查看: 20972|回复: 1
要做一个垃圾桶结果程序出问题了帮忙看下丢啦啥字母
发表于 2019-2-21 21:16:24 | 显示全部楼层 |阅读模式
#include ( Servo.h )
#define  trigpin 3
#define  echopin 2
Servo  servo;
int sound = 250;
void setup( ) {
  serial .begin (9600);
  pinmode(trigpin . output);
  pinmode(trigpin . input);
  servo.attach(4);
void loop( ) {
  Long duration, distance;
  digitalWrite(trigpin, LOW);
  delayMicroseconds(2);
  digitalWrite(trigpin, HIGH);
  delayMicroseconds(10);
  duration = pulseln (echopin, HIGH);
  distance = (duration/2)/29.1;
  if  (distance < 5) {
    Serial.println("the diatance is less than 5");
    servo . write ( 90 ) ;
  else{
    servo.write(0);
  if ( distance > 60  distance <=0){
    Serial . println ( " The distance is more than 60 ") ;
  Else{
    Serial.print(distance);
    Serial . println ( "cm " ) ;
  delay(500);
发表于 2019-2-22 17:03:36 | 显示全部楼层
  1. #include "Servo.h"
  2. #define  trigpin 3
  3. #define  echopin 2
  4. Servo  servo;
  5. int sound = 250;
  6. void setup( ) {
  7.   Serial .begin (9600);
  8.   pinMode(trigpin,OUTPUT);
  9.   pinMode(trigpin,INPUT);
  10.   servo.attach(4);
  11. }
  12. void loop( ) {
  13.   long duration, distance;
  14.   digitalWrite(trigpin, LOW);
  15.   delayMicroseconds(2);
  16.   digitalWrite(trigpin, HIGH);
  17.   delayMicroseconds(10);
  18.   digitalWrite(trigpin, LOW);
  19.   duration = pulseIn(echopin, HIGH);
  20.   distance = (duration/2)/29.1;
  21.   if  (distance < 5) {
  22.     Serial.println("the diatance is less than 5");
  23.     servo . write ( 90 ) ;
  24.   }
  25.   else{
  26.     servo.write(0);
  27.   }
  28.   if ( distance > 60){
  29.     Serial . println ( " The distance is more than 60 ") ;
  30.   }
  31.   else{
  32.     Serial.print(distance);
  33.     Serial . println ( "cm " ) ;
  34.   }
  35.   delay(500);
  36. }
不知道你这写得对不对。但是语法错误不少。
GMT+8, 2026-7-25 15:45 , Processed in 0.035740 second(s), 20 queries .
