查看: 10035|回复: 4
【求助】用python发送arduino采集的数据到yeelink,莫名错误
发表于 2013-5-19 20:51:51 | 显示全部楼层 |阅读模式
本人想用python发送arduino 数据到yeelink,但是一直提示
406 Not Acceptable
b'Data format incorrect.'
如果把"Content-Length": 改为9以上,则没有反应。
请高手指点啊!
代码入下:
  1. import http.client, urllib.parse
  2. params = urllib.parse.urlencode({"value":29})
  3. headers = {"U-ApiKey":"632xxxxxxxxxxxxxxxxxxxx",
  4.            "Content-Length": 8,
  5.            "Content-type": "application/x-www-form-urlencoded",
  6.            "Connection": "close",
  7.            "Accept": "*/*"
  8.            }
  9. conn = http.client.HTTPConnection("api.yeelink.net")
  10. conn.request("POST",url="/v1.0/device/2432/sensor/3557/datapoints", body=params, headers=headers)
  11. response = conn.getresponse()
  12. print(response.status, response.reason)
  13. data = response.read()
  14. print(data)
  15. conn.close()
发表于 2013-5-19 22:00:41 | 显示全部楼层
可能是这句的问题
03.params = urllib.parse.urlencode({"value":29})
 楼主| 发表于 2013-5-20 00:32:30 | 显示全部楼层
davidce 发表于 2013-5-19 22:00
可能是这句的问题
还望明示啊
发表于 2013-5-20 08:02:09 | 显示全部楼层
urlencode 后的括号里应该都是字符串
 楼主| 发表于 2013-5-20 09:35:41 | 显示全部楼层
我是按文档改的,就是这样的,改成字符串反而会报错
  2. params = urllib.parse.urlencode({'@number': 12524, '@type': 'issue', '@action': 'show'})
  3. headers = {"Content-type": "application/x-www-form-urlencoded",
  4.            "Accept": "text/plain"}
  5. conn = http.client.HTTPConnection("bugs.python.org")
  6. conn.request("POST", "", params, headers)
  7. response = conn.getresponse()
  8. print(response.status, response.reason)
GMT+8, 2026-7-26 20:43 , Processed in 0.034346 second(s), 18 queries .
