设定了陀螺仪跟加速度计的精度,设定了数字高低通滤波器。
测试结果是只有FIFO数据溢出复位以后的第一行数据可信,其他的都乱跳……
如红框所示,分别对应Yaw(Z轴) Pitch(Y轴) Roll(X轴)
图片引自wikipedia.org
请教各位大神如何只提取第一行的数据?
下面是我的程序:
- // I2C device class (I2Cdev) demonstration Arduino sketch for MPU6050 class
- // 10/7/2011 by Jeff Rowberg <[url=mailto:[email protected]][email protected][/url]>
- // Updates should (hopefully) always be available at [url=https://github.com/jrowberg/i2cdevlib]https://github.com/jrowberg/i2cdevlib[/url]
- // Changelog:
- // 2011-10-07 - initial release
- I2Cdev device library code is placed under the MIT license
- Copyright (c) 2011 Jeff Rowberg
- Permission is hereby granted, free of charge, to any person obtaining a copy
- of this software and associated documentation files (the "Software"), to deal
- in the Software without restriction, including without limitation the rights
- to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
- copies of the Software, and to permit persons to whom the Software is
- furnished to do so, subject to the following conditions:
- The above copyright notice and this permission notice shall be included in
- all copies or substantial portions of the Software.
- THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
- IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
- FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
- AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
- LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
- OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
- THE SOFTWARE.
- // Arduino Wire library is required if I2Cdev I2CDEV_ARDUINO_WIRE implementation
- // is used in I2Cdev.h
- #include "Wire.h"
- // I2Cdev and MPU6050 must be installed as libraries, or else the .cpp/.h files
- // for both classes must be in the include path of your project
- #include "I2Cdev.h"
- #include "MPU6050_6Axis_MotionApps20.h"
- // class default I2C address is 0x68
- // specific I2C addresses may be passed as a parameter here
- // AD0 low = 0x68 (default for InvenSense evaluation board)
- // AD0 high = 0x69
- MPU6050 mpu;
- #define LED_PIN 13
- bool blinkState = false;
- bool dmpReady = false; // set true if DMP init was successful
- uint8_t mpuIntStatus; // holds actual interrupt status byte from MPU
- uint8_t devStatus; // return status after each device operation (0 = success, !0 = error)
- uint16_t packetSize; // expected DMP packet size (default is 42 bytes)
- uint16_t fifoCount; // count of all bytes currently in FIFO
- uint8_t fifoBuffer[64]; // FIFO storage buffer
- int16_t ax, ay, az;
- int16_t gx, gy, gz;
- int8_t offset_x, offset_y, offset_z;
- // orientation/motion vars
- Quaternion q; // [w, x, y, z] quaternion container
- VectorInt16 aa; // [x, y, z] accel sensor measurements
- VectorInt16 aaReal; // [x, y, z] gravity-free accel sensor measurements
- VectorInt16 aaWorld; // [x, y, z] world-frame accel sensor measurements
- VectorFloat gravity; // [x, y, z] gravity vector
- float euler[3]; // [psi, theta, phi] Euler angle container
- float ypr[3]; // [yaw, pitch, roll] yaw/pitch/roll container and gravity vector
- // === INTERRUPT DETECTION ROUTINE ===
- volatile bool mpuInterrupt = false; // indicates whether MPU interrupt pin has gone high
- void dmpDataReady() {
- mpuInterrupt = true;
- // === INITIAL SETUP ===
- void setup() {
- // join I2C bus (I2Cdev library doesn't do this automatically)
- Wire.begin();
- // initialize serial communication
- // (38400 chosen because it works as well at 8MHz as it does at 16MHz, but
- // it's really up to you depending on your project)
- Serial.begin(9600);
- while (!Serial); // wait for Leonardo enumeration, others continue immediately
- // NOTE: 8MHz or slower host processors, like the Teensy @ 3.3v or Ardunio
- // Pro Mini running at 3.3v, cannot handle this baud rate reliably due to
- // the baud timing being too misaligned with processor ticks. You must use
- // 38400 or slower in these cases, or use some kind of external separate
- // crystal solution for the UART timer.
- // initialize device
- Serial.println("Initializing I2C devices...");
- mpu.initialize();
- // verify connection
- Serial.println("Testing device connections...");
- Serial.println(mpu.testConnection() ? "MPU6050 connection successful" : "MPU6050 connection failed");
- //mpu.setXGyroOffset(6);mpu.setYGyroOffset(-2);
- //mpu.setZGyroOffset(0);
- /*Serial.print("Offset:\t");
- Serial.print(mpu.getXAccelOffset()); Serial.print("\t");
- Serial.print(mpu.getYAccelOffset()); Serial.print("\t");
- Serial.print(mpu.getZAccelOffset()); Serial.print("\t");
- Serial.print(mpu.getXGyroOffset()); Serial.print("\t");
- Serial.print(mpu.getYGyroOffset()); Serial.print("\t");
- Serial.println(mpu.getZGyroOffset());
- Serial.print("Gain:\t");
- Serial.print(mpu.getXFineGain()); Serial.print("\t");
- Serial.print(mpu.getYFineGain()); Serial.print("\t");
- Serial.println(mpu.getZFineGain());// Serial.print("\t");
- mpu.setFullScaleGyroRange(3);
- mpu.setFullScaleAccelRange(3);
- mpu.setDLPFMode(6);
- mpu.setDHPFMode(1);
- // load and configure the DMP
- Serial.println("Initializing DMP...");
- devStatus = mpu.dmpInitialize();
- // make sure it worked (returns 0 if so)
- if (devStatus == 0) {
- // turn on the DMP, now that it's ready
- Serial.println("Enabling DMP...");
- mpu.setDMPEnabled(true);
- // enable Arduino interrupt detection
- Serial.println("Enabling interrupt detection (Arduino external interrupt 0)...");
- attachInterrupt(0, dmpDataReady, RISING);
- mpuIntStatus = mpu.getIntStatus();
- // set our DMP Ready flag so the main loop() function knows it's okay to use it
- Serial.println("DMP ready! Waiting for first interrupt...");
- dmpReady = true;
- // get expected DMP packet size for later comparison
- packetSize = mpu.dmpGetFIFOPacketSize();
- } else {
- // ERROR!
- // 1 = initial memory load failed
- // 2 = DMP configuration updates failed
- // (if it's going to break, usually the code will be 1)
- Serial.print("DMP Initialization failed (code ");
- Serial.print(devStatus);
- Serial.println(")");
- // configure Arduino LED for
- pinMode(LED_PIN, OUTPUT);
- void loop() {
- // if programming failed, don't try to do anything
- if (!dmpReady) return;
- // wait for MPU interrupt or extra packet(s) available
- if (!mpuInterrupt && fifoCount < packetSize) return;
- // reset interrupt flag and get INT_STATUS byte
- mpuInterrupt = false;
- // get current FIFO count
- fifoCount = mpu.getFIFOCount();
- // check for overflow (this should never happen unless our code is too inefficient)
- if ((mpuIntStatus & 0x10) || fifoCount == 1024) {
- // reset so we can continue cleanly
- mpu.resetFIFO();
- Serial.println(F("FIFO overflow!"));
- // otherwise, check for DMP data ready interrupt (this should happen frequently)
- } else if (mpuIntStatus & 0x02) {
- // wait for correct available data length, should be a VERY short wait
- while (fifoCount < packetSize) fifoCount = mpu.getFIFOCount();
- // read a packet from FIFO
- mpu.getFIFOBytes(fifoBuffer, packetSize);
- // track FIFO count here in case there is > 1 packet available
- // (this lets us immediately read more without waiting for an interrupt)
- fifoCount -= packetSize;
- /*display Euler angles in degrees
- 通过欧拉角度显示偏航*/
- mpu.dmpGetQuaternion(&q, fifoBuffer);
- mpu.dmpGetGravity(&gravity, &q);
- mpu.dmpGetYawPitchRoll(ypr, &q, &gravity);
- Serial.print("ypr\t");
- Serial.print(ypr[0] * 180/M_PI);
- Serial.print("\t");
- Serial.print(ypr[1] * 180/M_PI);
- Serial.println(ypr[2] * 180/M_PI);
- // read raw accel/gyro measurements from device
- //mpu.getMotion6(&ax, &ay, &az, &gx, &gy, &gz);
- // these methods (and a few others) are also available
- //accelgyro.getAcceleration(&ax, &ay, &az);
- //accelgyro.getRotation(&gx, &gy, &gz);
- // display tab-separated accel/gyro x/y/z values
- //Serial.print("a/g:\t");
- /*Serial.print(ax); Serial.print(",");
- Serial.print(ay); Serial.print(",");
- Serial.print(az); Serial.print(",");
- Serial.print(gx); Serial.print(",");
- Serial.print(gy); Serial.print(",");
- Serial.println(gz);*/
- // blink LED to indicate activity
- blinkState = !blinkState;
- digitalWrite(LED_PIN, blinkState);
复制代码 |
