查看: 6398|回复: 0
新人求问~
发表于 2013-5-4 21:56:48 | 显示全部楼层 |阅读模式
小弟最近开始学习arduino 看到以下一篇教程
http://winkleink.blogspot.co.uk/2011/07/arduino-8x8-led-driving-game.html
教程中给出了代码 但是我的LED却只能全亮 不能像游戏中哪样 请高手帮忙~我是红色的8X8led 和他一样用了2个shit register
一个POT 我POT接的是 pin2 但是LED却不能显示
int clockPin = 12;
  int latchPin = 8;
int dataPin = 11;
这个我和他接法一样求大神指点
代码如下
// Control an 8x8 LED display with 2 x 74HC595 shift registers
// Using only 3 pins from the Arduino
// Random Number - used to decide if to go back 1, stay the same line or forward 1
int randNumber;
//currentLine is used to record the current position of the track
int currentLine = 3;
// Postion of car
int carPosition = 3;
// Arduino Pin for the Pot used as the controller input for the car
int potPin = 2;
// Reading for the pot
int potRead;
// Range for the Pot as full travel would be too much to be practical
int potLow;
int potHigh;
//Pin connected to Pin 12 of 74HC595 (Latch)
int latchPin = 8;
//Pin connected to Pin 11 of 74HC595 (Clock)
int clockPin = 12;
//Pin connected to Pin 14 of 74HC595 (Data)
int dataPin = 11;
uint8_t led[8];
uint8_t car[8];
uint8_t trackLine[5];
long counter1 = 0;
// Seed Random Generator with noise from analog pin 0
randomSeed(analogRead(0));
//set pins to output
pinMode(latchPin, OUTPUT);
pinMode(clockPin, OUTPUT);
pinMode(dataPin, OUTPUT);
// Set Track to straight
led[0] = B11100011;
led[1] = B11100011;
led[2] = B11100011;
led[3] = B11100011;
led[4] = B11100011;
led[5] = B11100011;
led[6] = B11100011;
led[7] = B11100011;
// Set car position - looks backward, but the display is LSB so a 1
// on the right will show as a 1 on the left of the screen
car[0] = B00000001;
car[1] = B00000010;
car[2] = B00000100;
car[3] = B00001000;
car[4] = B00010000;
car[5] = B00100000;
car[6] = B01000000;
car[7] = B10000000;
// used to set the track decision
trackLine[0] = B10001111;
trackLine[1] = B11000111;
trackLine[2] = B11100011;
trackLine[3] = B11110001;
// trackLine[4] = B00001001;
potRead = analogRead(potPin);
potLow = potRead - 70;
potHigh = potRead + 89;
// counter1 used for delay in animation
counter1++;
// set the LEDs
screenUpdate();
if (potRead > potHigh){
   potRead = potHigh;}
if (potRead < potLow){
   potRead = potLow;}
carPosition = (potRead - potLow)/20;
// Loop for the action
if (counter1 >=75) {
counter1 = 0;
// Do track
for (int i = 0 ; i < 7 ; i++){
   led[i] = led[i+1];
// check of the car has crashed if it has then do a crash signal
if (led[0] & car[carPosition]){
  crash();
led[0] = led[0] | car[carPosition];
randNumber = random(3)-1;
currentLine = currentLine +randNumber;
if (currentLine == 0){
   currentLine = 1;}
if (currentLine == 5){
   currentLine = 4;}
led[7] = trackLine[currentLine-1];
void screenUpdate() {
uint8_t row = B00000001;
for (byte k = 0; k < 9; k++) {
// Open up the latch ready to receive data
digitalWrite(latchPin, LOW);
shiftIt(~row );
shiftIt(led[k] ); // LED array
// Close the latch, sending the data in the registers out to the matrix
digitalWrite(latchPin, HIGH);
row = row << 1;
void shiftIt(byte dataOut) {
// Shift out 8 bits LSB first,
// on rising edge of clock
boolean pinState;
//clear shift register read for sending data
digitalWrite(dataPin, LOW);
// for each bit in dataOut send out a bit
for (int i=0; i<8; i++) {
  //set clockPin to LOW prior to sending bit
digitalWrite(clockPin, LOW);
// if the value of DataOut and (logical AND) a bitmask
// are true, set pinState to 1 (HIGH)
if ( dataOut & (1<<i) ) {
pinState = HIGH;
else {
   pinState = LOW;
//sets dataPin to HIGH or LOW depending on pinState
digitalWrite(dataPin, pinState);
//send bit out on rising edge of clock
digitalWrite(clockPin, HIGH);
//stop shifting
void crash(){
// Used to set all bits on or off
int allBits = B11111111;
// Do 10 loop so of on and off
for (int show=0; show <10; show++){
for (int i=0; i <8; i++){
led[i] = allBits;
for (int delaylots=0; delaylots<200; delaylots++){
   screenUpdate();
if(allBits == B11111111){
   allBits = B00000000;
// Reset the position of the car to the middle of the track
for (int i =0; i <8; i++){
  led[i] = trackLine[2];
GMT+8, 2026-7-26 20:47 , Processed in 0.084628 second(s), 17 queries .
