查看: 9695|回复: 0
Arduino Ethernet 在IDE 0021 和W5100 ethernet shield与PC机串口测试时连接失败...
发表于 2013-5-19 19:02:59 | 显示全部楼层 |阅读模式
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
byte ip[] = { 192, 168, 1, 102 };
byte server[] = { 222, 139, 215, 195 };
Client client(server, 2080);
  Ethernet.begin(mac, ip);
  Serial.println("starting simple arduino client test");
  Serial.println();
  delay(1000);
  if (client.connect()) {
    Serial.println("connected");
    client.println("GET /~shb/arduino.txt HTTP/1.0");
    client.println();
  } else {
  if (client.available()) {
    char c = client.read();
    Serial.print(c);
  if (!client.connected()) {
    Serial.println();
    client.stop();
    for(;;);
观察结果为:
connecting...
connection failed
如何解决?
disconnecting.
GMT+8, 2026-7-26 19:56 , Processed in 0.047695 second(s), 18 queries .
