查看: 22159|回复: 9
Yeelink应用之微博点阵提醒器[ENC28J60+Arduino+Matrix LED]
发表于 2013-4-10 15:36:50 | 显示全部楼层 |阅读模式
奋斗了两晚上,最终在张老师的帮助下实现了微博提醒器的原型。
功能如下:
1. 自动获取IP
2. 获得微博状态并显示在点阵LED上
电路连接如图
ENC28J60与Arduino接线参考资料:arduino学习笔记26 - ENC28J60以太网模块实验
http://www.geek-workshop.com/thread-200-1-1.html
点阵电路的教程:http://www.geek-workshop.com/thread-2570-1-1.html
点阵动画的教程:http://www.geek-workshop.com/thread-2726-1-1.html
Yeelink配置图
参考资料:张老师写的 enc28j60+yeelink利用browseUrl()函数l获取开关状态
http://www.geek-workshop.com/thread-2034-1-1.html
Arduino主程序代码
[pre lang="arduino" line="1" file="BOXZ_Matrix_Eye02e.ino"]//**************************************************************//
//  BOXZ Matrix Eyes(Matrix 8x8 LED)
//  For 74HC595 x2 (without ULN2803)
//  creat by Leo 2012.11.25(http://weibo.com/leolite)
//  the drive is referenced from http://www.instructables.com/id/LED-Dot-Matrix-Display-1/
//  the animation is referenced from http://www.bleq.nl/arduino/
//**********************Handbook**********************************
//How to use this?
//Just use the software named "ArduinoFrameAnimator" to export the "animation.h" file.
//Then Copy to this Tab"animation.h" and Upload.
//The main sketch don't need to change anything! The animation will loop playback itself
//Only if you want to add some action in loop(). Have fun!
/*_
_____________
|1.2.3.4.5    |
|6.7.8.9.10   |
______________
GND:1,6
5V:2,7
latchPin:3,8
clockPin:4,9
datain:5
dataout:10
#include <TimerOne.h>
#include <EtherCard.h>
#include "animation.h"
//Pin connected to ST_CP of 74HC595(Pin 12)
int latchPin = 4;
//Pin connected to SH_CP of 74HC595(Pin 11)
int clockPin = 5;
////Pin connected to DS of 74HC595(Pin 14)
int dataPin = 6;
// A number indicating when to advance to the next frame
unsigned long nextImage = 0;
// A counter to know what frame we're showing
int animationIndex = 0;
// 8x8 Point temporary array
byte brightnesses[64];
// Matrix image frame for 8x8 LED
int M[8];
#define REQUEST_RATE 5000 // milliseconds
// ethernet interface mac address
static byte mymac[] = {
  0x74,0x69,0x69,0x2D,0x30,0x31 };
// remote website name
char website[] PROGMEM = "api.yeelink.net";
char urlBuf[] PROGMEM = "/v1.0/device/xxx/sensor/xxx/";
char apiKey[] PROGMEM = "U-ApiKey: xxxxx";
byte Ethernet::buffer[500];   // a very small tcp/ip buffer is enough here
static long timer;
String switchStatus;
int switchint;
// called when the client request is complete
static void my_result_cb (byte status, word off, word len) {
  String reply=(const char*)Ethernet::buffer + off;
  switchStatus = reply.substring(reply.length()-2,reply.length()-1);
  //  Serial.println(reply);
  Serial.print("<<< reply ");
  Serial.print(millis() - timer);
  Serial.println(" ms");
  Serial.print("Switch Status:");
  Serial.println(switchStatus);
  Serial.println();
  //set pins to output so you can control the shift register
  pinMode(latchPin, OUTPUT);
  pinMode(clockPin, OUTPUT);
  pinMode(dataPin, OUTPUT);
  Serial.begin(57600);
  Serial.println("DHCP Demo");
  if (!ether.begin(sizeof Ethernet::buffer, mymac, 10))
    Serial.println( "Failed to access Ethernet controller");
    Serial.println("Ethernet controller initialized");
  if (!ether.dhcpSetup())
    Serial.println("Failed to get configuration from DHCP");
    Serial.println("DHCP configuration done");
  ether.printIp("IP Address:\t", ether.myip);
  ether.printIp("Netmask:\t", ether.mymask);
  ether.printIp("Gateway:\t", ether.gwip);
  ether.printIp("DNS:\t", ether.dnsip);
  timer = - REQUEST_RATE; // start timing out right away
  ether.packetLoop(ether.packetReceive());
  if (millis() > timer + REQUEST_RATE) {
    timer = millis();
    if (!ether.dnsLookup(website))
      Serial.println("DNS failed");
    ether.printIp("Server: ", ether.hisip);
    Serial.println("\n>>> REQ");
    ether.browseUrl(urlBuf, "datapoints", website,apiKey, my_result_cb);
  if(switchStatus.charAt(switchStatus.length() - 1) =='1'){
    if(animationIndex >= animationFrames)
      //restart animation index
      animationIndex = 0;
    else{
      //load Delay time for Image
      nextImage = animationDelays[animationIndex];
      //load image(converted)
      for(int m=0; m<5; m++) {
        for(int i=0; i<64; i++) {
          brightnesses = (animation04[animationIndex][i/4] >> (i%4*2)) & B00000001;
          M[i/8] |= (brightnesses << (i%8)) ;
      //Update Image
      screenUpdate(nextImage);
      animationIndex ++;
      //clear M[]
      for(int i=0; i<(8); ++i) {
        M=0;
  if(switchStatus.charAt(switchStatus.length() - 1) =='0'){
      animationIndex = 0;
    else{
          brightnesses = (animation00[animationIndex][i/4] >> (i%4*2)) & B00000001;
      //Update Image
      animationIndex ++;
      //clear M[]
        M=0;
void screenUpdate(unsigned long frametime)
{ // function to display image
    unsigned long startime=millis();
  while(millis()-startime<frametime)
    byte row = B10000000; // row 1
    for (byte k = 0; k < 8; k++)
      digitalWrite(latchPin, LOW); // open latch ready to receive data
      shiftIt(~row); // row binary number
      shiftIt(M[k]); // LED array (inverted)
      // Close the latch, sending the data in the registers out to the matrix
      digitalWrite(latchPin, HIGH);
      row = row>> 1; // bitshift right
void shiftIt(byte dataOut) {
  // Shift out 8 bits LSB first, on rising edge of clock
  boolean pinState;
  //clear shift register read for sending data
  digitalWrite(dataPin, LOW);
  // for each bit in dataOut send out a bit
  for (int i=0; i<8; i++) {
    //set clockPin to LOW prior to sending bit
    digitalWrite(clockPin, LOW);
    // if the value of DataOut and (logical AND) a bitmask
    // are true, set pinState to 1 (HIGH)
    if ( dataOut & (1<<i) ) {
      pinState = HIGH;
    else {
      pinState = LOW;
    //sets dataPin to HIGH or LOW depending on pinState
    digitalWrite(dataPin, pinState);
    //send bit out on rising edge of clock
    digitalWrite(clockPin, HIGH);
  digitalWrite(clockPin, LOW); //stop shifting
[/code]
Arduino代码(包含点阵动画程序)
发表于 2013-4-10 15:44:27 | 显示全部楼层
cool.字数补丁
发表于 2013-4-10 16:12:56 | 显示全部楼层
我也做了一个微博语音加呼吸灯提醒的,你这个触发后有没有加上归零?(要不开关一直是开)
 楼主| 发表于 2013-4-10 17:08:56 | 显示全部楼层
额,忘记加了。 你也是用Yeelink做的?响应快么?
发表于 2013-4-10 18:22:52 | 显示全部楼层
16*16能用595驱动不
发表于 2013-4-10 18:55:14 | 显示全部楼层
RE: Yeelink应用之微博点阵提醒器
恩,是的,yeelink是30s抓取一次,肯定快不起来
发表于 2013-9-18 16:54:10 | 显示全部楼层
你这是使用http协议,循环取数据,速度当然不快。  不知您找到解决办法了吗?
 楼主| 发表于 2013-9-18 21:29:53 | 显示全部楼层
我们解决不了哦,是服务器的配置问题
发表于 2013-9-22 16:03:55 | 显示全部楼层
幻生幻灭 发表于 2013-9-18 21:29
我们解决不了哦,是服务器的配置问题
您使用enc28j60模块 做过跨网段的反向控制的实验吗?
arduino连接到路由器上,可以访问外网地址,但是不知外网如何访问arduino,需要在路由器里面为 实验ip 设置nat端口映射或者dmz主机吗?
发表于 2015-4-20 17:57:09 | 显示全部楼层
谢谢分享学习一下
GMT+8, 2026-6-20 04:09 , Processed in 0.037938 second(s), 24 queries .
