
      Serial.print("forward right: ");
      Serial.println(actualSpeed);
        #endif
    analogWrite(speedPinRight,actualSpeed);
    digitalWrite(right1,LOW);
    digitalWrite(right2,HIGH);//turn right motor clockwise
  }else if(mag == 0){ //neutral
        #if SHIELDBOTDEBUG
      Serial.println("nuetral right");
        #endif
        stopRight();
  }else { //meaning backwards
    float ratio = (float)abs(mag)/128;
    actualSpeed = ratio*speedmotorA;
        #if SHIELDBOTDEBUG
      Serial.print("backward right: ");
        #endif
    digitalWrite(right1,HIGH);
    digitalWrite(right2,LOW);//turn right motor counterclockwise
//TODO shouldnt these share one function and just input the differences?
void Shieldbot::leftMotor(char mag){
  if(mag >0)
  { //forward
    float ratio = (float)(mag)/128;
    actualSpeed = (int)(ratio*speedmotorB); //define your speed based on global speed
        #if SHIELDBOTDEBUG
      Serial.print("forward left: ");
        #endif
    analogWrite(speedPinLeft,actualSpeed);
    digitalWrite(left1,LOW);
    digitalWrite(left2,HIGH);//turn left motor counter-clockwise
  else if(mag == 0)
  { //neutral
        #if SHIELDBOTDEBUG
      Serial.println("nuetral left");
        #endif
        stopLeft();
    actualSpeed = ratio*speedmotorB;
        #if SHIELDBOTDEBUG
      Serial.print("backward left: ");
        #endif
    digitalWrite(left1,HIGH);
    digitalWrite(left2,LOW);//turn left motor counterclockwise
void Shieldbot::forward(){
  leftMotor(127);
  rightMotor(127);
void Shieldbot::backward(){
  leftMotor(-128);
  rightMotor(-128);
void Shieldbot::stop(){
  stopLeft();
  stopRight();
void Shieldbot::stopLeft(){
  analogWrite(speedPinLeft,0);
void Shieldbot::stopRight(){
  analogWrite(speedPinRight,0);
//may be dangerous to motor if reverse current into hbridge exceeds 2A
void Shieldbot::fastStopLeft(){
  digitalWrite(left2,LOW);//turn DC Motor B move clockwise
void Shieldbot::fastStopRight(){
  digitalWrite(right2,LOW);//turn DC Motor A move anticlockwise
void Shieldbot::fastStop(){
        fastStopRight();
        fastStopLeft();
求大神分析一下!
发表于 2016-6-13 00:22:04 | 显示全部楼层
不是没人懂,是你粗心把线接错了!程序没问题的!!你模电基础差,有待提高!!!
回复 支持 1 反对 0
 楼主| 发表于 2016-6-11 11:32:57 | 显示全部楼层
  speedmotorB=left;
  speedmotorA=right;
  rightMotor(right);
  leftMotor(left);
//0 dont move
        #if SHIELDBOTDEBUG
        #endif
        #if SHIELDBOTDEBUG
        #endif
        stopRight();
        #if SHIELDBOTDEBUG
        #endif
  if(mag >0)
  { //forward
        #if SHIELDBOTDEBUG
        #endif
  else if(mag == 0)
  { //neutral
        #if SHIELDBOTDEBUG
        #endif
        stopLeft();
        #if SHIELDBOTDEBUG
        #endif
  leftMotor(127);
  rightMotor(127);
  leftMotor(-128);
  rightMotor(-128);
  stopLeft();
  stopRight();
        fastStopRight();
        fastStopLeft();
我应该改哪里才能让小车往前走啊
 楼主| 发表于 2016-6-11 13:41:06 | 显示全部楼层
好像没人懂。。。
发表于 2016-6-12 10:15:03 | 显示全部楼层
把电机的接线调换一下。
发表于 2016-9-7 18:09:05 | 显示全部楼层
电机转反了只要把A,B相反接,还有库文件直接一个压缩包嘛
发表于 2016-9-7 18:48:39 | 显示全部楼层
这已经不能用基础差来解释了
不过在论坛问问题抓住了重点
GMT+8, 2026-7-28 06:17 , Processed in 0.036028 second(s), 23 queries .
