今天做了个数码管的显示,利用串行转并行的74hc595来驱动四个数码管,用arduino的定时器做了一个时钟,具体实现的功能是:串口与数码管同步时钟,利用串口发送时间数据可以调时。没有数码管也可以下载代码,从串口看输出时钟哦,也可以发送调时指令。(手机像素不好,大家将就着看看吧)。
- // 实现功能:数码管显示时钟,通过串口设置时间(串口同步时钟)。
- // 1.串口波特率设置为:9600
- // 2.设置时间格式: Txxxxxx. 例:12:34:56 发送:T123456
- #include <TimerOne.h>
- #define uchar unsigned char
- #define SI_H digitalWrite(4, HIGH)
- #define SI_L digitalWrite(4, LOW);
- #define RCK_H digitalWrite(5, HIGH);
- #define RCK_L digitalWrite(5, LOW);
- #define SCK_H digitalWrite(6, HIGH);
- #define SCK_L digitalWrite(6, LOW);
- #define CS_H digitalWrite(7, HIGH);
- #define CS_L digitalWrite(7, LOW);
- uchar second,minute,hour;
- String Rx = "";
- uchar count[] =
- {0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90,0x88,0x83,0xC6,0xA1,0x86,0x8E};
- void port_init(void)
- pinMode(4, OUTPUT);
- pinMode(5, OUTPUT);
- pinMode(6, OUTPUT);
- pinMode(7, OUTPUT);
- pinMode(8, OUTPUT);
- pinMode(9, OUTPUT);
- pinMode(10, OUTPUT);
- pinMode(11, OUTPUT);
- //num = 0 / 1 / 2 / 3
- //mode = HIGH -> open / LOW -> close
- void SMG_select(uchar num,uchar mode)
- if(num<4)
- switch(num)
- case 0: num = 8; break;
- case 1: num = 9; break;
- case 2: num = 10;break;
- case 3: num = 11;break;
- digitalWrite(num,mode);
- void write_data(uchar data)
- uchar i;
- CS_H;
- for(i=0;i<8;i++)
- if((data&0x80)==0x80) SI_H;
- else SI_L;
- SCK_H;
- delayMicroseconds(20);
- SCK_L;
- data=data<<1;
- RCK_L;
- delay(1);
- RCK_H;
- CS_L;
- void set_time()
- while(Serial.available() >0)
- Rx += char( Serial.read() );
- delay(2);
- if (Rx.length() >0)
- if(Rx[0]==84)
- hour = (Rx[1]-0x30)*10 + (Rx[2]-0x30);
- minute = (Rx[3]-0x30)*10 + (Rx[4]-0x30);
- second = (Rx[5]-0x30)*10 + (Rx[6]-0x30);
- Serial.println(" -----------------------");
- Serial.print("| Set Time: ");
- Serial.print(hour,DEC);
- Serial.print(":");
- Serial.print(minute,DEC);
- Serial.print(second,DEC);
- Serial.println(" |");
- Rx = "";
- void setup()
- Serial.begin(9600);
- port_init();
- // pinMode(13, OUTPUT);
- Timer1.initialize(1000000);
- Timer1.attachInterrupt( timerIsr );
- void timerIsr()
- //digitalWrite( 13, digitalRead( 13 ) ^ 1 );
- second++;
- if(second > 59)
- second = 0;
- minute ++;
- if(minute > 59)
- minute = 0;
- hour ++;
- if(hour > 23) hour = 0;
- Serial.print("Time : ");
- Serial.println(second,DEC);
- void loop()
- set_time();
- SMG_select(0,HIGH);
- write_data(count[hour/10]);
- delayMicroseconds(400);
- SMG_select(0,LOW);
- SMG_select(1,HIGH);
- if(second%2) write_data(count[hour%10] + 0x80);
- else write_data(count[hour%10]);
- SMG_select(1,LOW);
- SMG_select(2,HIGH);
- write_data(count[minute/10]);
- SMG_select(2,LOW);
- SMG_select(3,HIGH);
- write_data(count[minute%10]);
- SMG_select(3,LOW);
复制代码 |
