查看: 9350|回复: 1
求助:arduino转化C51
发表于 2013-8-6 17:29:03 | 显示全部楼层 |阅读模式
  int L,R,i1,i2;
  i1=analogRead(analogPin1);
  L=(6762/(i1-9))-4;
  if(L<threshold&&L>0) //物体偏左
    while(1)
      xx+=0.01;
      i2=analogRead(analogPin2);
      R=(6762/(i2-9))-4;
      if(R<threshold&&R>0) //向右移动??
        while(1) //等待左边检测离开
          L=(6762/(i1-9))-4;
          if(L>threshold&&L>0)
            while(1) //等待右边检测离开
              R=(6762/(i2-9))-4;
             delay(20);
              if(R>threshold)
               delay(20);
                 //Serial.write(right);
                   if(xx>0&&xx<6)
                 { //Serial.println('1');
                    Serial.write(3);
                 if(xx>6&&xx<12)
                 {Serial.write(2);}
                 if(xx>12)
                 {Serial.write(1);}
                 xx=0;
                delay(20);
else //放弃检
        L=(6762/(i1-9))-4;
        if(L>threshold) break;
  R=(6762/(i2-9))-4;
if( R<threshold&&R>0) //物体偏右
    while(1)
      xx+=0.01;
      L=(6762/(i1-9))-4;
      if(!L) break;
      if(L<threshold&&L>0) //向左移动??
        while(1) //等待右边检测离开
          R=(6762/(i2-9))-4;
          if(R>threshold)
            while(1) //等待左边检测离开
              L=(6762/(i1-9))-4;
               delay(20);
              if(L>threshold)
              { delay(20);
                  //Serial.write(left);
                  if(xx>0&&xx<6)
                 { Serial.write(6);}
                 if(xx>6&&xx<12)
                 {Serial.write(5);}
                 if(xx>12)
                 {Serial.write(4);}
                  xx=0;
                delay(20) ;
      else //放弃检??
        R=(6762/(i2-9))-4;
        if(R>threshold) break;
求助大神
发表于 2013-8-7 12:40:23 | 显示全部楼层
就是用C在改写一次了?
GMT+8, 2026-7-27 21:14 , Processed in 0.044482 second(s), 19 queries .
