如下边的帖子:
http://www.geek-workshop.com/thread-1165-1-1.html
按照那个帖子,我把程序改成这样
#include <SPI.h>
#include <Ethernet.h>
#include <Wire.h>
#include <math.h>
byte buff[2];
// for yeelink api
#define APIKEY "798e1ba4a9a0f********86c9d38" // replace your yeelink api key here
#define DEVICEID 2988 // replace your device ID
#define SENSORID 4215 // replace your sensor ID
// assign a MAC address for the ethernet controller.
byte mac[] = { 0x00, 0x5D, 0x60, 0x15, 0xDA, 0x8D};
//byte ip[] = { 10, 1,19, 205 };
// initialize the library instance:
EthernetClient client;
char server[] = "api.yeelink.net"; // name address for yeelink API
//IPAddress server(42,96,164,52);
unsigned long lastConnectionTime = 0; // last time you connected to the server, in milliseconds
boolean lastConnected = false; // state of the connection last time through the main loop
const unsigned long postingInterval = 30*1000; // delay between 2 datapoints, 30s
String returnValue = "";
boolean ResponseBegin = false;
pinMode(7, OUTPUT);
Wire.begin();
// start serial port:
Serial.begin(57600);
// start the Ethernet connection with DHCP:
if (Ethernet.begin(mac) == 0) {
for(;;)
else {
Serial.println("Ethernet configuration OK");
// Ethernet.begin(mac, ip);
// if there's incoming data from the net connection.
// send it out the serial port. This is for debugging
// purposes only:
if (client.available()) {
char c = client.read();
// Serial.print(c);
if (c == '{')
ResponseBegin = true;
else if (c == '}')
if (ResponseBegin)
returnValue += c;
if (returnValue.length() !=0 && (ResponseBegin == false))
Serial.println(returnValue);
if (returnValue.charAt(returnValue.length() - 1) == '1') {
Serial.println("turn on the LED");
digitalWrite(7, HIGH);
else if(returnValue.charAt(returnValue.length() - 1) == '0') {
Serial.println("turn off the LED");
digitalWrite(7, LOW);
returnValue = "";
// if there's no net connection, but there was one last time
// through the loop, then stop the client:
if (!client.connected() && lastConnected) {
Serial.println();
client.stop();
// if you're not connected, and ten seconds have passed since
// your last connection, then connect again and send data:
if(!client.connected() && (millis() - lastConnectionTime > postingInterval)) {
// read sensor data, replace with your code
//int sensorReading = readLightSensor();
Serial.print("yeelink:");
//get data from server
getData();
// store the state of the connection for next time through
// the loop:
lastConnected = client.connected();
// this method makes a HTTP connection to the server and get data back
void getData(void) {
// if there's a successful connection:
if (client.connect(server, 80)) {
// send the HTTP GET request:
client.print("GET /v1.0/device/");
client.print(DEVICEID);
client.print("/sensor/");
client.print(SENSORID);
client.print("/datapoints");
client.println(" HTTP/1.1");
client.println("Host: api.yeelink.net");
client.print("Accept: *");
client.print("/");
client.println("*");
client.print("U-ApiKey: ");
client.println(APIKEY);
client.println("Content-Length: 0");
client.println("Connection: close");
client.println();
Serial.println("print get done.");
else {
// if you couldn't make a connection:
Serial.println();
client.stop();
// note the time that the connection was made or attempted:
问题:
1、串口一直打印:
yeelink:connecting...
print get done.
print get done.
2、无法使用yeelink平台对led控制;
由于之前的帖子时间太久,就重发了个》》》》
大伙给点建议吧........谢谢了》》》
