查看: 9879|回复: 0
多个DHT11的读书数问题
发表于 2013-4-9 00:15:40 | 显示全部楼层 |阅读模式
求教:我打算用两个DHT11同时测温,程序如下,但始终显示同一个传感器读数,请问怎么改程序会显示两个DHT11的读数,非常感谢您的回答!
#include <dht11.h>
#include<LiquidCrystal.h>
#define DHT11_PIN 1
#define DHT11_PIN 2
byte read_dht11_dat()
        byte i = 0;
        byte result=0;
        for(i=0; i< 8; i++){
             while(!(PINC & _BV(DHT11_PIN)));  // wait for 50us
             delayMicroseconds(30);
             if(PINC & _BV(DHT11_PIN))
             result |=(1<<(7-i));
             while((PINC & _BV(DHT11_PIN)));  // wait '1' finish
        return result;
LiquidCrystal lcd(8,9,4,5,6,7);
  lcd.begin(16,2);
   DDRC |= _BV(DHT11_PIN);
   PORTC |= _BV(DHT11_PIN);
dht11 DHT11;
        byte dht11_dat[5];
        byte dht11_in;
        byte i;
        // start condition
        // 1. pull-down i/o pin from 18ms
        PORTC &= ~_BV(DHT11_PIN);
        delay(18);
        delayMicroseconds(40);
        DDRC &= ~_BV(DHT11_PIN);
        dht11_in = PINC & _BV(DHT11_PIN);
        if(dht11_in){
                Serial.println("dht11 start condition 1 not met");
                return;
        delayMicroseconds(80);
        if(!dht11_in){
                Serial.println("dht11 start condition 2 not met");
                return;
        // now ready for data reception
        for (i=0; i<5; i++)
                dht11_dat[i] = read_dht11_dat();
        byte dht11_check_sum = dht11_dat[0]+dht11_dat[1]+dht11_dat[2]+dht11_dat[3];
        // check check_sum
        if(dht11_dat[4]!= dht11_check_sum)
                Serial.println("DHT11 checksum error");
     lcd.setCursor(0,0);
     lcd.print("H");
     lcd.print(":");
     lcd.print(dht11_dat[0], DEC);
     lcd.print(".");
     lcd.print(dht11_dat[1], DEC);
     lcd.print("%");
     lcd.setCursor(0,1);
      lcd.print("T");
     lcd.print(":");
     lcd.print(dht11_dat[2], DEC);
     lcd.print(".");
     lcd.print(dht11_dat[3], DEC);
     lcd.print("C ");
     lcd.setCursor(9,0);
     lcd.print(".");
     lcd.print("%");
     lcd.setCursor(9,1);
     lcd.print(".");
     lcd.print("C");
    delay(1000);
GMT+8, 2026-7-25 01:52 , Processed in 0.032451 second(s), 18 queries .
