楼主: 弘毅
arduino uno mega2560等各种不同板子bootloader烧写方法
发表于 2014-6-22 22:49:13 | 显示全部楼层
弘毅版主,
熔丝位低位值由FF改为3F之后(目的是为了掉电使能),arduino IDE就无法下载程序了呢?
发表于 2014-6-22 22:53:40 | 显示全部楼层
我用USBtinyISP下载uno时出错
processing.app.debug.RunnerException
        at cc.arduino.packages.uploaders.SerialUploader.burnBootloader(SerialUploader.java:309)
        at processing.app.Editor$47.run(Editor.java:2571)
        at java.awt.event.InvocationEvent.dispatch(Unknown Source)
        at java.awt.EventQueue.dispatchEventImpl(Unknown Source)
        at java.awt.EventQueue.access$200(Unknown Source)
        at java.awt.EventQueue$3.run(Unknown Source)
        at java.security.AccessController.doPrivileged(Native Method)
        at java.security.ProtectionDomain$1.doIntersectionPrivilege(Unknown Source)
        at java.awt.EventQueue.dispatchEvent(Unknown Source)
        at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
        at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
        at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
        at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
        at java.awt.EventDispatchThread.run(Unknown Source)
Caused by: processing.app.debug.RunnerException: Wrong microcontroller found.  Did you select the right board from the Tools > Board menu?
        at cc.arduino.packages.Uploader.executeUploadCommand(Uploader.java:113)
        at cc.arduino.packages.uploaders.SerialUploader.burnBootloader(SerialUploader.java:302)
        ... 15 more
是什么意思,
用原配的328p-au可以正常下载
发表于 2014-6-22 23:12:42 | 显示全部楼层
熔丝位低位值由FF改为3F之后,下载程序报错avrdude: stk500_getsync(): not in sync: resp=0x00
发表于 2014-6-22 23:31:28 | 显示全部楼层
用avrdude-GUI读不出熔丝位
发表于 2014-6-22 23:55:11 | 显示全部楼层
怎么上不了图?
发表于 2014-6-22 23:56:08 | 显示全部楼层
图在附件中
发表于 2014-6-22 23:57:01 | 显示全部楼层
是不是买到假的328p-pu了
发表于 2014-7-8 21:05:17 | 显示全部楼层
我按照楼主的讲解依次操作,用USBASP刷BOOT,只显示校验错,13引脚的LED间隔一秒钟的闪烁,然后用IDE加载LED实例程序,最后总是提示:
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: stk500v2_getsync(): timeout communicating with programmer
求助,这是如何解决???
是裸板烧录的,没有加任何扩展!!
发表于 2014-8-2 17:20:36 | 显示全部楼层
rsw1986 发表于 2012-4-16 12:41
谢谢楼主,这个问题解决了,缺少的那个文件是usbtinyIPS的驱动,装上驱动就好了
请问你这个驱动是怎么装的啊,我试了几遍都不行啊
发表于 2014-8-13 22:29:57 | 显示全部楼层
我的是xp,win8稍微麻烦点,需要百度一下
发表于 2014-8-15 23:32:28 | 显示全部楼层
我是刷 uno的 用avrdude-GUI-1.0.5,所有的步骤都对了,但是最后显示刷错误,如图,请问怎么办哈 试过好多次了 都一样的错误。
发表于 2014-8-21 16:43:02 | 显示全部楼层
弱弱的问一句,用的是什么下载线?ISP下载线不是10pin的嘛?ICSP是6pin的。
发表于 2014-10-12 11:06:42 | 显示全部楼层
楼主楼主
出现这种问题 是不是那个bootloader缺失呀??
Binary sketch size: 5,492 bytes (of a 32,256 byte maximum)
avrdude: verification error, first mismatch at byte 0x0042
         0x43 != 0xba
avrdude: verification error; content mismatch
发表于 2014-10-14 17:34:53 | 显示全部楼层
有了这个,就可以自制arduino最小系统了
发表于 2014-12-15 10:20:21 | 显示全部楼层
请教大侠  是不是没有bootloader,不能下载程序进去,,我做的2560系统版没有烧录bootloader。。是不是烧不进去程序就是这原因。。
GMT+8, 2026-7-23 10:03 , Processed in 0.039869 second(s), 26 queries .
