查看: 12200|回复: 1
简单控制L298电机驱动模块代码(正反转调速2个电机)
发表于 2012-12-7 21:10:06 | 显示全部楼层 |阅读模式
int Kp;
int dir1PinA = 4;
int dir2PinA = 7;
int dir1PinB = 8;
int dir2PinB = 12;
pinMode(4,OUTPUT);             //IO
    pinMode(7,OUTPUT);         //IO
      pinMode(8,OUTPUT);       //IO
        pinMode(12,OUTPUT);   //IO
        pinMode(10,OUTPUT);   //PWM引脚
        pinMode(11,OUTPUT);   //PWM引脚
Kp =analogRead(A2);    //电位器模拟 0-1023
  //>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>前进-------
if(Kp<500)                    //电位器旋至中间  向500-0影射成 0-255PWM 输出
  digitalWrite(dir1PinA,LOW);      //低
    digitalWrite(dir2PinA,HIGH);   //高
    digitalWrite(dir1PinB, LOW);
    digitalWrite(dir2PinB,HIGH);
analogWrite(10,map(Kp,500,0,0,255));
  analogWrite(11,map(Kp,500,0,0,255));
  //>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>后退-------
if(Kp>530)           //电位器旋至中间  向530-1023影射成 0-255PWM 输出
  digitalWrite(dir1PinA,HIGH);
    digitalWrite(dir2PinA,LOW);
    digitalWrite(dir1PinB,HIGH);
    digitalWrite(dir2PinB,LOW);
   analogWrite(10,map(Kp,530,1023,0,255));
  analogWrite(11,map(Kp,530,1023,0,255));
delay(10);
这个是 l298   正反转调速2个电机
发表于 2012-12-7 21:19:10 | 显示全部楼层
太谢谢楼主了
GMT+8, 2026-7-26 19:17 , Processed in 0.037258 second(s), 18 queries .
