查看: 18627|回复: 3
【求大神】Arduino控制两个舵机反向转动问题
发表于 2018-4-9 23:51:36 | 显示全部楼层 |阅读模式
如题,以下是我自己写的控制两个舵机转动的程序,但是这样运行的结果是两个舵机同步转动, 我想实现两个舵机反向转动,如何修改,求大神帮忙,跪谢!
#include <Servo.h>
Servo myservo1;  //Create a steering control object
Servo myservo2;  //Create a steering control object
int pos = 0;    // The variable is used to store the angle position of the rudder
  myservo1.attach(9);  // The rudder is controlled by the Arduino ninth pin
  myservo2.attach(10);  // The rudder is controlled by the Arduino ninth pin
  for(pos = 0; pos < 180; pos += 1)   // From 0 to 180 degrees
  {                                                     // Every step of step
     myservo1.write(pos);        // Steering angle of the steering gear
     myservo2.write(pos);        //
    delay(15);                       // Wait for 15ms to get the steering gear to the designated position
  for(pos = 180; pos>=1; pos -= 1)   //From 180 to 0 degrees
 楼主| 发表于 2018-4-10 00:20:09 | 显示全部楼层
求大神帮忙啊~!!!
发表于 2018-4-10 06:02:16 | 显示全部楼层
     myservo1.write(pos);        // Steering angle of the steering gear             //
发表于 2018-4-11 10:58:03 | 显示全部楼层
#include <Servo.h>
  myservo1.write(0);        // Steering angle of the steering gear
  myservo2.write(180);
     myservo2.write(180-pos);        //
GMT+8, 2026-7-25 04:10 , Processed in 0.034376 second(s), 20 queries .
