查看: 27021|回复: 4
arduino 无法控制pca9685输出pwm波驱动舵机,请高手看看哪个步骤出了问题?
发表于 2018-4-9 17:18:10 | 显示全部楼层 |阅读模式
舵机一点反应都没有
代码为:
#include <Wire.h>
#include "Adafruit_PWMServoDriver.h"
// called this way, it uses the default address 0x40
Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver(0x40);
// our servo # counter
uint8_t servonum = 0;
  Serial.println("16 channel Servo test!");
  pwm.begin();
  pwm.setPWMFreq(50);  // Analog servos run at ~60 Hz updates
// you can use this function if you'd like to set the pulse length in seconds
// e.g. setServoPulse(0, 0.001) is a ~1 millisecond pulse width. its not precise!
void setServoPulse(uint8_t n, double pulse) {
  double pulselength;
  pulselength = 1000000;   // 1,000,000 us per second
  pulselength /= 50;   // 60 Hz
  Serial.print(pulselength); Serial.println(" us per period");
  pulselength /= 4096;  // 12 bits of resolution
  Serial.print(pulselength); Serial.println(" us per bit");
  pulse *= 1000;
  pulse /= pulselength;
  Serial.println(pulse);
  pwm.setPWM(n, 0, pulse);
void writeServo(uint8_t n,uint8_t angle){
  double pulse;
  pulse=0.5+angle/90.0;
  setServoPulse(n,pulse);
    writeServo(0,90);
    writeServo(2,80);
发表于 2018-4-9 22:31:51 | 显示全部楼层
mega2560的I2C不在A4,A5
 楼主| 发表于 2018-4-11 14:38:34 | 显示全部楼层
通幽境 发表于 2018-4-9 22:31
mega2560的I2C不在A4,A5
谢谢点播,试了试21 20 也不行呢,我的代码有问题吗
发表于 2018-4-12 16:19:15 | 显示全部楼层
上拉了吗?
发表于 2018-4-15 11:07:38 | 显示全部楼层
围观特来学习
GMT+8, 2026-7-26 17:34 , Processed in 0.144988 second(s), 20 queries .
