查看: 18350|回复: 2
关于2块GY-30同时显示的问题
发表于 2016-9-14 23:58:40 | 显示全部楼层 |阅读模式
想用2个GY-30做个光照比较,但是改BH1750程序时,无法加入第二个BH1750
程序如下
//VCC-5v
//GND-GND
//SCL-SCL(A5)
//SDA-SDA(A4)
//ADD-GND     ADD接VCC为0x5c ADD接GND为0x23
#include "Wire.h"
#include "math.h"
int BH1750address1 = 0x23;//BH1750 I2C地址、
int BH1750address2 = 0x5c;
byte buff[2];
  Wire.begin();
  Serial.print( BH17501() );
  Serial.print( “/” );
  Serial.print( BH17502() );
  Serial.println("[lx]");
double BH17501() //BH1750设备操作
double BH17502()
  int ia = 0;
  int ib = 0;
  double vala = 0;
  double valb = 0
                //开始I2C读写操作
  Wire.beginTransmission(BH1750address1);
  Wire.beginTransmission(BH1750address2);
  Wire.write(0x10);//1lx reolution 120ms//发送命令
  Wire.endTransmission();
  delay(200);
  //读取数据
  Wire.requestFrom(BH1750address1, 2);
  Wire.requestFrom(BH1750address2, 2);
  while (Wire.available()) //
    buff[ia] = Wire.read(); // receive one byte
    buff[ib] = Wire.read();
    ia++;
    ib++;
  if (2 == ia)
    vala = ((buff[0] << 8) | buff[1]) / 1.2;
  return vala;
  if (2 == ib)
    valb = ((buff[0] << 8) | buff[1]) / 1.2;
return vala;
主要是看不懂BH1750()是从double里读取的还是其他地方读出来的
问题简介如下
gy-30:24: error: expected initializer before 'double'
double BH17502()
exit status 1
谢谢各位大神了
 楼主| 发表于 2016-9-26 15:29:13 | 显示全部楼层
好吧,没人回。。。
研究了好久终于弄好了
顺便发发
#include "Wire.h" //IIC库
#include "math.h"
int BH1750address1 = 0x23;//芯片地址为16位23
byte buff[2];
  Wire.begin();
  int ia;
  int ib;
  int sumcd;
  uint16_t vala = 0;
  uint16_t valb = 0;
  BH1750a_Init(BH1750address1);
  BH1750b_Init(BH1750address2);
  delay(1000);
  if (2 == BH1750a_Read(BH1750address1))
    vala = ((buff[0] << 8) | buff[1]) / 12 - 3;
  if (2 == BH1750b_Read(BH1750address2))
    valb = ((buff[0] << 8) | buff[1]) / 12;
delay(150);
Serial.print(vala, DEC);
Serial.print("/");
  Serial.print(valb, DEC);
int BH1750a_Read(int address1) //
  int ia = 0;
  Wire.beginTransmission(address1);
  Wire.requestFrom(address1, 2);
    buff[ia] = Wire.read();  // read one byte
    ia++;
  return ia;
int BH1750b_Read(int address2) //
  int ib = 0;
  Wire.beginTransmission(address2);
  Wire.requestFrom(address2, 2);
    buff[ib] = Wire.read();  // read one byte
    ib++;
  return ib;
void BH1750a_Init(int address1)
void BH1750b_Init(int address2)
发表于 2018-5-31 22:14:30 | 显示全部楼层
请问这个芯片地址是怎么确定的?我很想请教下
GMT+8, 2026-7-26 22:23 , Processed in 0.037454 second(s), 19 queries .
