查看: 12402|回复: 0
有四组数据,但是为什么串口绘图器只画一个数据的图
发表于 2016-7-15 23:02:48 | 显示全部楼层 |阅读模式
请教各位大神,有四组数据,两个电位器和两个传感器,但是为什么使用串口绘图器只画一个数据的图?使用其他什么软件可以监视串口数据绘图啊?谢谢各位大神了
//PINs setting
int adjust1Pin = 15;    //用来调节A的电位器
int adjust2Pin =16;    //用来调节B的电位器
int read1Pin = 17;      //用来连接输入A传感器
int read2Pin = 18;      //用来连接输入B传感器
int i1Pin = 6;        //连接电机驱动板的I1接口
int i2Pin =9;        //连接电机驱动板的I2接口
int i3Pin = 10;        //连接电机驱动板的I3接口
int i4Pin = 11;        //连接电机驱动板的I4接口
int power1Pin = 3;     //连接电机驱动板的EA接口
int power2Pin = 5;     //连接电机驱动板的EB接口
boolean debug = false;
boolean writeLog = false;
double setKd1 =3.3;
double setKd2 =3.3;
double setKp = 1;
int offset = 70;
int delayMs = 1;
int tick = 0;
//int myLog[3500];
int *myLog = new int[3500];
//PID structure
typedef struct {
  double target;
  double aver;
  double Kp;
  double Kd;
  int preError;
  int power;
  boolean flag;
  double v;
} PID;
PID Pid1, Pid2;
  pinMode(i1Pin, OUTPUT);     //I1和I2都是数字信号
  pinMode(i2Pin, OUTPUT);     //通过设置I1和I2来控制电流方向
  pinMode(i3Pin, OUTPUT);     //I1和I2都是数字信号
  pinMode(i4Pin, OUTPUT);     //通过设置I1和I2来控制电流方向
  pinMode(power1Pin, OUTPUT);  //按占空比方式输出的模拟信号
  pinMode(power2Pin, OUTPUT);  //按占空比方式输出的模拟信号
  //analogWrite(rotatePin, 128);
  Serial.begin(9600);          //设置波特率
  TCCR0B = 0x01;   // Timer 0: PWM 5 &  6 @ 16 kHz
  TCCR1B = 0x01;   // Timer 1: PWM 9 & 10 @ 32 kHz
  TCCR2B = 0x01;   // Timer 2: PWM 3 & 11 @ 32 kHz
  Pid1.Kp = setKp;
  Pid1.preError = 0;
  Pid1.Kd = setKd1;
  Pid1.power = 0;
  Pid1.flag = true;
  Pid1.target = 300;
  Pid1.aver = 0;
  Pid1.v = 0;
  Pid2.Kp = setKp;
  Pid2.preError = 0;
  Pid2.Kd = setKd2;
  Pid2.power = 0;
  Pid2.flag = true;
  Pid2.target = 300;
  Pid2.aver = 0;
  Pid2.v = 0;
  tick = 0;
int tick2 = 0;
//boolean rotateFlag = true;
  //digitalWrite(rotatePin, rotateFlag);
  //rotateFlag = ! rotateFlag;
  //delay(16000);
  //return;
  if(false) tick = 0;
  tick++;
  if(tick==500)
    tick2++;
    if(tick2<50) {tick = 0;return;}
    tick2 = 0;
    if(writeLog)
      for(int i=0;i<500;i++)
        Serial.print(myLog[i*7 + 0]);
        Serial.print("  ");
        Serial.print(myLog[i*7 + 1]);
        Serial.print("  ");
        Serial.print(myLog[i*7 + 2]);
        Serial.print("  ");
        Serial.print(myLog[i*7 + 3]);
        Serial.print("  ");
        Serial.print(myLog[i*7 + 4]);
        Serial.print("  ");
        Serial.print(myLog[i*7 + 5]);
        Serial.print("  ");
        Serial.print(myLog[i*7 + 6]);
        Serial.println("  ");
      Serial.println(Pid1.target);
      Serial.println(Pid1.preError);
      Serial.println(Pid2.target);
      Serial.println(Pid2.preError);
    return;
  else if(tick>500)
    tick = 0;
    //delay(990000);
    return;
  //=======第一组电位器和传感器========
  int readValue1 = 0;
  for(int i = 0; i < 4; i++) readValue1 += analogRead(read1Pin);
  readValue1 >>= 2;
  //readValue1 += (Pid1.flag ? 1 : -1) * Pid1.power / 17;
  int adjustValue1 = analogRead(adjust1Pin); //410 analogRead(adjust1Pin);
  Pid1.aver = Pid1.aver * 0.9995 + readValue1 * 0.0005;
  Pid1.target = Pid1.target + (Pid1.target - Pid1.aver) / 100.0;
  Pid1.target = max(0, max(adjustValue1 - offset, Pid1.target));
  Pid1.target = min(755, min(adjustValue1 + offset, Pid1.target));
  //=======第二组电位器和传感器=======
  int readValue2 = 0;
  for(int i = 0; i < 4; i++) readValue2 += analogRead(read2Pin);
  readValue2 >>= 2;
  //readValue2 += (Pid2.flag ? 1 : -1) * Pid2.power / 6;
  int adjustValue2 = analogRead(adjust2Pin); //240 analogRead(adjust2Pin);
  Pid2.aver = Pid2.aver * 0.9995 + readValue2 * 0.0005;
  Pid2.target = Pid2.target + (Pid2.target - Pid2.aver) / 1000.0;
  Pid2.target = max(0, max(adjustValue2 - offset, Pid2.target));
  Pid2.target = min(755, min(adjustValue2 + offset, Pid2.target));
  if(true)
   Serial.println(adjustValue1);
   Serial.println(adjustValue2);
   Serial.println(readValue1);
   Serial.println(readValue2);
    Pid1.flag = adjustValue1 > 512;
    Pid1.power = abs(adjustValue1 - 512) / 2;
    if(Pid1.power > 255) Pid1.power = 255;
    digitalWrite(i1Pin, Pid1.flag);
    digitalWrite(i2Pin, !Pid1.flag);
    analogWrite(power1Pin, Pid1.power);
    Pid2.flag = adjustValue2 > 512;
    Pid2.power = abs(adjustValue2 - 512) / 2;
    if(Pid2.power > 255) Pid2.power = 255;
   digitalWrite(i3Pin, Pid2.flag);
    digitalWrite(i4Pin, !Pid2.flag);
    analogWrite(power2Pin, Pid2.power);
    delay(32000);
    return;
  //Calculate power values
  double v, error;
  error = readValue1 - Pid1.target;
  v = error - Pid1.preError;
  Pid1.v = (Pid1.v * 6 + v) / 7;
  Pid1.power = (int)error * Pid1.Kp + Pid1.v * Pid1.Kd;
  Pid1.flag = Pid1.power > 0;
  Pid1.power = abs(Pid1.power);
  if(Pid1.power>255) Pid1.power = 255;
  Pid1.preError = error;
  error = readValue2 - Pid2.target;
  v = error - Pid2.preError;
  Pid2.v = (Pid2.v * 6 + v) / 7;
  Pid2.power = (int)error * Pid2.Kp + Pid2.v * Pid2.Kd;
  Pid2.flag = Pid2.power < 0;
  Pid2.power = abs(Pid2.power);
  if(Pid2.power>255) Pid2.power = 255;
  Pid2.preError = error;
  //Write PMW to control the floa
  myLog[tick * 7 + 0] = tick;
  myLog[tick * 7 + 1] = (int)Pid1.target;
  myLog[tick * 7 + 2] = readValue1;
  myLog[tick * 7 + 3] = Pid1.power;
  myLog[tick * 7 + 4] = (int)Pid2.target;
  myLog[tick * 7 + 5] = readValue2;
  myLog[tick * 7 + 6] = Pid2.power;
  for(int i=0;i<8;i++)
    digitalWrite(rotatePins[i] , 0);
    digitalWrite(rotatePins[(i + 1) % 8] ,1);
    delay(1);
  digitalWrite(rotatePins[0] , 0);
  delay(delayMs);
GMT+8, 2026-7-28 12:33 , Processed in 0.059693 second(s), 19 queries .
