查看: 9823|回复: 1
serial chart 的问题
发表于 2013-5-1 08:44:56 | 显示全部楼层 |阅读模式
data区显示Testing device connections...
MPU6050 connection successful
没有波形,没数据
但是用arduino的串口工具有数据
不明白问题在哪里
配置文件是[_setup_]
port=COM3
baudrate=38400
width=1200
height=600
background_color = white
grid_h_origin = 200
grid_h_step = 10
grid_h_color = #EEE
grid_h_origin_color = #CCC
grid_v_origin = 200
grid_v_step = 10
grid_v_color = #EEE
grid_v_origin_color = transparent
[_default_]
min=-100
max=100
[ax]
color = red
[ay]
color = orange
[az]
color = black
6050程序是
// Arduino Wire library is required if I2Cdev I2CDEV_ARDUINO_WIRE implementation
// is used in I2Cdev.h
#include "Wire.h"
// I2Cdev and MPU6050 must be installed as libraries, or else the .cpp/.h files
// for both classes must be in the include path of your project
#include "I2Cdev.h"
#include "MPU6050.h"
// class default I2C address is 0x68
// specific I2C addresses may be passed as a parameter here
// AD0 low = 0x68 (default for InvenSense evaluation board)
// AD0 high = 0x69
MPU6050 accelgyro;
int16_t ax, ay, az;
int16_t gx, gy, gz;
#define LED_PIN 13
bool blinkState = false;
  // join I2C bus (I2Cdev library doesn't do this automatically)
  Wire.begin();
  // initialize serial communication
  // (38400 chosen because it works as well at 8MHz as it does at 16MHz, but
  // it's really up to you depending on your project)
  Serial.begin(38400);
  // initialize device
  Serial.println("Initializing I2C devices...");
  accelgyro.initialize();
  // verify connection
  // configure Arduino LED for
  pinMode(LED_PIN, OUTPUT);
  // read raw accel/gyro measurements from device
  // these methods (and a few others) are also available
  //accelgyro.getAcceleration(&ax, &ay, &az);
  //accelgyro.getRotation(&gx, &gy, &gz);
  // display tab-separated accel/gyro x/y/z values
// Serial.print("a/g:\t");
  Serial.print(ax);
  Serial.print(",");
  Serial.print(ay);
  Serial.print(",");
  Serial.print(az);
  Serial.print(",");
  // blink LED to indicate activity
  blinkState = !blinkState;
  digitalWrite(LED_PIN, blinkState);
发表于 2014-3-20 10:49:53 | 显示全部楼层
问题解决没有  我也是出现这样的问题
GMT+8, 2026-7-28 17:09 , Processed in 0.033881 second(s), 19 queries .
