返回列表 发新帖
楼主: smching
阿癫佬与泼妇玩灯光效果
发表于 2013-12-11 23:09:42 | 显示全部楼层
大师邮箱多少啊,
 楼主| 发表于 2013-12-14 15:35:03 | 显示全部楼层
白贼 发表于 2013-12-11 23:06
能请问下大师vixen2控制arduinoUNO灯光秀,为何我的LED总是点不亮,我发个文件你帮我看下,行不?
你是用1#还是15#的代码/设计?
遇到了什么问题?
 楼主| 发表于 2013-12-14 15:42:46 | 显示全部楼层
白贼 发表于 2013-12-11 23:09
大师邮箱多少啊,
我的邮箱时常会收到许多垃圾邮件,偶而会看漏邮件。建议来这里讨论
发表于 2013-12-14 21:07:26 | 显示全部楼层
貌似OK了,
发表于 2014-12-18 10:24:04 | 显示全部楼层
白贼 发表于 2013-12-14 21:07
貌似OK了,
你是不是用LED来代替舞台灯光的,如何实现的可以分享一下心得体会吗?
Vixen我用的是3.1版的。
发表于 2014-12-21 10:57:48 | 显示全部楼层
Vixen我用的是3.1版的。
我只会vixen2.1,有个程序给你参考
#include <Wire.h>
#include <LiquidCrystal_I2C.h>
LiquidCrystal_I2C lcd(0x27,20,4); //set the LCD address to 0x37 for a 16 chars and 2 line display
    The purpose of this code is to allow the Arduino to use the
    generic serial output of vixen lights to control 5 channels of LEDs.
    Author: Matthew Strange
    Created: 14 October 2010
    Modifier: Ben Towner
    Modified: 19-OCT-2010
    Changes: Addition of 20 Digital On/Off Channels - Setup for Arduino Mega 2560
    // PWM Output - ChanX=PWM Pin
    int Chan1 = 2;
    int Chan2 = 3;
    int Chan3 = 4;
    int Chan4 = 5;
    int Chan5 = 6;
    // Digital Output - ChanX=Digital Pin
    int Chan6 = 7;
    int Chan7 = 8;
    int Chan8 = 9;
    int Chan9 = 10;
    int Chan10 = 11;
    int Chan11 = 12;
    int Chan12 = 13;
    int i = 0;     // Loop counter
    int incomingByte[19];   // array to store the 25 values from the serial port
    //setup the pins/ inputs & outputs
      Serial.begin(9600);        // set up Serial at 9600 bps
      pinMode(Chan1, OUTPUT);   // sets the pins as output
      pinMode(Chan2, OUTPUT);
      pinMode(Chan3, OUTPUT);
      pinMode(Chan4, OUTPUT);
      pinMode(Chan5, OUTPUT);
      pinMode(Chan6, OUTPUT);
      pinMode(Chan7, OUTPUT);
      pinMode(Chan8, OUTPUT);
      pinMode(Chan9, OUTPUT);
      pinMode(Chan10, OUTPUT);
      pinMode(Chan11, OUTPUT);
      pinMode(Chan12, OUTPUT);
      pinMode(A0, OUTPUT);
      pinMode(A1, OUTPUT);
      pinMode(A2, OUTPUT);
      pinMode(A3, OUTPUT);
    //  pinMode(A4, OUTPUT);
   //   pinMode(A5, OUTPUT);
    lcd.init();
    lcd.backlight();
    {  // 25 channels are coming in to the Arduino
       if (Serial.available() >=11) {
        // read the oldest byte in the serial buffer:
        for (int i=0; i<11; i++) {
          // read each byte
          incomingByte = Serial.read();
        analogWrite(Chan1, incomingByte[0]);   // Write current PWM values to LED pins
        analogWrite(Chan2, incomingByte[1]);
        analogWrite(Chan3, incomingByte[2]);
        analogWrite(Chan4, incomingByte[3]);
        analogWrite(Chan5, incomingByte[4]);
        digitalWrite(Chan6, incomingByte[5]);   // Write on/off values to LED pins
        digitalWrite(Chan7, incomingByte[6]);
        digitalWrite(Chan8, incomingByte[7]);
        digitalWrite(Chan9, incomingByte[8]);
        digitalWrite(Chan10, incomingByte[9]);
        digitalWrite(Chan11, incomingByte[10]);
        digitalWrite(Chan12, incomingByte[11]);  /*
        analogWrite(A0, incomingByte[12]);
        analogWrite(A1, incomingByte[13]);
        analogWrite(A2, incomingByte[14]);
        analogWrite(A3, incomingByte[15]);  */
     //   analogWrite(A4, incomingByte[16]);
    //    analogWrite(A5, incomingByte[17]);    */
  lcd.setCursor(0, 1);
   lcd.print(incomingByte[0]);
  lcd.setCursor(0, 2);
   lcd.print(incomingByte[1]);
发表于 2014-12-21 11:01:20 | 显示全部楼层
Vixen我用的是3.1版的。
这个是vixen2.1配合上传的ino代码你试下
发表于 2014-12-21 13:30:48 | 显示全部楼层
谢谢,我试试!~
发表于 2014-12-21 18:05:47 | 显示全部楼层
FredKhoo 发表于 2014-12-21 13:30
谢谢,我试试!~
OK or NO????
发表于 2015-1-12 00:41:07 | 显示全部楼层
@您好楼主,有个问题我想请教一下,我用了BILL写的数组生成器,就是把vixen生成cpp数组给arduino调用,这样可以不用打开vixen点亮LED,但是他点亮了,我点不亮,我发提问了有空麻烦看一下可以吗http://www.geek-workshop.com/thread-12380-1-1.html
发表于 2015-1-12 21:16:49 | 显示全部楼层
谢谢分享学习一下
 楼主| 发表于 2015-2-3 19:32:40 | 显示全部楼层
白贼 发表于 2015-1-12 00:41
@您好楼主,有个问题我想请教一下,我用了BILL写的数组生成器,就是把vixen生成cpp数组给arduino调用,这样 ...
你是参考这个吗?
http://www.billporter.info/2012/ ... ersion-for-arduino/
我不曾测试,有空玩玩看
发表于 2015-2-4 11:03:28 | 显示全部楼层
很实用的东西啊,这软件名字太搞笑了
发表于 2016-7-21 18:55:33 | 显示全部楼层
大陆很多国产灯具里面,DMX就是用stc8951来编解码的,以后看来arduino也有希望哦~
GMT+8, 2026-7-28 10:42 , Processed in 0.045265 second(s), 22 queries .
