查看: 11131|回复: 8
在网上找一个一码表代码,谁能帮我修正一下吗?
发表于 2013-9-23 08:30:23 | 显示全部楼层 |阅读模式
#include "U8glib.h"
#include <SD.h>
#include <TinyGPS.h>
#include <avr/pgmspace.h>
//使用PROGMEM存放GPS方向数组,节省SRAM
prog_char d_0[] PROGMEM = "N";
prog_char d_1[] PROGMEM = "NNE";
prog_char d_2[] PROGMEM = "NE";
prog_char d_3[] PROGMEM = "ENE";
prog_char d_4[] PROGMEM = "E";
prog_char d_5[] PROGMEM = "ESE";
prog_char d_6[] PROGMEM = "SE";
prog_char d_7[] PROGMEM = "SSE";
prog_char d_8[] PROGMEM = "S";
prog_char d_9[] PROGMEM = "SSW";
prog_char d_10[] PROGMEM = "SW";
prog_char d_11[] PROGMEM = "WSW";
prog_char d_12[] PROGMEM = "W";
prog_char d_13[] PROGMEM = "WNW";
prog_char d_14[] PROGMEM = "NW";
prog_char d_15[] PROGMEM = "NNW";
PROGMEM const char *dir_table[] =
   d_0,
   d_1,
   d_2,
   d_3,
   d_4,
   d_5,
   d_6,
   d_7,
   d_8,
   d_9,
   d_10,
   d_11,
   d_12,
   d_13,
   d_14,
   d_15
TinyGPS gps;
//U8GLIB_PCD8544 u8g(3, 4, 99, 5, 6);  // SPI Com: SCK = 3, MOSI = 4, CS = 永远接地, A0 = 5, Reset = 6
U8GLIB_ST7920_128X64_4X u8g(3, 9, 8); // 声明液晶屏  8-D/I  9-R/W  3-E
File myFile;
boolean sderror = false;                //TF卡状态
char logname[13];                            //记录文件名
boolean writelog = true;                //是否要记录当前数据到TF卡标志
boolean refresh = false;                //是否要更新液晶显示标志
boolean finish_init = false;    //初始化完成标志
byte satnum=0;          //连接上的卫星个数
float flat, flon, spd, alt, oflat, oflon;       //GPS信息,经纬度、速度、高度、上一次的经纬度
unsigned long age;                        //GPS信息 fix age
int year;                                          //GPS信息 年
byte month, day, hour, minute, second, hundredths;            //GPS信息 时间信息
char crs[4];                    //GPS信息 行驶方向
char sz[10];                    //文本信息
byte cnt=0;                              //循环计数器
static void gpsdump(TinyGPS &gps);
static bool feedgps();
static void print_date(TinyGPS &gps);
static void print_satnum(TinyGPS &gps);
static void print_pos(TinyGPS &gps);
static void print_alt(TinyGPS &gps);
static void print_speed(TinyGPS &gps);
static void print_course(TinyGPS &gps);
static String float2str(float val, byte len);
//AVR定时器,每秒触发
ISR(TIMER1_OVF_vect) {
TCNT1=0x0BDC; // set initial value to remove time error (16bit counter register)
if (finish_init) refresh = true;      //在完成初始化后,将刷新显示标志设为true
//设置并激活AVR计时器
TIMSK1=0x01; // 启用全局计时器中断
TCCR1A = 0x00; //normal operation page 148 (mode0);
TCNT1=0x0BDC; //set initial value to remove time error (16bit counter register)
TCCR1B = 0x04; //启动计时器
pinMode(10, OUTPUT);
oflat = 0;
oflon = 0;
logname[0]=' ';
Serial.begin(9600); //GPS模块默认输出9600bps的NMEA信号
u8g.setColorIndex(1);         // 设置LCD显示模式,黑白
u8g.setFont(u8g_font_04b_03br);       //字体
//TF卡的片选端口是10
if (!SD.begin(10)) {
   sderror = true;
//初始化完成
finish_init = true;
  //读取并分析GPS数据
  feedgps();
  //刷新显示
  if (refresh)
     cnt %=10;
     writelog = true;
     u8g.firstPage();
     do{
       gpsdump(gps);
       u8g.setPrintPos(70,48);
       u8g.print( cnt);
     } while ( u8g.nextPage() );
         //每5秒且GPS信号正常时将数据记录到TF卡
     if (cnt % 5 == 0 && writelog)
       logEvent();
         //刷新完毕,更新秒计数器
     refresh = false;
     cnt++;
print_satnum(gps);
print_date(gps);
print_pos(gps);
print_speed(gps);
print_alt(gps);
print_course(gps);
//更新并显示卫星个数
satnum = gps.satellites();
if ( satnum != TinyGPS::GPS_INVALID_SATELLITES){
   u8g.setPrintPos( 46, 6);
   u8g.print(satnum);
   writelog &= true;
else {
   u8g.drawStr( 10, 15, F("gTracking System"));
   u8g.drawStr( 22, 23, F("build 2506"));
   u8g.drawStr( 0, 34, (cnt % 2) ? F("Searching...") : F("            "));
   //u8g.drawStr( 7, 48, F("wells.osall.com"));
   writelog = false;
feedgps();
//更新并显示GPS经纬度信息
gps.f_get_position(&flat, &flon, &age);
if (flat != TinyGPS::GPS_INVALID_F_ANGLE && flon !=  TinyGPS::GPS_INVALID_F_ANGLE) {
   u8g.setPrintPos(0,40);
   u8g.print(float2str(flon,8));
   u8g.print(F(" : "));
   u8g.print(float2str(flat,8));
   writelog &= true;
   writelog = false;
feedgps();
//更新并显示GPS高度信息
alt = gps.f_altitude();
if (alt != TinyGPS::GPS_INVALID_F_ALTITUDE){
   u8g.setPrintPos(0,48);
   u8g.print(F("Alt: "));
   u8g.print(float2str(alt,5));
   writelog &= true;
   writelog = false;
feedgps();
//更新并显示行驶方向
if (gps.f_course() == TinyGPS::GPS_INVALID_F_ANGLE)
   writelog = false;
       //从PROGMEM中读取数组中的字符串
   strcpy_P(crs,(char*)pgm_read_word(&(dir_table[gps.cardinal(gps.f_course())])));
   u8g.setPrintPos(60,6);
   u8g.print(crs);
feedgps();
//更新并显示GPS时间
gps.crack_datetime(&year, &month, &day, &hour, &minute, &second, &hundredths, &age);
if (age != TinyGPS::GPS_INVALID_AGE && month>0 && day>0)
   u8g.setPrintPos( 0, 6);
   sprintf(sz, "%02d",((hour+8) % 24)); //显示北京时间 GMT+8
   u8g.print(sz);
   u8g.setPrintPos( 11, 6);
   u8g.print(second % 2 ? F(":") : F(" "));
   u8g.setPrintPos(15,6);
   sprintf(sz, "%02d",minute);
   u8g.print(sz);
   writelog &= true;
   writelog = false;
feedgps();
//更新并显示时速
spd = gps.f_speed_kmph();
if (spd != TinyGPS::GPS_INVALID_F_SPEED)
       if(spd<0.5) spd=0.0; //屏蔽0时速时的误差显示
   u8g.drawStr(0,14, F("SPEED"));
   u8g.setPrintPos(0,32);
   u8g.setFont(u8g_font_fub14n); //使用大字体
   u8g.print( float2str(spd,5));
   u8g.print(F(" km/h"));
   writelog &= true;
   writelog = false;
feedgps();
//读取并解码GPS信息
while (Serial.available())
   if (gps.encode(Serial.read()))
     return true;
return false;
//将浮点数转化为字符串(整数部分<1000)
String str = "";
char tmp[4];
byte pos = 0;
int p1;
bool minus=false;
//取绝对值
if (val<0)
   minus=true;
   len--;
   val = abs(val);
p1=(int)val;  //取整数部分
val=val-p1;   //得到小数部分
itoa(p1,tmp,10);      //整数部分转化为字符串
str.concat(tmp);
//获得小数点位置
if (p1 == 0) {
   pos = 1;
else {
   for (pos=0;pos<len && p1>0;pos++)
     p1=p1/10;
//小数点
if (pos<len && val>0){
   pos++;
   str.concat('.');
//小数部分加入字符串
for (;pos<len&& val>0;pos++)
   str.concat((char)('0'+ (byte)(val*10)));
   val= val * 10 - ((byte)(val*10));
if (minus) str = "-" + str;
return str;
//记录数据到TF卡
void logEvent()
if (logname[0]==' ') {        //获取文件名
   sprintf(logname, "%04d%02d%02d.trc",  year, month, day, hour, minute, second);
   myFile=SD.open(logname, FILE_WRITE);
   if (!myFile) {
     sderror = true;
   else {
      myFile.println(F("#gTracking#b2506#"));  //输出数据的版本信息
      myFile.close();
      delay(10);
//当位置和上一次(5秒前)相比发生一定变化量时才记录数据(节省数据文件的空间)
if (writelog && logname[0]!=' ' &&  (abs(flat-oflat) > 0.0001 || abs(flon - oflon) > 0.0001))
   if (!myFile) {
     sderror = true;
     oflat = flat;
     oflon = flon;
     sprintf(sz, "%04d-%02d-%02d",  year, month, day);
     myFile.print(sz);
     myFile.print(F(","));
     sprintf(sz, "%02d:%02d:%02d,", hour, minute, second);
     myFile.print(sz);
     sprintf(sz,"%02d,",satnum);
     myFile.print(sz);
     myFile.print(float2str(flat,20));
     myFile.print(",");
     myFile.print(float2str(flon,20));
     myFile.print(",");
     myFile.print(float2str(alt,10));
     myFile.print(",");
     myFile.print(float2str(spd,10));
     myFile.print(",");
     myFile.print(crs);
     myFile.println(",");
     delay(20);
     myFile.flush();
     delay(50);
     myFile.close();
 楼主| 发表于 2013-9-23 08:31:52 | 显示全部楼层
我把有错误的代码行暂时注释掉后,烧写进我的UNO,发现无法正常运行!
有哪位帮忙测试一下!
无法编译通过的代码是这个:
发表于 2014-5-5 22:14:08 | 显示全部楼层
有哪位帮忙测试一下!
同问啊楼主,,你解决这个问题了没有啊?????????,求解??
发表于 2014-5-10 18:25:49 | 显示全部楼层
我也在看这个代码。还没搞清楚
 楼主| 发表于 2014-5-10 18:53:37 | 显示全部楼层
没呢,好久没有去再动这个代码了
 楼主| 发表于 2014-5-10 18:57:13 | 显示全部楼层
http://www.biketo.com/edge/knowledge/135961279612002.html
这个是原贴
发表于 2014-5-10 19:42:03 | 显示全部楼层
这个是原贴
你是打算做一个什么样的东西呢?
我只打算做一个轨迹记录的
现在调好了显示,GPS解析,卡在SD存储这部分了。
分开调试各个部分的代码,都没有问题,当把SD卡部分接进去之后,系统会变得相当相当的慢……
 楼主| 发表于 2014-5-18 10:49:50 | 显示全部楼层
maxims 发表于 2014-5-10 19:42
你是打算做一个什么样的东西呢?
我只打算做一个轨迹记录的
现在调好了显示,GPS解析,卡在SD存储这部分 ...
我贴的代码你能通过编译吗???
发表于 2014-5-19 22:08:02 | 显示全部楼层
huanter 发表于 2014-5-18 10:49
我贴的代码你能通过编译吗???
你是打算做什么样的东西?
这个代码,我修改之后,已经调试通过了。
GMT+8, 2026-7-29 02:59 , Processed in 0.057625 second(s), 20 queries .
