查看: 15900|回复: 3
W5100与Arduino的下载问题
发表于 2016-9-5 10:41:22 | 显示全部楼层 |阅读模式
Yeelink sensor client power switch example
#include <SPI.h>
#include <Ethernet.h>
#include <Wire.h>
#include <math.h>
byte buff[2];
// for yeelink api
#define APIKEY         "96abb172345a41d71934027704a3xxxx" // 此处替换为你自己的API KEY
#define DEVICEID       350557 // 此处替换为你的设备编号
#define SENSORID1      393573 // 此处替换为你的传感器编号
// assign a MAC address for the ethernet controller.
byte mac[] = { 0x00, 0x1D, 0x72, 0x82, 0x35, 0x9D};
// initialize the library instance:
EthernetClient client ;
char server[] = "api.yeelink.net";   // name address for yeelink API
unsigned long lastConnectionTime = 0;          // last time you connected to the server, in milliseconds
boolean lastConnected = false;                 // state of the connection last time through the main loop
const unsigned long postingInterval = 3*1000; // delay between 2 datapoints, 30s
String returnValue = "";
boolean ResponseBegin = false;
  pinMode(13, OUTPUT); //高电平点亮
  Wire.begin();
  // start serial port:
Serial.begin(57600);
  // start the Ethernet connection with DHCP:
  if (Ethernet.begin(mac) == 0) {
    for(;;)
  else {
    Serial.println("Ethernet configuration OK");
  // if there's incoming data from the net connection.
  // send it out the serial port.  This is for debugging
  // purposes only:
  if (client.available()) {
    char c = client.read();
   // Serial.print(c);
      if (c == '{')
        ResponseBegin = true;
      else if (c == '}')
      if (ResponseBegin)
        returnValue += c;
  if (returnValue.length() !=0 && (ResponseBegin == false))
    Serial.println(returnValue);
    if (returnValue.charAt(returnValue.length() - 1) == '1') {
      Serial.println("turn on the LED");
      digitalWrite(13, HIGH);
      else if(returnValue.charAt(returnValue.length() - 1) == '0') {
      Serial.println("turn off the LED");
      digitalWrite(13, LOW);
     returnValue = "";
  // if there's no net connection, but there was one last time
  // through the loop, then stop the client:
  if (!client.connected() && lastConnected) {
    Serial.println();
    client.stop();
  // if you're not connected, and ten seconds have passed since
  // your last connection, then connect again and send data:
  if(!client.connected() && (millis() - lastConnectionTime > postingInterval)) {
    // read sensor data, replace with your code
    //int sensorReading = readLightSensor();
    Serial.print("yeelink:");
    //get data from server
    getData();
  // store the state of the connection for next time through
  // the loop:
  lastConnected = client.connected();
// this method makes a HTTP connection to the server and get data back
void getData(void) {
  // if there's a successful connection:
  if (client.connect(server, 80)) {
    // send the HTTP GET request:
    client.print("GET /v1.0/device/");
    client.print(DEVICEID);
    client.print("/sensor/");
    client.print(SENSORID1);
    client.print("/datapoints");
    client.println(" HTTP/1.1");
    client.println("Host: api.yeelink.net");
    client.print("Accept: *");
    client.print("/");
    client.println("*");
    client.print("U-ApiKey: ");
    client.println(APIKEY);
    client.println("Content-Length: 0");
    client.println("Connection: close");
    client.println();
    Serial.println("print get done.");
  else {
    // if you couldn't make a connection:
    Serial.println();
    client.stop();
   // note the time that the connection was made or attempted:
下载程序的时候,系统自动选择EtEtherne ,我就选择的他,编译通过,但是上传程序就出错额,我就右选择的
NANO
[Stino - 开始下载...]
avrdude: Expected signature for ATMEGA328P is 1E 95 0F
         Double check chip, or use -F to override this check.
[Stino - 发生错误,错误代码1。]
,用的官方例程,编译可以通过,但是就是上传不了啊 ,大神,求助!
编译通过
编译通过
发表于 2016-9-5 17:20:08 | 显示全部楼层
sublime编写Arduino程序?
发表于 2016-9-5 21:02:43 | 显示全部楼层
不明你在说啥。。。。
 楼主| 发表于 2016-9-6 09:16:16 | 显示全部楼层
mikeliujia 发表于 2016-9-5 17:20
sublime编写Arduino程序?
是的,好好用
GMT+8, 2026-7-24 20:27 , Processed in 0.036894 second(s), 20 queries .
