查看: 16823|回复: 2
arduion 按键可否递增#define PIXEL_COUNT 16值
发表于 2016-8-31 10:20:45 | 显示全部楼层 |阅读模式
// This is a demonstration on how to use an input device to trigger changes on your neo pixels.這是如何使用的輸入設備來觸發你的新變化像素的演示。
// You should wire a momentary push button to connect from ground to a digital IO pin.  When you您應該連接一個瞬時按鈕從地面連接到數字IO引腳。當你
// press the button it will change to a new pixel animation.  Note that you need to press the按下按鈕,它會變成一個新的像素的動畫。請注意,您需要按
// button once to start the first animation!按鈕一次,開始第一個動畫!
#include <Adafruit_NeoPixel.h>
#define BUTTON_PIN   2    // Digital IO pin connected to the button.  This will be數字IO引腳連接到按鈕。這將是
                          // driven with a pull-up resistor so the switch should帶有上拉電阻驅動,從而該開關應該
                          // pull the pin to ground momentarily.  On a high -> low摳腳接地瞬間。在高 - >低
                          // transition the button press logic will execute.轉型按下按鈕邏輯將執行
#define PIXEL_PIN    6    // Digital IO pin connected to the NeoPixels.數字IO引腳連接到NeoPixels。
#define PIXEL_COUNT 16    //-----此处数值是否可以写成用按键增加和减少????
// Parameter 1 = number of pixels in strip,  neopixel stick has 8  參數1 =帶鋼像素數,neopixel粘有8
// Parameter 2 = pin number (most are valid)                       參數2 =針數(最有效)
// Parameter 3 = pixel type flags, add together as needed:         參數3 =像素類型的標誌,同時根據需要添加:
//   NEO_RGB     Pixels are wired for RGB bitstream                 NEO_RGB像素的有線RGB流
//   NEO_GRB     Pixels are wired for GRB bitstream, correct for neopixel stick                      NEO_GRB像素的有線暴流,正確neopixel棒
//   NEO_KHZ400  400 KHz bitstream (e.g. FLORA pixels)                                               NEO_KHZ400 400千赫比特流(如FLORA像素)
//   NEO_KHZ800  800 KHz bitstream (e.g. High Density LED strip), correct for neopixel stick         NEO_KHZ800 800 KHz的比特流(如高密度LED燈條),正確neopixel棒
Adafruit_NeoPixel strip = Adafruit_NeoPixel(PIXEL_COUNT, PIXEL_PIN, NEO_GRB + NEO_KHZ800);           //Adafruit_NeoPixel帶= Adafruit_NeoPixel(PIXEL_COUNT,PIXEL_PIN,NEO_GRB + NEO_KHZ800);
bool oldState = HIGH;     //布爾oldState =高;
int showType = 0;         //INT showType = 0;
void setup() {           //無效設置(){
  pinMode(BUTTON_PIN, INPUT_PULLUP);
  strip.begin();
  strip.show(); // Initialize all pixels to 'off'  初始化所有像素“關”
void loop() {                   //空隙環(){
  // Get current button state.     獲取當前按鈕狀態
  bool newState = digitalRead(BUTTON_PIN);         //布爾newState = digitalRead(BUTTON_PIN);
  // Check if state changed from high to low (button press).     檢查狀態由高變低(按下按鈕)。
  if (newState == LOW && oldState == HIGH) {                     //如果(newState ==低&& oldState == HIGH){
    // Short delay to debounce button.                           //短延時去抖按鈕。
    delay(20);                                                   //延遲(20);
    // Check if button is still low after debounce.              //檢查按鈕仍然偏低抖了。
    if (newState == LOW) {                                       //如果(newState == LOW){
      showType++;
      if (showType > 9)                                          // 如果(showType> 9)
        showType=0;
      startShow(showType);
  // Set the last button state to the old state.                   //設置最後一個按鈕的狀態到老態。
  oldState = newState;
void startShow(int i) {                                                 // 無效startShow(int i)以{
  switch(i){                                                            //開關(ⅰ){
    case 0: colorWipe(strip.Color(0, 0, 0), 50);    // Black/off          情況下0:colorWipe(strip.Color(0,0,0),50); //黑/關閉
            break;                                                     //打破;
    case 1: colorWipe(strip.Color(255, 0, 0), 50);  // Red                 情況1:colorWipe(strip.Color(255,0,0),50); //紅
    case 2: colorWipe(strip.Color(0, 255, 0), 50);  // Green                情況2:colorWipe(strip.Color(0,255,0),50); //綠
    case 3: colorWipe(strip.Color(0, 0, 255), 50);  // Blue                 情況3:colorWipe(strip.Color(0,0,255),50); //藍
    case 4: theaterChase(strip.Color(127, 127, 127), 50); // White          情況4:theaterChase(strip.Color(127,127,127),50); //白
    case 5: theaterChase(strip.Color(127,   0,   0), 50); // Red            情況5:theaterChase(strip.Color(127,0,0),50); //紅
    case 6: theaterChase(strip.Color(  0,   0, 127), 50); // Blue           情況6:theaterChase(strip.Color(0,0,127),50); //藍
    case 7: rainbow(20);                                                 //案例7:彩虹(20);
    case 8: rainbowCycle(20);                                           //殼體8:rainbowCycle(20);
    case 9: theaterChaseRainbow(50);                                    // 情況9:theaterChaseRainbow(50);
// Fill the dots one after the other with a color                      後,其他用顏色填充點單
void colorWipe(uint32_t c, uint8_t wait) {                             //無效colorWipe(uint32_t的C,uint8_t有等待){
  for(uint16_t i=0; i<strip.numPixels(); i++) {                        //  對於(uint16_t我= 0;我<strip.numPixels();我++){
      strip.setPixelColor(i, c);                                       // strip.setPixelColor(I,C);
      strip.show();
      delay(wait);                                                     // 延遲(等待);
void rainbow(uint8_t wait) {                                           //彩虹無效(uint8_t有等待){
  uint16_t i, j;
  for(j=0; j<256; j++) {                                               // 對於(J = 0;&#308;<256; J ++){
    for(i=0; i<strip.numPixels(); i++) {                               // 對於(i = 0;我<strip.numPixels();我++){
      strip.setPixelColor(i, Wheel((i+j) & 255));                      //   strip.setPixelColor(ⅰ,輪式((I + J)255));
    strip.show();
    delay(wait);                                                       //延遲(等待);
// Slightly different, this makes the rainbow equally distributed throughout         略有不同,這使得彩虹均勻分佈在整個
void rainbowCycle(uint8_t wait) {                                                    //無效rainbowCycle(uint8_t有等待){
  uint16_t i, j;
  for(j=0; j<256*5; j++) { // 5 cycles of all colors on wheel                         //對於(J = 0;&#308;<256 * 5; J ++){// 5個週期輪上的所有顏色
    for(i=0; i< strip.numPixels(); i++) {                                             //對於(i = 0;我<strip.numPixels();我++){
      strip.setPixelColor(i, Wheel(((i * 256 / strip.numPixels()) + j) & 255));       //strip.setPixelColor(我,車輪(((I * 256 / strip.numPixels())+ J)255));
    strip.show();
//Theatre-style crawling lights.                                                    //劇院式燈光爬行。
void theaterChase(uint32_t c, uint8_t wait) {                                       //無效theaterChase(uint32_t的C,uint8_t有等待){
  for (int j=0; j<10; j++) {  //do 10 cycles of chasing                             //對於(INT J = 0;&#308;<10; J ++){//做10次追逐
    for (int q=0; q < 3; q++) {                                                     //為(中間體Q = 0,Q <3,Q ++){
      for (int i=0; i < strip.numPixels(); i=i+3) {                                 //  對於(INT I = 0;我<strip.numPixels(); I = I + 3){
        strip.setPixelColor(i+q, c);    //turn every third pixel on                 //   strip.setPixelColor(I + Q,C); //把每一個第三像素的
      strip.show();
        strip.setPixelColor(i+q, 0);        //turn every third pixel off            把每一個第三像素關閉
//Theatre-style crawling lights with rainbow effect                                 劇院式燈光爬行彩虹效果
void theaterChaseRainbow(uint8_t wait) {                                            //無效theaterChaseRainbow(uint8_t有等待){
  for (int j=0; j < 256; j++) {     // cycle all 256 colors in the wheel            // 對於(INT J = 0;&#308;<256; J ++){//週期的所有256種顏色的輪
        for (int i=0; i < strip.numPixels(); i=i+3) {                               //對於(INT I = 0;我<strip.numPixels(); I = I + 3){
          strip.setPixelColor(i+q, Wheel( (i+j) % 255));    //turn every third pixel on   把每一個第三像素的
        strip.show();
          strip.setPixelColor(i+q, 0);        //turn every third pixel off         //  strip.setPixelColor(ⅰ+ Q,0); //把每一個第三像素關閉
// Input a value 0 to 255 to get a color value.                                   //輸入值0到255得到的顏色值。
// The colours are a transition r - g - b - back to r.                            //顏色是一個過渡的R - 克 - B - 回河
uint32_t Wheel(byte WheelPos) {                                                   //uint32_t的車輪(字節WheelPos){
  WheelPos = 255 - WheelPos;
  if(WheelPos < 85) {                                                             //  如果(WheelPos <85){
   return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3);                       // 返回strip.Color(255 - WheelPos * 3,0 WheelPos * 3);
  } else if(WheelPos < 170) {                                                     //}否則,如果(WheelPos <170){
    WheelPos -= 85;
   return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3);                       // 返回strip.Color(0,WheelPos * 3,255 - WheelPos * 3);
  } else {        // }其他{
   WheelPos -= 170;
   return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0);                       //返回strip.Color(WheelPos * 3,255 - WheelPos * 3,0);
 楼主| 发表于 2016-9-1 08:57:53 | 显示全部楼层
等待中~~~~
发表于 2016-9-1 16:54:13 | 显示全部楼层
改成
int PIXEL_COUNT = 16;试试嘛
define是常量, 不允许更改
GMT+8, 2026-7-28 08:10 , Processed in 0.032831 second(s), 18 queries .
