本人新人——废话不多说了……直接上代码……
官网也有这个代码,但是发这里大家用的方便……:)
记得把int接入D2口作为中断
接线和以前一样接arduino 的 I2C接口
SDL SCL两个口
3.3v电源
- // Arduino Wire library is required if I2Cdev I2CDEV_ARDUINO_WIRE implementation
- // is used in I2Cdev.h
- #include "Wire.h"
- // I2Cdev and MPU6050 must be installed as libraries, or else the .cpp/.h files
- // for both classes must be in the include path of your project
- #include "I2Cdev.h"
- #include "MPU6050_6Axis_MotionApps20.h"
- MPU6050 mpu(0x68);
- // MPU control/status vars
- bool dmpReady = false; // set true if DMP init was successful
- uint8_t mpuIntStatus; // holds actual interrupt status byte from MPU
- uint8_t devStatus; // return status after each device operation (0 = success, !0 = error)
- uint16_t packetSize; // expected DMP packet size (default is 42 bytes)
- uint16_t fifoCount; // count of all bytes currently in FIFO
- uint8_t fifoBuffer[64]; // FIFO storage buffer
- // orientation/motion vars
- Quaternion q; // [w, x, y, z] quaternion container
- VectorFloat gravity; // [x, y, z] gravity vector
- float ypr[3]; // [yaw, pitch, roll] yaw/pitch/roll container and gravity vector
- // === INTERRUPT DETECTION ROUTINE ===
- volatile bool mpuInterrupt = false; // indicates whether MPU interrupt pin has gone high
- void dmpDataReady() {
- mpuInterrupt = true;
- // === INITIAL SETUP ===
- void mpu_setup() {
- //Serial.begin(115200); // opens serial port, sets data rate to 9600 bps
- // join I2C bus (I2Cdev library doesn't do this automatically)
- Wire.begin();
- // initialize device
- Serial.println("Initializing I2C devices...");
- mpu.initialize();
- // verify connection
- Serial.println("Testing device connections...");
- Serial.println(mpu.testConnection() ? "MPU6050 connection successful" : "MPU6050 connection failed");
- delay(2);
- // load and configure the DMP
- Serial.println("Initializing DMP...");
- devStatus = mpu.dmpInitialize();
- // make sure it worked (returns 0 if so)
- if (devStatus == 0) {
- // turn on the DMP, now that it's ready
- Serial.println("Enabling DMP...");
- mpu.setDMPEnabled(true);
- // enable Arduino interrupt detection
- Serial.println("Enabling interrupt detection (Arduino external interrupt 0)...");
- attachInterrupt(0, dmpDataReady, RISING);
- mpuIntStatus = mpu.getIntStatus();
- // set our DMP Ready flag so the main loop() function knows it's okay to use it
- Serial.println("DMP ready! Waiting for first interrupt...");
- dmpReady = true;
- // get expected DMP packet size for later comparison
- packetSize = mpu.dmpGetFIFOPacketSize();
- else {
- // ERROR!
- // 1 = initial memory load failed
- // 2 = DMP configuration updates failed
- // (if it's going to break, usually the code will be 1)
- Serial.print("DMP Initialization failed (code ");
- Serial.print(devStatus);
- Serial.println(")");
- void mpu_loop()
- float alpha,omiga;
- // if programming failed, don't try to do anything
- if (!dmpReady)
- return;
- // wait for MPU interrupt or extra packet(s) available
- if (!mpuInterrupt && fifoCount < packetSize)
- return;
- // reset interrupt flag and get INT_STATUS byte
- mpuInterrupt = false;
- // get current FIFO count
- fifoCount = mpu.getFIFOCount();
- // check for overflow (this should never happen unless our code is too inefficient)
- if ((mpuIntStatus & 0x10) || fifoCount == 1024) {
- // reset so we can continue cleanly
- mpu.resetFIFO();
- Serial.println("FIFO overflow!");
- // otherwise, check for DMP data ready interrupt (this should happen frequently)
- else if (mpuIntStatus & 0x02) {
- // wait for correct available data length, should be a VERY short wait
- while (fifoCount < packetSize) fifoCount = mpu.getFIFOCount();
- // read a packet from FIFO
- mpu.getFIFOBytes(fifoBuffer, packetSize);
- // track FIFO count here in case there is > 1 packet available
- // (this lets us immediately read more without waiting for an interrupt)
- fifoCount -= packetSize;
- mpu.dmpGetQuaternion(&q, fifoBuffer);
- mpu.dmpGetGravity(&gravity, &q);
- mpu.dmpGetYawPitchRoll(ypr, &q, &gravity); //从DMP中取出Yaw、Pitch、Roll三个轴的角度,放入数组ypr。单位:弧度
- alpha=-ypr[2] * 180/M_PI;
- omiga=mpu.getRotationX()/16.4; //配置是16位表示正负2000°/s, 65536/4000
- Serial.print("Alpha ");
- Serial.print(alpha);//x轴平行偏移角度
- Serial.print("\tOmiga ");
- Serial.println(omiga);//对应加速度力道
另外谁研究过dmp的电子罗盘接入?
请分享下 |
