查看: 22206|回复: 3
基于应用的简单框架(sht,PPD42ns,ad,以太网),后续陆续补充传感器
发表于 2013-2-9 12:29:54 | 显示全部楼层 |阅读模式
说明:代码由@grissiom 提供
代码已经更新到 https://github.com/lewei50/leweiclient  可能与这里的不一致,以github上面为准
鉴于现在的所谓的物联网应用需要了解的知识相对复杂,一般爱好者不好上手,产生了做一个基于应用的简单框架的想法。利用arduino的硬件平台,把所有的传感器的读取,以太网数据的上传都进行了封装。
使用方法
1 导入库
实现代码如下:包含sht,AD PPD,后续会陆续增加传感器以及把反向控制加入到框架中
  1. #include <LeweiClient.h>
  2. #include <SPI.h>
  3. #include <Ethernet.h>
  4. #include <Wire.h> //BH1750 IIC Mode
  5. uint8_t mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED};
  6. #define LW_USERKEY "xxxxxxxxxxxxxxxxxxxxxxxx111"
  7. #define LW_GATEWAY "01"
  8. //delay between updates
  9. #define POST_INTERVAL (10*1000)
  10. LeWeiClient *lwc;
  11. const unsigned long postingInterval = 10*1000;
  12. LeWeiAnalogSensor the_UVSensor("UV", "UV_sensor", "UVsensor", 0);
  13. //LeWeiAnalogSensor the_MoistureSensor("MS", "Moisture_sensor", "MoistureSensor", 1);
  14. DHT11 the_dht11(2);
  15. LeWeiDHTHumSensor the_hum("HM", "Hum_sensor", "HumSensor", &the_dht11);
  16. LeWeiDHTTemprSensor the_tempr("TEMP", "Temp_sensor", "TempSensor", &the_dht11);
  17. LeWeiPPDSensor the_PM1Sensor("PM1", "PM_sensor", "PM1sensor", 8);
  18. LeWeiBH17xxSensor the_bh1750("BH", "light_sensor", "BH1750", 0x23);
  19. void setup() {
  20.     Serial.begin(9600);
  21.     if (Ethernet.begin(mac) == 0)
  22.     {
  23.         Serial.print("Failed to configure Ethernet using DHCP\r\n");
  24.     }
  25.     else
  26.     {
  27.         Serial.print("Ethernet configuration OK\r\n");
  28.     }
  29.     the_dht11.init();
  30.     the_bh1750.init();
  31.     // hope no exception here
  32.     lwc = new LeWeiClient(LW_USERKEY, LW_GATEWAY);
  33.     lwc->registerSensor(the_PM1Sensor);
  34.     lwc->registerSensor(the_UVSensor);
  35.     //lwc->registerSensor(the_MoistureSensor);
  36.     lwc->registerSensor(the_hum);
  37.     lwc->registerSensor(the_tempr);
  38.     lwc->registerSensor(the_bh1750);
  39. }
  40. void loop() {
  41.     if (lwc) {
  42.         Serial.print("*** start data collection\r\n");
  43.         lwc->scanDevices();
  44.         Serial.print("*** start data send\r\n");
  45.         lwc->send();
  46. /*
  47. *        Serial.print("*** start log send\r\n");
  48. *        lwc->sendLog("I'm alive.");
  49. *
  50. */
  51.         delay(POST_INTERVAL);
  52.     }
  53. }
发表于 2013-2-10 15:47:01 | 显示全部楼层
代码封装的很好,结构简介 逻辑清楚 很好的例子 多谢楼主
发表于 2013-2-10 21:30:56 | 显示全部楼层
谢谢楼主,很需要这个!
发表于 2015-12-19 11:24:59 | 显示全部楼层
不错的代码,写的很好
GMT+8, 2026-6-15 10:39 , Processed in 0.073932 second(s), 22 queries .
