查看: 11057|回复: 0
求救 parallax MLX90614 Infrared Module
发表于 2013-8-12 11:02:50 | 显示全部楼层 |阅读模式
我使用 1.05 版 arduino , 可是以下程序代码
无法通过compile
我将 Temp90.print(0,BYTE); 修改成 Temp90.write(0);
可是还是无法成功
请问要如何解决
#include <SoftwareSerial.h>
SoftwareSerial Temp90(2, 3);
int LED=13;   /* for the show  */
int RESET=12;
  pinMode(2,OUTPUT);
  pinMode(3,OUTPUT);
  pinMode(RESET,OUTPUT);
  digitalWrite(RESET,HIGH);
  delay(50);
  digitalWrite(RESET,LOW);
  delay(100);
  Temp90.begin(2400);
  Serial.begin(115200);
  delay(100);
  Temp90.print("!TEMc");
  Temp90.print(0x5A,BYTE);
  Temp90.print(7,BYTE);
  digitalWrite(LED,HIGH);
  delay(1000);
  digitalWrite(LED,LOW);
  pinMode(2,INPUT);
  pinMode(3,INPUT);
  delay(10);
Acqu_Temp();
int Acqu_Temp()
  static char rByte[10];
  char rChar;
  static int Read=0;
  static int rcount=0;
  int Temp1, Temp2, Temp3;
    rChar = Temp90.read();
    if (rChar == 'T') {
      rByte[0]=rChar;
      rChar=Temp90.read();
      if(rChar=='E')
          rByte[1]=rChar;
          if(rChar=='M')
            rByte[2]=rChar;
            rByte[3]=Temp90.read();
            rByte[4]=Temp90.read();
            rByte[5]=Temp90.read();
            Temp1 = rByte[4] + rByte[5]*256;
            Temp2 = (Temp1/100);
            if (Temp1*2 < 27315) {
                Temp3 = ((27315-(Temp1*2))/100);
              Temp3 = (Temp1/100*2)-273;
              Serial.print("Temperature= ");
              Serial.print(Temp3,DEC);
              Serial.println(" Degrees Celsius");
      delay(500);
      delay(500);
GMT+8, 2026-7-28 06:15 , Processed in 0.066905 second(s), 17 queries .
