查看: 10576|回复: 2
想做一个检测到物体电机自动停转的程序
发表于 2013-9-8 20:43:42 | 显示全部楼层 |阅读模式
本人菜鸟,所以对这个语言方面还有诸多不熟悉的地方,就大神检查一下,这应该是个很简单的程序,我不知道哪不对,反正就是不工作。
代码如下:
int yellowtrig = 8;
int blackecho = 9;
int distance = 0;
int motorPin1 = 3;
int motorPin2 = 4;
void setup(){
pinMode(yellowtrig, OUTPUT);
pinMode(blackecho, INPUT);
void loop(){
digitalWrite(8,LOW);
delayMicroseconds(2);
digitalWrite(8,HIGH);
delayMicroseconds(10);
distance = pulseIn(9, HIGH);
distance = distance/58;
Serial.print(distance);
Serial.print("cm");
Serial.println(" ");
delay(1000);
if(distance <= 15){
digitalWrite(3,LOW);
digitalWrite(4,LOW);
}else{
digitalWrite(3,HIGH);
发表于 2013-9-9 13:27:15 | 显示全部楼层
真心没看懂
发表于 2013-9-9 18:54:58 | 显示全部楼层
这个编译过了?好像多个}吧
  1. int TrigPin = 8;
  2. int EchoPin = 9;
  3. int motorPin1 = 3;
  4. int motorPin2 = 4;
  5. float distance = 0;
  6. void setup(){
  7.   pinMode(motorPin1, OUTPUT);
  8.   pinMode(motorPin2, OUTPUT);
  9.   pinMode(TrigPin, OUTPUT);
  10.   pinMode(EchoPin, INPUT);
  11.   Serial.begin(9600);
  12. }
  13. void loop(){
  14.   distance=MeasuringDistance();
  15.   Serial.print(distance);
  16.   Serial.print("cm");
  17.   Serial.println(" ");
  18.   if(distance <= 15){
  19.     digitalWrite(motorPin1,LOW);
  20.     digitalWrite(motorPin2,LOW);
  21.   }
  22.   else{
  23.     digitalWrite(motorPin1,HIGH);
  24.     digitalWrite(motorPin2,LOW);
  25.   }
  26.   delay(1000);
  27. }
  28. long MeasuringDistance() {  //测量距离 单位厘米
  29.   long duration;
  30.   digitalWrite(TrigPin, LOW);
  31.   delayMicroseconds(2);
  32.   digitalWrite(TrigPin, HIGH);
  33.   delayMicroseconds(5);
  34.   digitalWrite(TrigPin, LOW);
  35.   duration = (pulseIn(EchoPin, HIGH))/29/2;
  36.   return duration;
  37. }
GMT+8, 2026-7-28 08:15 , Processed in 0.039494 second(s), 20 queries .
