查看: 10144|回复: 4
请教一个关于12864的问题
发表于 2013-10-3 23:15:38 | 显示全部楼层 |阅读模式
大家帮我看看这程序有问题吗?就是在弘毅的教程的基础上加了一张图,但下载到arduino用12864显示的时候第一张的字和第二张的笑脸都有问题,字整个乱码,笑脸不完整,但第三张我家的图片是完好的,我把我加的那张图片的代码删了,就一点问题没有了,怎么回事?难道ARDUINO+12864只能显示这么多?
代码:
LCD  Arduino
PIN1 = GND
PIN2 = 5V
RS(CS) = 8;
RW(SID)= 9;
EN(CLK) = 3;
PIN15 PSB = GND;
#include "LCD12864RSPI.h"
#define AR_SIZE( a ) sizeof( a ) / sizeof( a[0] )
unsigned char show0[]={0xBC,0xAB,0xBF,0xCD,0xB9,0xA4,0xB7,0xBB};//极客工坊
unsigned char show1[]="geek-workshop";
unsigned char logo0[]={                                         //笑脸
      0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x00,0x00,0x01,0xFF,
      0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x00,0x00,0x1F,0xFF,
      0xF8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,
      0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x00,0x03,0xFE,0x00,
      0x7F,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x00,0x0F,0xF0,0x00,
      0x0F,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x00,0x1F,0x80,0x00,
      0x01,0xF8,0x00,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x00,0x3E,0x00,0x00,
      0x00,0x7C,0x00,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x00,0xF8,0x00,0x00,
      0x00,0x1F,0x00,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x01,0xF0,0x00,0x00,
      0x00,0x0F,0x80,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x03,0xE0,0x00,0x00,
      0x00,0x07,0xC0,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x07,0xC0,0x00,0x00,
      0x00,0x01,0xE0,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x07,0x80,0x00,0x00,
      0x00,0x00,0xE0,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x0F,0x00,0x00,0x00,
      0x00,0x00,0xF0,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x1E,0x00,0x00,0x00,
      0x00,0x00,0x78,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x3C,0x00,0x00,0x00,
      0x00,0x00,0x3C,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x38,0x00,0x40,0x00,
      0x00,0x80,0x1C,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x78,0x03,0xF8,0x00,
      0x07,0xF0,0x1E,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x70,0x07,0xFE,0x00,
      0x0F,0xFC,0x0E,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0xF0,0x1F,0xBF,0x00,
      0x3F,0x7E,0x0F,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0xE0,0x3E,0x0F,0x80,
      0x7C,0x1F,0x07,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0xE0,0x7C,0x07,0xC0,
      0xF8,0x0F,0x87,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x01,0xE0,0xF8,0x01,0xE1,
      0xF0,0x03,0xC3,0x80,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x01,0xC0,0xF0,0x01,0xE1,
      0xE0,0x03,0xC3,0x80,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x01,0xC0,0xE0,0x00,0xE1,
      0xC0,0x01,0xC3,0x80,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x01,0xC0,0x00,0x00,0x00,
      0x00,0x00,0x03,0x80,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x03,0x80,0x00,0x00,0x00,
      0x00,0x00,0x01,0xC0,0x00,0x00,0x00,0x00,
      0x00,0x00,0x01,0x80,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x01,0xE0,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0xE0,0x00,0x00,0x00,
      0x00,0x00,0x07,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0xF0,0x00,0x0C,0x00,
      0x0C,0x00,0x0F,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x70,0x00,0x1E,0x00,
      0x1E,0x00,0x0E,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x78,0x00,0x1F,0x00,
      0x3E,0x00,0x1E,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x38,0x00,0x07,0x80,
      0xF8,0x00,0x1C,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x3C,0x00,0x03,0xE1,
      0xF0,0x00,0x3C,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x1E,0x00,0x01,0xFF,
      0xE0,0x00,0x78,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x0F,0x00,0x00,0xFF,
      0x80,0x00,0xF0,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x07,0x00,0x00,0x3F,
      0x00,0x7E,0x00,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x00,0x0F,0xE0,0x00,
      0x07,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,
      0x3F,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x80,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0x00,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0x00,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xF0,0x00,0x00,
      0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0x00,0x00,
      0xFF,0xFF,0xFF,0xFF,0xF0,0x00,0x00,0x00,
      0xFF,0xFF,0xFF,0xFE,0x00,0x00,0x00,0x00,
      0xFF,0xFF,0xFF,0xE0,0x00,0x00,0x00,0x00,
      0xFF,0xFF,0xFE,0x00,0x00,0x00,0x00,0x00,
      0xFF,0xFF,0xC0,0x00,0x00,0x00,0x00,0x00,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xC0,
      0xFF,0xFC,0x00,0x00,0x00,0x00,0x00,0x00,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x9E,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xBF,
      0x38,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x03,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,
      0xFF,0xFF,0xFF,0xFF,0xFF,0x83,0xFE,0x00,
      0xFF,0xFF,0xFF,0xFF,0xFF,0x06,0xF8,0x00,
      0x60,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
      0xFF,0xFF,0xFF,0xFF,0xFC,0x06,0x00,0x01,
      0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
      0xFF,0xFF,0xFF,0xFF,0xF8,0x00,0x00,0x0F,
      0xFF,0xFF,0xFF,0xFF,0xC0,0x00,0x00,0x0F,
      0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
      0xFF,0xFF,0xFF,0x8F,0x80,0x00,0x00,0x0F,
      0xF3,0xFF,0xFC,0x07,0x00,0x00,0x00,0x0F,
      0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
      0xC7,0xF8,0x88,0x00,0x00,0x00,0x00,0x0F,
      0xFF,0xFF,0xFC,0x00,0x00,0x00,0x00,0x0F,
      0xFF,0xFF,0xFF,0xFE,0x00,0x00,0x00,0x0F,
      0xFF,0xFF,0xFF,0xFF,0x80,0x00,0x3C,0x07,
      0xFE,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
      0xFF,0xFF,0xFF,0xFF,0xF0,0x00,0x7E,0xFF,
      0x8F,0x80,0x00,0x00,0x00,0x00,0x00,0x00,
      0xFF,0xFF,0xFF,0xFF,0xF8,0x00,0x7E,0xFF,
      0x8F,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,
      0xFF,0xFF,0xFF,0xFF,0xFE,0x00,0x7D,0xFF,
      0x1F,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xC3,0xF9,0xFF,
      0x3F,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xE3,0x9B,0xFF,
      0x3F,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xAF,0xFB,0xFE,
      0x7F,0xF8,0x00,0x00,0x00,0x00,0x00,0x00,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xEF,0xF3,0xFC,
      0x7F,0xFE,0x00,0x00,0x00,0x00,0x00,0x00,
      0xFF,0xFF,0xFF,0xFF,0xFE,0xFF,0xF7,0xFC,
      0x7F,0xFF,0x80,0x00,0x00,0x00,0x00,0x00,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF7,0xFC,
      0xFF,0xFF,0xE0,0x00,0x00,0x00,0x00,0x00,
      0xFF,0xFF,0xF8,0x00,0x00,0x00,0x00,0x00,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF9,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x9F,0xF1,
      0xFF,0xFF,0xFF,0x80,0x00,0x00,0x00,0x00,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0x0F,0xF3,
      0xFF,0x1F,0xFF,0xC0,0x00,0x00,0x00,0x00,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xF0,0x0F,0xE3,
      0xFF,0x03,0xFF,0xFC,0x00,0x00,0x00,0x00,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0x07,0xC3,
      0xFF,0x00,0xFF,0xFC,0x00,0x00,0x00,0x00,
      0xFF,0xFF,0xEF,0xFF,0xFF,0x80,0x07,0xC7,
      0xFF,0x80,0x07,0xBF,0x00,0x00,0x00,0x00,
      0x00,0x07,0x3F,0xDC,0x00,0x00,0x03,0x87,
      0xFF,0x80,0x00,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x30,0x00,0x00,0x00,0x01,0x8F,
      0xFF,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x0F,
      0x00,0x00,0x00,0x00,0x00,0x00,0x08,0x0F,
      0xFF,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1F,
      0xFF,0xE0,0x00,0x00,0x1E,0x00,0x20,0x00,
      0x00,0x00,0x00,0x80,0x40,0x00,0x00,0x1F,
      0xFF,0xE5,0xDE,0x2F,0xFC,0xFD,0x00,0x00,
      0x00,0x00,0x03,0x00,0x40,0x20,0x00,0x1F,
      0xFF,0xFF,0xFE,0xF2,0x3F,0xFC,0xE0,0x00,
      0x00,0x00,0x0F,0xEF,0xDD,0xF6,0x00,0x0F,
      0xFF,0xFB,0xF3,0xFF,0xFF,0xFF,0x00,0x00,
      0xD9,0x13,0xBF,0xFF,0xFF,0xFE,0x00,0x2F,
      0xFF,0xFF,0xFF,0xFF,0xFD,0xF9,0x00,0x00,
      0xFF,0xE7,0xFF,0xF9,0xF9,0xFC,0x00,0x37,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0x00,0x00,
      0x9E,0xFE,0x4F,0xFF,0xFF,0xFC,0x00,0x57,
      0xFF,0xF8,0xFF,0xE4,0x7F,0xE8,0x00,0x00,
      0xEF,0xFF,0xFF,0xFF,0xFF,0xF8,0x00,0x1F,
      0xFF,0xF8,0xFF,0xFE,0x0F,0x80,0x00,0x00,
      0xC3,0x81,0xFB,0xDE,0xB0,0x08,0x00,0x1F,
      0xFF,0xF8,0x67,0xFE,0x1C,0x20,0x00,0x08,
      0x00,0x03,0xBB,0x60,0x31,0xC0,0x00,0x1F,
      0xFF,0xF8,0x0F,0xF7,0xFD,0xFF,0xE0,0x00,
      0x00,0x01,0x8F,0x8B,0xFB,0xC0,0x00,0x3F,
      0xFF,0xF8,0x7E,0xFF,0xFF,0x43,0x20,0x00,
      0x00,0x00,0x0E,0x01,0xFF,0xE0,0x00,0x1F,
      0xFF,0xFF,0xFF,0xFF,0xE0,0x00,0x00,0x00
LCDA.Initialise(); // 屏幕初始化
delay(100);
LCDA.CLEAR();//清屏
delay(100);
LCDA.DisplayString(0,2,show0,AR_SIZE(show0));//第一行第三格开始,显示文字极客工坊
delay(100);
LCDA.DisplayString(2,1,show1,AR_SIZE(show1));;//第三行第二格开始,显示文字geek-workshop
delay(5000);
LCDA.CLEAR();//清屏
delay(100);
LCDA.DrawFullScreen(logo0);
delay(5000);
LCDA.CLEAR();//清屏
delay(100);
LCDA.DrawFullScreen(logo1);
delay(5000);
发表于 2013-10-4 15:24:18 | 显示全部楼层
我好像也看到过笑脸不完整的情况,关注一下。
 楼主| 发表于 2013-10-5 21:44:20 | 显示全部楼层
没有人知道吗?
发表于 2013-10-7 18:03:10 | 显示全部楼层
看到你第二个表情也是logo0?两个logo0
GMT+8, 2026-7-28 00:33 , Processed in 0.035611 second(s), 19 queries .
