查看: 10132|回复: 0
解决Arduino联网问题
发表于 2013-7-8 13:11:28 | 显示全部楼层 |阅读模式
很多时候不能访问互联网,是因为DNS失败,或者DNS错误.
所以,可以人工修改DNS,方法是.
memset(ether.dnsip,8,4);
但是不一定能解决,这时候可以人工解决问题,电脑先解释IP,静态绑定.还能节省代码空间.
第一步,打开命令行提示符.
C:\Users\Tater>nslookup xxx.sinaapp.com //查自己域名
服务器:  cache-b.guangzhou.gd.cn
Address:  202.96.128.166
非权威应答:
名称:    sinaapp.com
Addresses:  220.181.136.37
          220.181.136.36
Aliases:  xxx.sinaapp.com
C:\Users\Tater>nslookup -qt=ns xxx.sinaapp.com  //如果没有权威回答,查自己域名的DNS
非权威应答:
xxx.sinaapp.com      canonical name = sinaapp.com
sinaapp.com     nameserver = ns4.sinaapp.com
sinaapp.com     nameserver = ns1.sinaapp.com
sinaapp.com     nameserver = ns2.sinaapp.com
sinaapp.com     nameserver = ns3.sinaapp.com
C:\Users\Tater>nslookup -qt=a xxx.sinaapp.com ns4.sinaapp.com //查自己域名的权威解答,后面ns是上面的结果任意一个
服务器:  UnKnown
Address:  220.181.129.90
名称:    sinaapp.com
Addresses:  220.181.136.36
          220.181.136.37
在代码中定义:
static byte remoteIp[] = {220,181,136,36};
在代码中执行.
ether.copyIp(ether.hisip,remoteIp);
完整代码:
  1. #include <EtherCard.h>
  2. static byte mymac[] = {0x74, 0x69, 0x69, 0x3D, 0x37, 0x31};
  3. static byte remoteIp[] = {220,181,136,36};
  4. byte Ethernet::buffer[700];
  5. char website[] PROGMEM = "xxx.sinaapp.com";
  6. unsigned long previousMillis = 0;
  7. unsigned long currentMillis;
  8. static byte session_id;
  9. byte actual_status;
  10. void setup ()
  11. {
  12.     Serial.begin(38400);
  13.
  14.     Serial.println("Initializing...");
  15.
  16.     ether.begin(sizeof Ethernet::buffer, mymac, 10);
  17.     ether.dhcpSetup();
  18.     ether.copyIp(ether.hisip,remoteIp);
  19.
  20.     ether.printIp("IP Address:\t", ether.myip);
  21.     ether.printIp("Netmask:\t", ether.mymask);
  22.     ether.printIp("Gateway:\t", ether.gwip);
  23.     ether.printIp("DNS Server:\t", ether.dnsip);
  24.     ether.printIp("Internet Gate:\t", ether.hisip);
  25.
  26. }
GMT+8, 2026-7-27 01:26 , Processed in 0.058810 second(s), 18 queries .
