查看: 14194|回复: 1
外部中断种类
发表于 2016-10-16 21:06:33 | 显示全部楼层 |阅读模式
不管是FALLING,RISING,CHANGE,输出为什么都一样
unsigned long time1 = 0;
unsigned long time2 = 0;
int pin = 2;
int i = 0;
unsigned long t1 = 0, t2 = 0;// 时间标记
  pinMode(pin,INPUT);
  attachInterrupt(0,Code,FALLING);//中断种类换成RISING,CHANGE,结果都一样,是不是板子坏了???
void Code()
  t1 = millis();
if((t1-t2)>10)
    Serial.print(i);
  Serial.println("zhongduan");
  i++;
  t2 = millis();
 楼主| 发表于 2016-10-16 21:14:07 | 显示全部楼层
在没有外接电路下,把手靠近Pin2的引脚都能触发中断,这的怎么回事????
GMT+8, 2026-7-24 00:46 , Processed in 0.034556 second(s), 17 queries .
