查看: 19632|回复: 0
8F328-U Signal Reverser
发表于 2019-4-18 16:14:41 | 显示全部楼层 |阅读模式
  1. /*
  2.    Signal Reverser (Use Interrupt pin2)
  3.    Date: 20190418
  4.    Rev: 01
  5.    By: Eddie
  6. */
  7. #define SCLK 2    // Signal input pin
  8. #define REVOUT 13 // Reversed output waveform as pin2 SCLK input
  9. volatile unsigned long pulseWidthStart, pulseWidthEnd, pulseWidth, cycleStart, cycleTime;
  10. void setup() {
  11.   pinMode(SCLK, INPUT_PULLUP);
  12.   pinMode(REVOUT, OUTPUT);
  13.   digitalWrite(REVOUT, LOW);
  14.   attachInterrupt(digitalPinToInterrupt(SCLK), ISRrisingEdge, RISING);
  15. //  Serial.begin(115200);
  16. }
  17. void loop() {
  18. }
  19. void reverseSignal() {
  20.   unsigned long pulseTime = 1.31*(3000 - pulseWidth); //reverse signal
  21.   //1.31 is used to compensate the delayMicroseconds() error of LGT8F328P chip
  22. //  Serial.println(pulseTime);
  23.   digitalWrite(REVOUT, HIGH);
  24.   delayMicroseconds(pulseTime);
  25.   digitalWrite(REVOUT, LOW);
  26. }
  27. void ISRrisingEdge() {
  28.   pulseWidthStart = micros();
  29.   pulseWidth = 0;
  30.   cycleTime = pulseWidthStart - cycleStart;
  31.   //  Serial.println(cycleTime);
  32.   cycleStart = pulseWidthStart;
  33.   attachInterrupt(digitalPinToInterrupt(SCLK), ISRfallingEdge, FALLING);
  34. }
  35. void ISRfallingEdge() {
  36.   pulseWidthEnd = micros();
  37.   pulseWidth = pulseWidthEnd - pulseWidthStart;
  38. //  Serial.println(pulseWidth);
  39.   reverseSignal();
  40.   attachInterrupt(digitalPinToInterrupt(SCLK), ISRrisingEdge, RISING);
  41. }
GMT+8, 2026-7-23 06:48 , Processed in 0.036221 second(s), 17 queries .
