查看: 12636|回复: 2
求助arduino 测量大于5v电压疑问
发表于 2013-8-4 23:45:10 | 显示全部楼层 |阅读模式
      下述代码例子是通过2个1K电阻进行分压,来测量范围0-10v的电压,例子中resistorFactor = 1023.0 / (R2/(R1 + R2));  这句是不是写错了?应该是resistorFactor = 1023.0 * (R2/(R1+R2)); 这样结果正好是511,与下述图表中的value of resistorFactor 吻合。
  DisplayMoreThan5V sketch
  prints the voltage on analog pin to the serial port
  Do not connect more than 5 volts directly to an Arduino pin.
const float referenceVolts = 5;   // the default reference on a 5-volt board
//const float referenceVolts = 3.3;  // use this for a 3.3-volt board
const float R1 = 1000; // value for a maximum voltage of 10 volts
const float R2 = 1000;
// determine by voltage divider resistors, see text
const float resistorFactor = 1023.0 / (R2/(R1 + R2));  //此处是否应该是resistorFactor = 1023.0 * (R2/(R1+R2));
const int batteryPin = 0;   // +V from battery is connected to analog pin 0
   int val = analogRead(batteryPin);  // read the value from the sensor
   float volts =
     (val / resistorFactor) * referenceVolts ; // calculate the ratio
   Serial.println(volts);  // print the value in volts
发表于 2013-8-5 06:26:22 | 显示全部楼层
you are right!
发表于 2013-8-5 10:49:01 | 显示全部楼层
对不对,自己实际测试一下便知~
GMT+8, 2026-7-27 08:53 , Processed in 0.034299 second(s), 20 queries .
