查看: 16003|回复: 1
2个电器的远程控制(越多反应时间越长)
发表于 2016-12-25 23:17:22 | 显示全部楼层 |阅读模式
话不多说,可以借鉴的借鉴,这个可以实现2个电器的控制,状态变化时的最大反应时间为30s*2(两个电器嘛)
#include <SPI.h>
#include <Ethernet.h>
#include <Wire.h>
#include <math.h>
byte buff[2];
// for yeelink api
#define APIKEY         "xxxxxxxxxxxxxxxxxxxxxxx" // 此处替换为你自己的API KEY
#define DEVICEID1_kt_light       353506 // 客厅灯光的设备编号
#define SENSORID1_kt_light      398630 // 客厅灯光的传感器编号
#define DEVICEID2_cf_light       353512 // 厨房灯光的设备编号
#define SENSORID2_cf_light      398636 // 厨房灯光的传感器编号
long int DEVICEID[2]={DEVICEID1_kt_light,DEVICEID2_cf_light};
long int SENSORID[2]={SENSORID1_kt_light,SENSORID2_cf_light};
//String DEVICEID[]={"DEVICEID1_kt_light","DEVICEID2_cf_light"};
//String SENSORID[]={"SENSORID1_kt_light","SENSORID2_cf_light"};
short int b[11]={};//电器开关的标志
short int c[11]={22,23,24,25,32,28,33,30,31,26,27};//电器输出端的引脚,
char i=0;//i用于b[11],c[],DEVICEID[],SENSORID[]计数
// assign a MAC address for the ethernet controller.
byte mac[] = { 0x00, 0x1D, 0x72, 0x82, 0x35, 0x9D};
// initialize the library instance:
EthernetClient client ;
char server[] = "api.yeelink.net";   // name address for yeelink API
unsigned long lastConnectionTime = 0;          // last time you connected to the server, in milliseconds
boolean lastConnected = false;                 // state of the connection last time through the main loop
const unsigned long postingInterval = 3*1000; // delay between 2 datapoints, 30s
String returnValue = "";
boolean ResponseBegin = false;
  pinMode(22, OUTPUT);//客厅灯光
  pinMode(23, OUTPUT);//厨房灯光
  Wire.begin();
  // start serial port:
Serial.begin(57600);
  // start the Ethernet connection with DHCP:
  if (Ethernet.begin(mac) == 0)
    for(;;)
    Serial.println("Ethernet configuration OK");
  // if there's incoming data from the net connection.
  // send it out the serial port.  This is for debugging
  // purposes only:
  if (client.available())
    char c = client.read();
   // Serial.print(c);
      if (c == '{')
        ResponseBegin = true;
      else if (c == '}')
      if (ResponseBegin)
        returnValue += c;
  if (returnValue.length() !=0 && (ResponseBegin == false))
    Serial.println(returnValue);
    if (returnValue.charAt(returnValue.length() - 1) == '1')
      Serial.println("turn on the LED");
      digitalWrite(c[i], HIGH);
      else if(returnValue.charAt(returnValue.length() - 1) == '0')
      Serial.println("turn off the LED");
      digitalWrite(c[i], LOW);
     returnValue = "";
     i++;
     if(i>=2){i=0;}//不能超出要查询的范围
  // if there's no net connection, but there was one last time
  // through the loop, then stop the client:
  if (!client.connected() && lastConnected)
    Serial.println();
    client.stop();
  // if you're not connected, and ten seconds have passed since
  // your last connection, then connect again and send data:
  if(!client.connected() && (millis() - lastConnectionTime > postingInterval)) {
    // read sensor data, replace with your code
    //int sensorReading = readLightSensor();
    Serial.print("yeelink:");
    //get data from server
    getData();
  // store the state of the connection for next time through
  // the loop:
  lastConnected = client.connected();
// this method makes a HTTP connection to the server and get data back
void getData(void) {
  // if there's a successful connection:
  if (client.connect(server, 80)) {
    // send the HTTP GET request:
    client.print("GET /v1.0/device/");
    client.print(DEVICEID[i]);
    client.print("/sensor/");
    client.print(SENSORID[i]);
    client.print("/datapoints");
    client.println(" HTTP/1.1");
    client.println("Host: api.yeelink.net");
    client.print("Accept: *");
    client.print("/");
    client.println("*");
    client.print("U-ApiKey: ");
    client.println(APIKEY);
    client.println("Content-Length: 0");
    client.println("Connection: close");
    client.println();
    Serial.println("print get done.");
  else {
    // if you couldn't make a connection:
    Serial.println();
    client.stop();
   // note the time that the connection was made or attempted:
发表于 2016-12-25 23:33:06 | 显示全部楼层
还是上个图吧  貌似看不出效果。。。。
GMT+8, 2026-7-26 21:25 , Processed in 0.045719 second(s), 19 queries .
