查看: 15485|回复: 0
MPU6050+12864 问题
发表于 2016-11-13 11:25:41 | 显示全部楼层 |阅读模式
做MPU6050在12864上显示数据,但是显示实时数据的部分一直有问题,不知道如何解决,请大神帮我看看
//#include <LiquidCrystal.h>
#include "LCD12864RSPI.h"
#define AR_SIZE( a ) sizeof( a ) / sizeof( a[0] )
//LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
unsigned char Re_buf[11],counter=0;
unsigned char sign=0;
double tempa,tempb,tempc;
char jiaosudu[5],key[5],jiaodu[5];
unsigned char show6[]={0xCB,0xD9,0xB6,0xC8,0x3A,0x00};//速度:
unsigned char show7[]="key:";//key
unsigned char show8[]={0xBD,0xC7,0xB6,0xC8,0x3A,0x00};//角度:
unsigned char show9[]={0xCF,0xD4,0xCA,0xBE,0xD0,0xC5,0xCF,0xA2,0x3A,0x00};//显示信息:
unsigned char logo0[]={                                         //笑脸
      0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x00,0x00,0x01,0xFF,
      0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x00,0x00,0x1F,0xFF,
      0xF8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,
      0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x00,0x03,0xFE,0x00,
      0x7F,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x00,0x0F,0xF0,0x00,
      0x0F,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x00,0x1F,0x80,0x00,
      0x01,0xF8,0x00,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x00,0x3E,0x00,0x00,
      0x00,0x7C,0x00,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x00,0xF8,0x00,0x00,
      0x00,0x1F,0x00,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x01,0xF0,0x00,0x00,
      0x00,0x0F,0x80,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x03,0xE0,0x00,0x00,
      0x00,0x07,0xC0,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x07,0xC0,0x00,0x00,
      0x00,0x01,0xE0,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x07,0x80,0x00,0x00,
      0x00,0x00,0xE0,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x0F,0x00,0x00,0x00,
      0x00,0x00,0xF0,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x1E,0x00,0x00,0x00,
      0x00,0x00,0x78,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x3C,0x00,0x00,0x00,
      0x00,0x00,0x3C,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x38,0x00,0x40,0x00,
      0x00,0x80,0x1C,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x78,0x03,0xF8,0x00,
      0x07,0xF0,0x1E,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x70,0x07,0xFE,0x00,
      0x0F,0xFC,0x0E,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0xF0,0x1F,0xBF,0x00,
      0x3F,0x7E,0x0F,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0xE0,0x3E,0x0F,0x80,
      0x7C,0x1F,0x07,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0xE0,0x7C,0x07,0xC0,
      0xF8,0x0F,0x87,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x01,0xE0,0xF8,0x01,0xE1,
      0xF0,0x03,0xC3,0x80,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x01,0xC0,0xF0,0x01,0xE1,
      0xE0,0x03,0xC3,0x80,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x01,0xC0,0xE0,0x00,0xE1,
      0xC0,0x01,0xC3,0x80,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x01,0xC0,0x00,0x00,0x00,
      0x00,0x00,0x03,0x80,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x03,0x80,0x00,0x00,0x00,
      0x00,0x00,0x01,0xC0,0x00,0x00,0x00,0x00,
      0x00,0x00,0x01,0x80,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x01,0xE0,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0xE0,0x00,0x00,0x00,
      0x00,0x00,0x07,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0xF0,0x00,0x0C,0x00,
      0x0C,0x00,0x0F,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x70,0x00,0x1E,0x00,
      0x1E,0x00,0x0E,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x78,0x00,0x1F,0x00,
      0x3E,0x00,0x1E,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x38,0x00,0x07,0x80,
      0xF8,0x00,0x1C,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x3C,0x00,0x03,0xE1,
      0xF0,0x00,0x3C,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x1E,0x00,0x01,0xFF,
      0xE0,0x00,0x78,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x0F,0x00,0x00,0xFF,
      0x80,0x00,0xF0,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x07,0x00,0x00,0x3F,
      0x00,0x7E,0x00,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x00,0x0F,0xE0,0x00,
      0x07,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,
      0x3F,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,
float a[3],w[3],angle[3],T;
  // initialize serial:
  Serial.begin(115200);
  Serial1.begin(115200);
  LCDA.initDriverPin(36,38,40);
  LCDA.Initialise(); // 屏幕初始化
  delay(100);
  LCDA.CLEAR();//清屏
  delay(100);
  LCDA.DrawFullScreen(logo0);
  delay(2000);
  LCDA.CLEAR();
  //lcd.begin(16, 2);
  //lcd.print("angle:");
void loop(){
  LCDA.DisplayString(0,0,show9,AR_SIZE(show9));
  LCDA.DisplayString(1,0,show6,AR_SIZE(show6));
  LCDA.DisplayString(2,0,show7,AR_SIZE(show7));
  LCDA.DisplayString(3,0,show8,AR_SIZE(show8));
  serialEvent();
  if(sign)
     sign=0;
     if(Re_buf[0]==0x55)      //检查帧头
        switch(Re_buf[1])
        case 0x51:
                a[0] = (short(Re_buf [3]<<8| Re_buf [2]))/32768.0*16;
                a[1] = (short(Re_buf [5]<<8| Re_buf [4]))/32768.0*16;
                a[2] = (short(Re_buf [7]<<8| Re_buf [6]))/32768.0*16;
                T = (short(Re_buf [9]<<8| Re_buf [8]))/340.0+36.25;
        case 0x52:
                w[0] = (short(Re_buf [3]<<8| Re_buf [2]))/32768.0*2000;
                w[1] = (short(Re_buf [5]<<8| Re_buf [4]))/32768.0*2000;
                w[2] = (short(Re_buf [7]<<8| Re_buf [6]))/32768.0*2000;
        case 0x53:
                angle[0] = (short(Re_buf [3]<<8| Re_buf [2]))/32768.0*180;
                angle[1] = (short(Re_buf [5]<<8| Re_buf [4]))/32768.0*180;
                angle[2] = (short(Re_buf [7]<<8| Re_buf [6]))/32768.0*180;
                /*Serial.print("a:");
                Serial.print(a[0]);Serial.print(" ");
                Serial.print(a[1]);Serial.print(" ");
                Serial.print(a[2]);Serial.print(" ");
                Serial.print("w:");
                Serial.print(w[0]);Serial.print(" ");
                Serial.print(w[1]);Serial.print(" ");
                Serial.print("angle:");
                Serial.print(angle[0]);Serial.print(" ");
                Serial.print(angle[1]);Serial.print(" ");
                Serial.print(angle[2]);Serial.print(" ");
                Serial.print("T:");
                Serial.println(T);*/
  //lcd.setCursor(0, 1);
  //lcd.print(angle[1]);
  tempa=(double)w[1];
  dtostrf(tempa,5,2,jiaosudu[5]);
// tempb=double(key);
//  dtostrf(tempb,5,2,key[5]);
// tempc=double(a[1]);
// dtostrf(tempc,5,2,jiaodu[5]);
  LCDA.DisplayString(1,4,(unsigned char*)jiaosudu[5],1);
//  LCDA.DisplayString(2,4,(unsigned char*)key[5],1);
// LCDA.DisplayString(3,4,(unsigned char*)jiaodu[5],1);
void serialEvent() {
  while (Serial1.available()) {
    //char inChar = (char)Serial.read(); Serial.print(inChar); //Output Original Data, use this code
    Re_buf[counter]=(unsigned char)Serial1.read();
    if(counter==0&&Re_buf[0]!=0x55) return;      //第0号数据不是帧头
    counter++;
    if(counter==11)             //接收到11个数据
       counter=0;               //重新赋值,准备下一帧数据的接收
       sign=1;
GMT+8, 2026-7-27 02:16 , Processed in 0.034768 second(s), 17 queries .
