查看: 6070|回复: 0
有關SerialEvent的問題?
发表于 2013-4-19 19:26:48 | 显示全部楼层 |阅读模式
這個網頁 http://arduino.cc/en/Tutorial/SerialEvent
依照下面的範例做, 在Serial Monitor內隨意輸入一些文字, 為什麼沒有任何顯示?
String inputString = "";         // a string to hold incoming data
boolean stringComplete = false;  // whether the string is complete
  // initialize serial:
  // reserve 200 bytes for the inputString:
  inputString.reserve(200);
  // print the string when a newline arrives:
  if (stringComplete) {
    Serial.println(inputString);
    // clear the string:
    inputString = "";
  SerialEvent occurs whenever a new data comes in the
hardware serial RX.  This routine is run between each
time loop() runs, so using delay inside loop can delay
response.  Multiple bytes of data may be available.
void serialEvent() {
  while (Serial.available()) {
    // get the new byte:
    char inChar = (char)Serial.read();
    // add it to the inputString:
    inputString += inChar;
    // if the incoming character is a newline, set a flag
    // so the main loop can do something about it:
    if (inChar == '\n') {
      stringComplete = true;
GMT+8, 2026-7-27 02:34 , Processed in 0.039505 second(s), 17 queries .
