查看: 10040|回复: 2
processing和arduino通信问题
发表于 2013-6-28 17:10:26 | 显示全部楼层 |阅读模式
本人小白。。。在利用processing和arduino进行通信时遇到了问题。。。
是这样,我想利用arduino的超声波传感器和processing结合,做出来一个当人靠近到一定距离时就会自动切换视频。。。但processing读取的数据和arduino的总是不一样。Serial.write(byte())已经写进去了,还是不行。。。。
ARDUINO CODE:
int inputPin = 3;
int outputPin = 2;
int inputPin1 = 9;
int outputPin1 = 8;
int distance;
int distance1;
void setup(){
  pinMode(inputPin,INPUT);
  pinMode(outputPin,OUTPUT);
  pinMode(inputPin1,INPUT);
  pinMode(outputPin1,OUTPUT);
void loop(){
  digitalWrite(outputPin,LOW);
  delayMicroseconds(2);
  digitalWrite(outputPin,HIGH);
  delayMicroseconds(10);
  float distance = pulseIn(inputPin,HIGH);
  distance = distance/58.0;
  Serial.print("distance = ");
  Serial.print(distance);
  Serial.println("cm");
  Serial.write(byte(distance));
  delay(100);
PROCESSING CODE  :
import processing.video.*;
import processing.serial.*;
Serial duankou;
Serial duankou1;
Movie mine;
Movie yours;
int data;
int data1;
  size(1200, 960);
  background(0);
  noStroke();
  smooth();
  duankou = new Serial(this, "/dev/cu.usbmodem1411", 9600);
  mine = new Movie(this, "1.mov");
  yours = new Movie(this, "2.mov");
void draw() {
  if (duankou.available()>0) {
    float data=duankou.read();
    println(data);
    if (data <= 10) {
      mine.play();
      yours.stop();
      image(mine, 0, 0);
    if (data >20) {
      yours.play();
      mine.stop();
      image(yours, 0, 0);
void movieEvent(Movie mine) {
  mine.read();
发表于 2013-6-29 13:51:29 | 显示全部楼层
发表于 2013-11-16 16:48:46 | 显示全部楼层
我回答不了,想请教下我用processing.serial的时候出现了serial does not run in 64-bit mode.
是不是因为我的电脑是64位的呢
GMT+8, 2026-7-27 23:57 , Processed in 0.033830 second(s), 20 queries .
