查看: 11480|回复: 1
W5100如何实现不间断向服务器发GET请求?
发表于 2013-10-31 14:52:20 | 显示全部楼层 |阅读模式
#include <SPI.h>
#include <Ethernet.h>
// Enter a MAC address for your controller below.
// Newer Ethernet shields have a MAC address printed on a sticker on the shield
byte mac[] = {  0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress server(173,194,33,104); // Google
// Initialize the Ethernet client library
// with the IP address and port of the server
// that you want to connect to (port 80 is default for HTTP):
EthernetClient client;
// Open serial communications and wait for port to open:
   while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  // start the Ethernet connection:
  if (Ethernet.begin(mac) == 0) {
    // no point in carrying on, so do nothing forevermore:
    for(;;)
  // give the Ethernet shield a second to initialize:
  delay(1000);
  // if you get a connection, report back via serial:
  if (client.connect(server, 80)) {
    Serial.println("connected");
    // Make a HTTP request:
    client.println("GET /search?q=arduino HTTP/1.0");
    client.println();
  else {
    // kf you didn't get a connection to the server:
  // if there are incoming bytes available
  // from the server, read them and print them:
  if (client.available()) {
    char c = client.read();
    Serial.print(c);
  // if the server's disconnected, stop the client:
  if (!client.connected()) {
    Serial.println();
    client.stop();
    // do nothing forevermore:
    for(;;)
以上例子,只能实现一次请求。。
如何实现不不间断请求。。。
发表于 2013-10-31 14:59:09 | 显示全部楼层
  1.     // do nothing forevermore:
  2.     for(;;)
  3.       ;
把这个换成延时函数
GMT+8, 2026-7-27 20:50 , Processed in 0.110469 second(s), 20 queries .
