查看: 10616|回复: 1
software serial 例程编译错误
发表于 2013-7-17 17:34:32 | 显示全部楼层 |阅读模式
arduino版本是1.0.5,为什么software serial例程都会编译错误呢?
例程如下:
  Software serial multple serial test
Receives from the hardware serial, sends to software serial.
Receives from software serial, sends to hardware serial.
The circuit:
* RX is digital pin 10 (connect to TX of other device)
* TX is digital pin 11 (connect to RX of other device)
Note:
Not all pins on the Mega and Mega 2560 support change interrupts,
so only the following can be used for RX:
10, 11, 12, 13, 50, 51, 52, 53, 62, 63, 64, 65, 66, 67, 68, 69
Not all pins on the Leonardo support change interrupts,
8, 9, 10, 11, 14 (MISO), 15 (SCK), 16 (MOSI).
created back in the mists of time
modified 25 May 2012
by Tom Igoe
based on Mikal Hart's example
This example code is in the public domain.
#include <SoftwareSerial.h>
SoftwareSerial mySerial(10, 11); // RX, TX
  // Open serial communications and wait for port to open:
  Serial.begin(57600);
  while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  Serial.println("Goodnight moon!");
  // set the data rate for the SoftwareSerial port
  mySerial.begin(4800);
  mySerial.println("Hello, world?");
void loop() // run over and over
  if (mySerial.available())
    Serial.write(mySerial.read());
  if (Serial.available())
    mySerial.write(Serial.read());
错误显示:
d:/program/arduino/hardware/tools/avr/bin/..b/gcc/avr/4.3.2/../../../../avrb/avr6/crtm2560.o: In function `__vector_default':
(.vectors+0xdc): relocation truncated to fit: R_AVR_13_PCREL against symbol `__vector_55' defined in .text.__vector_55 section in core.a(HardwareSerial.cpp.o)
谢谢各位大神!
 楼主| 发表于 2013-7-17 18:37:59 | 显示全部楼层
知道为什么了,把板子型号选为nano 328就可以了,可能是因为mega 2560上的11口为pwm口,而不是数字口~
GMT+8, 2026-7-27 08:47 , Processed in 0.042174 second(s), 17 queries .
