查看: 9858|回复: 3
pmw控制小灯加用在以太网控制板上就失效~求解
发表于 2013-1-19 02:31:29 | 显示全部楼层 |阅读模式
我单独用uno就能pmw控制成功。但是把这段代码复制进去远程控制小灯(yeelink的例程)里面,pmw就失效了~~搞不明白
补充:我试了所有的口。都不行。
不管我程序里面定义的是什么口,1,2,3,4,5,6,7,8,9,12都不会亮。10,11,13都亮。
Yeelink sensor client power switch example
#include <SPI.h>
#include <Ethernet.h>
#include <Wire.h>
#include <math.h>
byte buff[2];
// for yeelink api
#define APIKEY         "dfa7e3490189215d6a2feb11fc68e49e" // replace your yeelink api key here
#define DEVICEID       958 // replace your device ID
#define SENSORID       1237 // replace your sensor ID
// assign a MAC address for the ethernet controller.
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED};
// initialize the library instance:
EthernetClient client;
char server[] = "api.yeelink.net";   // name address for yeelink API
//IPAddress server(202,136,60,231);      // numeric IP for api.pachube.com
unsigned long lastConnectionTime = 0;          // last time you connected to the server, in milliseconds
boolean lastConnected = false;                 // state of the connection last time through the main loop
const unsigned long postingInterval = 3*1000; // delay between 2 datapoints, 30s
String returnValue = "";
boolean ResponseBegin = false;
  pinMode(11, OUTPUT);
  Wire.begin();
  // start serial port:
  Serial.begin(57600);
  // start the Ethernet connection with DHCP:
  if (Ethernet.begin(mac) == 0) {
    for(;;)
  else {
    Serial.println("Ethernet configuration OK");
  // if there's incoming data from the net connection.
  // send it out the serial port.  This is for debugging
  // purposes only:
  if (client.available()) {
    char c = client.read();
   // Serial.print(c);
      if (c == '{')
        ResponseBegin = true;
      else if (c == '}')
      if (ResponseBegin)
        returnValue += c;
  if (returnValue.length() !=0 && (ResponseBegin == false))
    Serial.println(returnValue);
    if (returnValue.charAt(returnValue.length() - 1) == '1') {
      Serial.println("turn on the LED");
       for (int a=0; a<=255;a++)                //循环语句,控制PWM亮度的增加
    analogWrite(11,a);
    delay(8);                             //当前亮度级别维持的时间,单位毫秒
    for (int a=255; a>=0;a--)             //循环语句,控制PWM亮度减小
    analogWrite(11,a);
    delay(8);                             //当前亮度的维持的时间,单位毫秒
  delay(800);
      else if(returnValue.charAt(returnValue.length() - 1) == '0') {
      Serial.println("turn off the LED");
      digitalWrite(7, LOW);
     returnValue = "";
  // if there's no net connection, but there was one last time
  // through the loop, then stop the client:
  if (!client.connected() && lastConnected) {
    Serial.println();
    client.stop();
  // if you're not connected, and ten seconds have passed since
  // your last connection, then connect again and send data:
  if(!client.connected() && (millis() - lastConnectionTime > postingInterval)) {
    // read sensor data, replace with your code
    //int sensorReading = readLightSensor();
    Serial.print("yeelink:");
    //get data from server
    getData();
  // store the state of the connection for next time through
  // the loop:
  lastConnected = client.connected();
// this method makes a HTTP connection to the server and get data back
void getData(void) {
  // if there's a successful connection:
  if (client.connect(server, 80)) {
    // send the HTTP GET request:
    client.print("GET /v1.0/device/");
    client.print(DEVICEID);
    client.print("/sensor/");
    client.print(SENSORID);
    client.print("/datapoints");
    client.println(" HTTP/1.1");
    client.println("Host: api.yeelink.net");
    client.print("Accept: *");
    client.print("/");
    client.println("*");
    client.print("U-ApiKey: ");
    client.println(APIKEY);
    client.println("Content-Length: 0");
    client.println("Connection: close");
    client.println();
    Serial.println("print get done.");
  else {
    // if you couldn't make a connection:
    Serial.println();
    client.stop();
   // note the time that the connection was made or attempted:
发表于 2013-1-19 14:27:53 | 显示全部楼层
你是不是用的11口啊?11口已经被eth占用。选择别的pwm口吧
 楼主| 发表于 2013-1-19 23:04:44 | 显示全部楼层
我试了所有的口。都不行。
发表于 2013-10-25 23:35:48 | 显示全部楼层
我也遇到过这个问题,我用的是w5100.发现10口无反应类似死机似的 11口调速不起作用,一直不知道什么原因,看了您的回答,我大概猜到原因了,那10口也是占用问题吗,大神?
GMT+8, 2026-7-28 04:24 , Processed in 0.040052 second(s), 19 queries .
