查看: 13975|回复: 4
1602液晶屏显示问题
发表于 2016-6-27 20:40:38 | 显示全部楼层 |阅读模式
功能:利用SD模块和液晶屏模块,采集环境光照强度,存储在SD卡中,并显示在1602液晶屏上。
现状:液晶屏能够显示Initializing Done,很清晰,但却不能显示每秒钟采集的光照强度,为什么呐?
  SD card datalogger
This example shows how to log data from three analog sensors
to an SD card using the SD library.
The circuit:
* analog sensors on analog ins 0, 1, and 2
* SD card attached to SPI bus as follows:
** MOSI - pin 11
** MISO - pin 12
** CLK - pin 13
** CS - pin 4
created  24 Nov 2010
modified 9 Apr 2012
by Tom Igoe
This example code is in the public domain.
#include <SPI.h>
#include <SD.h>
#include<LiquidCrystal.h>
LiquidCrystal lcd(5,6,7,8,9,10);
const int chipSelect = 4;
  // Open serial communications and wait for port to open:
  lcd.begin(16,2);
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  Serial.print("Initializing SD card...");
  lcd.print("Initializing");
  lcd.setCursor(0,1);
  // see if the card is present and can be initialized:
  if (!SD.begin(chipSelect)) {
    Serial.println("Card failed, or not present");
    // don't do anything more:
    return;
  Serial.println("card initialized.");
  lcd.print("Done");
  delay(1000);
  lcd.clear();
  // make a string for assembling the data to log:
  String dataString = "";
  // read three sensors and append to the string:
    int sensor = analogRead(A0);
    delay(1000);
    dataString += String(sensor);
    lcd.setCursor(0,0);
    lcd.print(sensor,DEC);
    lcd.setCursor(0,1);
    lcd.print("OK");
    lcd.clear();
  // open the file. note that only one file can be open at a time,
  // so you have to close this one before opening another.
  File dataFile = SD.open("data1.xls", FILE_WRITE);
  // if the file is available, write to it:
  if (dataFile) {
    dataFile.println(dataString);
    dataFile.close();
    // print to the serial port too:
    Serial.println(dataString);
  // if the file isn't open, pop up an error:
  else {
    Serial.println("error opening datalog.xls");
发表于 2016-6-27 23:00:00 | 显示全部楼层
写文件要用时间啊。。。你电脑内存几个G,写个文件几毫秒,你不看看arduino内存多大。。。。
发表于 2016-6-28 10:38:53 | 显示全部楼层
看看我写的这个,显示正常,存储正常,可以参考看看
#include <LiquidCrystal.h>        //LCD显示库 1602LCD屏使用
#include <Wire.h>                 //i2c总线库     1307时钟使用 占用A4A5
#include <RTClib.h>              //RTC时钟芯片库  1307时钟使用
#include <DHT.h>                 //DHT11 DHT22 通用库
#include <SPI.h>                 //SPI总线库      SD卡使用
#include <SD.h>                  //SD卡库         SD卡使用
DHT dht;
RTC_DS1307 rtc;
int a=0;
const int chipSelect = 4;       //SD卡使用到引脚4
LiquidCrystal lcd(10,9,8,7,6,5); //LCD使用到引脚10,9,8,7,6,5
Serial.begin(9600);             //串口引脚波特率9600
Wire.begin();                    //i2c总线启用
rtc.begin();                     //RTC时钟启用
dht.setup(2); // data pin 2      //DHT使用到引脚2
pinMode(13, OUTPUT);
lcd.begin(16,2);
lcd.print("hello,World!");
    return;
  delay(3000);
   float humidity = dht.getHumidity();
  float temperature = dht.getTemperature();
   a= a+1;
    DateTime now = rtc.now();
   dataString +=String(a)+",";
   dataString += String(now.year(), DEC)+"-"+String(now.month(), DEC)+"-"+String(now.day(), DEC)+" ";
   dataString += String(now.hour(), DEC)+":"+String(now.minute(), DEC)+":"+String(now.second(), DEC);
   dataString +=","+String(dht.getHumidity())+","+String(dht.getTemperature());
   lcd.setCursor(0,1);
   lcd.print(String(dht.getHumidity())+","+String(dht.getTemperature()));
digitalWrite(13, HIGH);
   File dataFile = SD.open("datalog.csv", FILE_WRITE);
    if (dataFile) {
    dataFile.close();
    digitalWrite(13, LOW);
else {
    Serial.println("error opening datalog.txt");
 楼主| 发表于 2016-7-5 08:40:40 | 显示全部楼层
#include         //LCD显示库 1602LCD屏使用
谢谢指教,后来搞明白了。两个原因,1是IDE版本升级之后,1602液晶显示屏只能显示第一个字符,后来下载了一个低版本的IDE后,就能够正常显示了;2是没有给液晶屏显示字符设置停留时间,导致字符很快就消失了,后来增加了一句delay,就解决了。
 楼主| 发表于 2016-7-5 08:41:40 | 显示全部楼层
给显示屏增加了一句delay,效果好多了
GMT+8, 2026-7-28 12:38 , Processed in 0.100917 second(s), 19 queries .
