查看: 8369|回复: 8
iphone arduino 控制LED灯光
发表于 2013-2-15 15:03:58 | 显示全部楼层 |阅读模式
最近刚做的用iphone+arduino 来控制LED灯光!!!
视频地址:
http://v.ku6.com/show/EOnPfr4_a4eKDp5yMRbLqw...html?from=my
发表于 2013-2-15 15:47:03 | 显示全部楼层
ios端的软件是怎么写的呢?
 楼主| 发表于 2013-2-15 16:20:35 | 显示全部楼层
恺之 发表于 2013-2-15 15:47
ios端的软件是怎么写的呢?
xcode4.6 + iphone6.1开发
代码:
1. 串口处理文件: serial.c
//  Iphone Serial I/O demo.  see DevDot.wikispaces.com for more info
//  By Collin Meyer (TheRain)
//  12-09-2007 revision 1
//  Feel free to reuse this code.
#include <stdio.h>   /* Standard input/output definitions */
#include <string.h>  /* String function definitions */
#include <unistd.h>  /* UNIX standard function definitions */
#include <fcntl.h>   /* File control definitions */
#include <errno.h>   /* Error number definitions */
#include <termios.h> /* POSIX terminal control definitions */
static struct termios gOriginalTTYAttrs;
static int OpenSerialPort(unsigned long speed)
    int        fileDescriptor = -1;
    int        handshake;
    struct termios  options;
    // Open the serial port read/write, with no controlling terminal, and don't wait for a connection.
    // The O_NONBLOCK flag also causes subsequent I/O on the device to be non-blocking.
    // See open(2) ("man 2 open") for details.
    fileDescriptor = open("/dev/tty.iap", O_RDWR | O_NOCTTY | O_NONBLOCK);
    if (fileDescriptor == -1)
        printf("Error opening serial port %s - %s(%d).\n",
               "/dev/tty.iap", strerror(errno), errno);
        goto error;
    // Note that open() follows POSIX semantics: multiple open() calls to the same file will succeed
    // unless the TIOCEXCL ioctl is issued. This will prevent additional opens except by root-owned
    // processes.
    // See tty(4) ("man 4 tty") and ioctl(2) ("man 2 ioctl") for details.
    if (ioctl(fileDescriptor, TIOCEXCL) == -1)
        printf("Error setting TIOCEXCL on %s - %s(%d).\n",
        goto error;
    //使用非阻塞方式
   /* if( fcntl(fileDescriptor, F_SETFL, FNDELAY) == -1)
        printf("Error clearing O_NONBLOCK %s - %s(%d).\n",
        goto error;
    // Now that the device is open, clear the O_NONBLOCK flag so subsequent I/O will block.
    // See fcntl(2) ("man 2 fcntl") for details.
    // 阻塞方式
    if (fcntl(fileDescriptor, F_SETFL, 0) == -1)
        goto error;
    // Get the current options and save them so we can restore the default settings later.
    if (tcgetattr(fileDescriptor, &gOriginalTTYAttrs) == -1)
        printf("Error getting tty attributes %s - %s(%d).\n",
        goto error;
    // The serial port attributes such as timeouts and baud rate are set by modifying the termios
    // structure and then calling tcsetattr() to cause the changes to take effect. Note that the
    // changes will not become effective without the tcsetattr() call.
    // See tcsetattr(4) ("man 4 tcsetattr") for details.
    options = gOriginalTTYAttrs;
    // Print the current input and output baud rates.
    printf("Current input baud rate is %d\n", (int) cfgetispeed(&options));
    printf("Current output baud rate is %d\n", (int) cfgetospeed(&options));
    // Set raw input (non-canonical) mode, with reads blocking until either a single character
    // has been received or a one second timeout expires.
    // See tcsetattr(4) ("man 4 tcsetattr") and termios(4) ("man 4 termios") for details.
    cfmakeraw(&options);
    options.c_cc[VMIN] = 1;
    options.c_cc[VTIME] = 10;
    // The baud rate, word length, and handshake options can be set as follows:
    cfsetspeed(&options, speed);    // Set 19200 baud
    options.c_cflag |= (CS8);  // RTS flow control of input
    printf("Input baud rate changed to %d\n", (int) cfgetispeed(&options));
    printf("Output baud rate changed to %d\n", (int) cfgetospeed(&options));
    // Cause the new options to take effect immediately.
    if (tcsetattr(fileDescriptor, TCSANOW, &options) == -1)
        printf("Error setting tty attributes %s - %s(%d).\n",
        goto error;
    // Success
    return fileDescriptor;
    // Failure "/dev/tty.iap"
error:
    if (fileDescriptor != -1)
        close(fileDescriptor);
    return -1;
//int main(int args, char *argv[])
//        int fd;
//        char somechar[8];
//        fd=OpenSerialPort(); // Open tty.iap with no hardware control, 8 bit, BLOCKING and at 19200 baud
//        if(fd>-1)
//                write(fd,"*",1); // Write handshaking message over serial
//                // After this, our device or our PC program should be strobing serial ground to gain access to the Iphone Serial Line
//                read(fd,&somechar[0],1); // Read 1 byte  over serial.  This will block (wait) untill the byte has been received
//                if(somechar[0]=='*') // Check if this byte is a "handshaking" message
//                        printf("Serial connection established!\n"); // If it is, we have established a connection to the device and can freely read/write over serial!
//                        while(1) // Do this forever or untill someone presses CTRL+C
//                                read(fd,&somechar[0],1);  // Read a character over serial!
//                                putchar(somechar[0]); // Write the character to the Terminal!!
//        return 0;
2.在xcode中包装一下上面的serial.c文件,取名SerialIO ,并使用serial.c中的OpenSerialPort、write、read,在控制LED这个实验中不需要使用read函数,因为iphone只发出控制指令,不需要read。
#import "SerialIO.h"
#import "serial.c"
@implementation SerialIO
+(int)open:(unsigned long)speed{
    if(serialPort == -1){
        serialPort = OpenSerialPort(speed);
        return serialPort;
        return serialPort;
+(long)write:(NSString *)msg{
    char *s = [msg cStringUsingEncoding:NSASCIIStringEncoding];
        return 0;
    int length =  [msg length];
   return write(serialPort, s, length);
+(long)read:(char [])rec length:(int)len{
  //  int bytes_left;
    int bytes_read;
    //char *ptr;
   // bytes_left = len;
    //while (bytes_left > 0) {
        bytes_read = read(serialPort, rec, len);
//        if(bytes_read < 0 ){
//        }else if(bytes_read==0){
//            break;
//        bytes_left-=bytes_read;
   //     ptr+=bytes_read;
  //  rec = ptr;
  //   return  (len - bytes_left);
    return bytes_read;
@end
3.最终调用(滑动事件): blueChange、redChange、greenChange
//  ViewController.m
//  SerialControl
//  Created by Panda on 13-2-8.
//  Copyright (c) 2013年 Panda. All rights reserved.
#import "ViewController.h"
@interface ViewController ()
@end
@implementation ViewController
- (void)viewDidLoad
    [super viewDidLoad];
        // Do any additional setup after loading the view, typically from a nib.
- (void)didReceiveMemoryWarning
    [super didReceiveMemoryWarning];
    // Dispose of any resources that can be recreated.
- (IBAction)blueChange:(id)sender {
    int a;
    a = (int)[_blueSilder value];
    a = 255-a;
    NSString *s=[[NSString alloc] initWithFormat:@"%d",a];
    [SerialIO open:9600];
    NSString *sendStr = [[@"db" stringByAppendingString:s] stringByAppendingString:@"#"];
    long count = [SerialIO write:sendStr];
- (IBAction)redChange:(id)sender {
    int a;
    a = (int)[_redSlider value];
    a = 255-a;
    NSString *sendStr = [[@"dr" stringByAppendingString:s] stringByAppendingString:@"#"];
- (IBAction)greenChange:(id)sender {
    int a;
    a = (int)[_greenSlider value];
    a = 255-a;
    NSString *sendStr = [[@"dg" stringByAppendingString:s] stringByAppendingString:@"#"];
@end
发表于 2013-2-16 08:59:14 | 显示全部楼层
ios 串口 好贴!!!
发表于 2013-2-17 11:33:21 | 显示全部楼层
强烈求更详细的的app编写资料
 楼主| 发表于 2013-2-17 22:40:39 | 显示全部楼层
Ansifa 发表于 2013-2-17 11:33
强烈求更详细的的app编写资料
我整理一下,这两天把接口制作及代码放上来。
发表于 2013-2-18 00:26:46 | 显示全部楼层
欧耶,非常期待。。。
 楼主| 发表于 2013-2-19 09:45:43 | 显示全部楼层
Ansifa 发表于 2013-2-18 00:26
欧耶,非常期待。。。
已经写了,也不知道够不够详细,有问题消息我
http://www.geek-workshop.com/thread-3429-1-1.html
发表于 2013-6-28 09:40:38 | 显示全部楼层
安卓手机软件有吗
GMT+8, 2026-7-27 05:59 , Processed in 0.036731 second(s), 21 queries .
